Shutting down wpa_supplicant and network manager takes many time
Hi,
First of all sorry for my poor english.
I have a Raspberry pi 4 with Manjaro KDE, and it runs very well.
The problem is that sometimes when it shutting down the process stops for several minutes on the wpa_supplicant and network_manager line.
This is not always, maybe half of the times.
There is any solution for this?
Thanks
I do not use KDE but have not noticed that here. It is weird that it would do that 50% of the time and be ok the rest of the time. Do you have crda installed and your Country code configured?
https://wiki.archlinux.org/title/Network_configuration/Wireless#Respecting_the_regulatory_domain
@/acharco …
I am running Manjaro 5.15 KDE now. This slowdown shutdown appears to have been managed. Prior to this, my kernels were doing the exact same thing. I would need to press the CPU reset button to get out of the endless wpa_supplicant and NetworkManager shutdown loop.
This leads me to believe it is a kernel bug, and nothing my own local machine is doing.
Good luck, friend!
There was an issue with the kernel a while back and I posted a temp fix using iwd/networkmanager here:
https://forum.manjaro.org/t/new-raspberry-pi-kernels-related-packages/4721/510
Thank you all
