Shutdown/restart is not clean
These errors appear on the screen for a second or two before proceeding to shutdown or restart.
  Kernel: 5.14.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
  root=UUID=25bda109-a98d-4b7f-8f35-7171a9fb6574 rw quiet splash loglevel=3
  vt.global_cursor_default=0 apparmor=1 security=apparmor
  resume=UUID=cd407363-6714-4634-8880-92fb188e7ddb udev.log_priority=3
  Desktop: GNOME 41.1 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 41.0
  Type: Laptop System: Dell product: Inspiron 16 7610 v: N/A
  Mobo: Dell model: 0599VR v: A00 serial: <superuser required> UEFI: Dell
  v: 1.1.3 date: 09/24/2021
  ID-1: BAT0 charge: 76.3 Wh (100.0%) condition: 76.3/84.3 Wh (90.5%)
  volts: 12.9 min: 11.4 model: BYD DELL M59JH16 type: Li-poly serial: <filter>
  status: Full
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
  charge: 55% (should be ignored) rechargeable: yes status: Discharging
  Info: 8-Core model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
  arch: Tiger Lake family: 6 model-id: 8D (141) stepping: 1 microcode: 34
  cache: L1: 640 KiB L2: 10 MiB L3: 24 MiB
  flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  bogomips: 73744
  Speed: 1049 MHz min/max: 800/4600 MHz Core speeds (MHz): 1: 1207 2: 949
  3: 1132 4: 801 5: 1052 6: 818 7: 1177 8: 1069 9: 952 10: 1187 11: 1059
  12: 1077 13: 821 14: 856 15: 1213 16: 1074
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
  v: kernel bus-ID: 0000:00:02.0 chip-ID: 8086:9a60 class-ID: 0300
  Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Dell
  driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 0000:01:00.0
  chip-ID: 10de:25a2 class-ID: 0302
  Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB driver: uvcvideo
  bus-ID: 3-5:3 chip-ID: 1bcf:2a02 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.org 1.21.1.1 compositor: gnome-shell driver:
  loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa
  OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 21.2.5
  direct render: Yes
  Device-1: Intel Tiger Lake-H HD Audio vendor: Dell
  driver: sof-audio-pci-intel-tgl
  alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
  chip-ID: 8086:43c8 class-ID: 0401
  Sound Server-1: ALSA v: k5.14.18-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.40 running: yes
  Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
  bus-ID: 0000:00:14.3 chip-ID: 8086:43f0 class-ID: 0280
  bus-ID: 3-14:5 chip-ID: 8087:0026 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
  v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 953.87 GiB used: 83.52 GiB (8.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC711 NVMe 1TB
  size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 type: SSD serial: <filter> rev: 41001131 temp: 51.9 C scheme: GPT
  ID-1: / raw-size: 245.95 GiB size: 241.03 GiB (98.00%)
  used: 83.52 GiB (34.7%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
  used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
  ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme0n1p5 maj-min: 259:5
  System Temperatures: cpu: 46.0 C mobo: N/A
  Processes: 347 Uptime: 13m wakeups: 3 Memory: 38.93 GiB used: 2.9 GiB (7.4%)
  Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages:
  pacman: 1218 lib: 302 Shell: Zsh v: 5.8 running-in: gnome-terminal
  inxi: 3.3.09
How do I fix these? Are these something to be concerned about?
If everything works normally, then I’d ignore those messages. Verbosity does not necessarily indicate an error. :wink:
Thanks. Fact is how do I know if everything is normal (unless the above errors are considered normal). Just wanted to confirm that :slight_smile:
Nevertheless, it sounds like there is nothing to be worried about just that plymouth stopped working after these errors started to surface.
Well, there’s a correlation but not a causality. :wink:
Plymouth uses another video memory buffer than the system console. Plymouth runs in graphical mode, while the messages you are seeing are from the main system console framebuffer, which runs in character mode. This buffer is not emptied after the boot process, but because your system switches to graphical mode, the buffer is no longer visible on the screen.
Then during shutdown, the graphical mode stops and the system switches back to the system console, which contains all of these messages. Some of them may constitute some kind of warning, some might be actual errors ─ although you would then be experiencing difficulties during usage ─ and yet others are just spurious verbosity.
You could suppress (most of) them by playing with the following line in /etc/default/grub:arrow_down:
GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3"
The quiet parameter ─ if present; you may need to add it ─ already gets rid of most of the spurious stuff. The udev.log_priority parameter determines what information must be shown and what information is less important. You can find more information about that at the Arch wiki.
Be sure to run… :arrow_down:
sudo update-grub
… after modifying the file.
Edit: Concretely…
  • The watchdog message can be ignored;
  • The systemd-udevd message can also be ignored; and
  • The /oldroot/sys message is something that appears when people are using the proprietary Nvidia driver with ─ I believe ─ CUDA support.
So, nothing to worry about. :wink:
That helped a lot. Thanks again!
