SigLevel = PackageRequired in pacman.conf
Is SigLevel = PackageRequired needed in pacman.conf?
The pacnew file version doesn’t have this line and I didn’t add it to the file myself in the past but perhaps some GUI tool did?
Thank you.
No, it’s no longer required. It was removed from the default file years ago, maybe with Pacman 7.0 if I remember correctly.
First time I ever looked at the pacnew files since using Manjaro—about five years. Had about only a dozen or so and with very small changes; and can still boot. Thanks.
@scotty65 Sorry, I meant that I can still boot after dealing with them. Was a bit worried I’d mess up something important.
It is very important that .pacnew & .pacsave files are dealt with ASAP after updates:
