Output of starting signal-desktop:
NODE_ENV production
NODE_CONFIG_DIR /usr/lib/signal-desktop/resources/app.asar/config
NODE_CONFIG {}
ALLOW_CONFIG_MUTATIONS undefined
HOSTNAME Leviathan
NODE_APP_INSTANCE undefined
SUPPRESS_NO_CONFIG_WARNING undefined
SIGNAL_ENABLE_HTTP undefined
userData: /home/xmanmonk/.config/Signal
(node:450467) [DEP0180] DeprecationWarning: fs.Stats constructor is deprecated.
(Use `signal-desktop --trace-deprecation ...` to show where the warning was created)
2026-07-25 15:09:07.266: ERROR CORE sqlcipher_page_cipher: hmac check failed for pgno=1
2026-07-25 15:09:07.267: ERROR CORE sqlite3Codec: error decrypting page 1 data: 1
2026-07-25 15:09:07.267: ERROR CORE sqlcipher_codec_ctx_set_error 1
2026-07-25 15:09:07.279: ERROR CORE sqlcipher_page_cipher: hmac check failed for pgno=1
2026-07-25 15:09:07.279: ERROR CORE sqlite3Codec: error decrypting page 1 data: 1
2026-07-25 15:09:07.279: ERROR CORE sqlcipher_codec_ctx_set_error 1
Tried starting with gpu disabled, same issue. Running signal-desktop 8.20.0-1 from extra.
