- “Check ~/.xsession-errors, maybe follow it”
Copy-paste from ~/.xsessions-errors.old:
(wrapper-2.0:1578): Gtk-WARNING **: 20:46:47.577: Failed to set text '<markup><b>Yakuake</b>
<html>Press <b>F12</b> to open</html></markup>' from markup due to error parsing markup: Unknown tag 'html' on line 2 char 8
[2979:2979:0207/204700.081385:ERROR:shared_image_factory.cc(575)] Could not find SharedImageBackingFactory with params: usage: Gles2|Raster|DisplayRead|Scanout, format: RED_8, share_between_threads: 0, gmb_type: shared_memory
[2979:2979:0207/204700.081455:ERROR:shared_image_factory.cc(575)] Could not find SharedImageBackingFactory with params: usage: Gles2|Raster|DisplayRead|Scanout, format: RG_88, share_between_threads: 0, gmb_type: shared_memory
[2979:2979:0207/204701.483332:ERROR:shared_image_factory.cc(575)] Could not find SharedImageBackingFactory with params: usage: Gles2|Raster|DisplayRead|Scanout, format: RED_8, share_between_threads: 0, gmb_type: shared_memory
[2979:2979:0207/204701.483408:ERROR:shared_image_factory.cc(575)] Could not find SharedImageBackingFactory with params: usage: Gles2|Raster|DisplayRead|Scanout, format: RG_88, share_between_threads: 0, gmb_type: shared_memory
X protocol error:
<class 'Xlib.error.BadAccess'>: code = 10, resource_id = 472, sequence_number = 60, major_opcode = 33, minor_opcode = 0
X protocol error:
<class 'Xlib.error.BadAccess'>: code = 10, resource_id = 472, sequence_number = 61, major_opcode = 33, minor_opcode = 0
X protocol error:
<class 'Xlib.error.BadAccess'>: code = 10, resource_id = 472, sequence_number = 62, major_opcode = 33, minor_opcode = 0
X protocol error:
<class 'Xlib.error.BadAccess'>: code = 10, resource_id = 472, sequence_number = 63, major_opcode = 33, minor_opcode = 0
xscreensaver: 20:47:10: SIGHUP received: restarting
[1728:0207/204710.628006:ERROR:zygote_communication_linux.cc(291)] Failed to send GetTerminationStatus message to zygote
[1728:0207/204710.628854:ERROR:gpu_process_host.cc(985)] GPU process launch failed: error_code=1002
[1728:0207/204710.629174:ERROR:gpu_process_host.cc(985)] GPU process launch failed: error_code=1002
[1728:0207/204710.629419:ERROR:gpu_process_host.cc(985)] GPU process launch failed: error_code=1002
[1728:0207/204710.629648:ERROR:gpu_process_host.cc(985)] GPU process launch failed: error_code=1002
[1728:0207/204710.629927:ERROR:gpu_process_host.cc(985)] GPU process launch failed: error_code=1002
[1728:0207/204710.631815:ERROR:gpu_process_host.cc(985)] GPU process launch failed: error_code=1002
[1728:0207/204710.632364:ERROR:network_service_instance_impl.cc(521)] Network service crashed, restarting service.
[1728:0207/204710.637524:ERROR:gpu_process_host.cc(985)] GPU process launch failed: error_code=1002
[1728:0207/204710.639259:ERROR:zygote_communication_linux.cc(291)] Failed to send GetTerminationStatus message to zygote
[1728:0207/204710.639942:ERROR:gpu_process_host.cc(985)] GPU process launch failed: error_code=1002
[1728:0207/204710.640346:ERROR:gpu_process_host.cc(985)] GPU process launch failed: error_code=1002
[1728:0207/204710.640354:FATAL:gpu_data_manager_impl_private.cc(440)] GPU process isn't usable. Goodbye.
Because of this I’ll not use Yakuake for a while, and, after searching for the “FATAL:gpu_data_manager_impl_private.cc(440)] GPU process isn’t usable. Goodbye.” error, I’ve removed xfce4-notes from autostarting as well, even though the search results pertains automattic/simplenote.
- “Check coredumpctl”
Nothing relevant to see here, i.e., no data at times of a crash.
- “Check journalctl -b 0 or -b -1”
[x@i5 ~]$ journalctl -b 0
feb 07 20:47:32 i5 kernel: Linux version 5.15.91-1-MANJARO (builduser@fv-az173-127) (gcc (GCC) 12.2.1 20230111, GNU ld (GNU >
feb 07 20:47:32 i5 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=56d4f2fd-0e54-494a-ba31-3e4a1cacb0f4>
feb 07 20:47:32 i5 kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
feb 07 20:47:32 i5 kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
feb 07 20:47:32 i5 kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
feb 07 20:47:32 i5 kernel: x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
feb 07 20:47:32 i5 kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
feb 07 20:47:32 i5 kernel: x86/fpu: xstate_offset[9]: 832, xstate_sizes[9]: 8
feb 07 20:47:32 i5 kernel: x86/fpu: Enabled xstate features 0x207, context size is 840 bytes, using 'compacted' format.
feb 07 20:47:32 i5 kernel: signal: max sigframe size: 3632
feb 07 20:47:32 i5 kernel: BIOS-provided physical RAM map:
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000005dfff] usable
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x000000000005e000-0x000000000005efff] reserved
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x000000000005f000-0x000000000009ffff] usable
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000031863fff] usable
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x0000000031864000-0x0000000034963fff] reserved
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x0000000034964000-0x0000000034bc8fff] ACPI data
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x0000000034bc9000-0x00000000350bcfff] ACPI NVS
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x00000000350bd000-0x0000000035f65fff] reserved
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x0000000035f66000-0x0000000035ffefff] type 20
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x0000000035fff000-0x0000000035ffffff] usable
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x0000000036000000-0x0000000039ffffff] reserved
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x000000003a800000-0x000000003abfffff] reserved
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x000000003b000000-0x00000000403fffff] reserved
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x00000000fc000000-0x00000000fc00ffff] reserved
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
feb 07 20:47:32 i5 kernel: BIOS-e820: [mem 0x0000000100000000-0x00000008bfbfffff] usable
feb 07 20:47:32 i5 kernel: NX (Execute Disable) protection: active
feb 07 20:47:32 i5 kernel: efi: EFI v2.80 by American Megatrends
feb 07 20:47:32 i5 kernel: efi: ACPI=0x3501a000 ACPI 2.0=0x3501a014 TPMFinalLog=0x34fe7000 SMBIOS=0x35a48000 SMBIOS 3.0=0x35>
feb 07 20:47:32 i5 kernel: SMBIOS 3.5.0 present.
feb 07 20:47:32 i5 kernel: DMI: Gigabyte Technology Co., Ltd. Z790 GAMING X AX/Z790 GAMING X AX, BIOS F2 09/27/2022
feb 07 20:47:32 i5 kernel: tsc: Detected 3500.000 MHz processor
feb 07 20:47:32 i5 kernel: tsc: Detected 3494.400 MHz TSC
- “Are you running xcape? See Settings > Session and Startup > Application Autostart”
I was, disabled it.
Let’s see if it happens again. Thank you.
