I updated the system and now I am having problems with the shutdown/restart.
Each time I shutdown/restart , the screen goes black instantly (like the computer is off , showing the no signal text) but the computer keeps running and makes 3-4 beeps one at a time at around 15-20 seconds interval.
The beeps are similar in sound and duration to those that happen when the PC starts but I never had beeps before when shutting down untill now and the process would take less than 5 seconds vs now around 1-2 min.
After that it continues with the process of shutting down/restarting.
Tried:
systemctl poweroff
But with no luck.
Tried looking in ~/.config/ksmserverrc
and it shows:
[$Version]
update_info=ksmserver_update_loginMode_value.upd:ksmserver_update_loginMode_value_default_enum[General]
loginMode=emptySession
The update history for that day:
[2022-07-31T01:49:39+0300] [ALPM] installed gedit-plugins (42.1-1)
[2022-07-31T01:49:39+0300] [ALPM] installed gedit (42.1-1)
[2022-07-31T01:49:39+0300] [ALPM] installed gspell (1.10.0-2)
[2022-07-31T01:49:39+0300] [ALPM] installed libpeas (1.32.0-1)
[2022-07-30T16:25:01+0300] [ALPM] installed qt5-xcb-private-headers (5.15.5+kde+r173-1)
[2022-07-30T16:25:01+0300] [ALPM] reinstalled qt5-base (5.15.5+kde+r173-1)
[2022-07-30T16:25:01+0300] [ALPM] installed libidn11 (1.33-2)
[2022-07-30T16:25:01+0300] [ALPM] installed libcurl-gnutls (7.84.0-2)
[2022-07-30T16:21:54+0300] [ALPM] reinstalled base (3-2)
[2022-07-30T16:21:54+0300] [ALPM] upgraded zsh-completions (0.33.0-1 -> 0.34.0-1)
[2022-07-30T16:21:54+0300] [ALPM] upgraded vlc (3.0.17.4-6 -> 3.0.17.4-7)
[2022-07-30T16:21:54+0300] [ALPM] upgraded virtualbox-sdk (6.1.34-4 -> 6.1.36-1)
[2022-07-30T16:21:54+0300] [ALPM] upgraded virtualbox-guest-iso (6.1.34-1 -> 6.1.36-1)
[2022-07-30T16:21:53+0300] [ALPM] upgraded virtualbox-ext-vnc (6.1.34-4 -> 6.1.36-1)
[2022-07-30T16:21:53+0300] [ALPM] upgraded virtualbox (6.1.34-4 -> 6.1.36-1)
[2022-07-30T16:21:53+0300] [ALPM] upgraded timeshift (22.06.4-1 -> 22.06.5-1)
[2022-07-30T16:21:53+0300] [ALPM] upgraded xapp (2.2.13-1 -> 2.2.14-1)
[2022-07-30T16:21:53+0300] [ALPM] upgraded systemsettings (5.24.6-1 -> 5.24.6-3)
[2022-07-30T16:21:53+0300] [ALPM] upgraded sratom (0.6.10-3 -> 0.6.12-1)
[2022-07-30T16:21:53+0300] [ALPM] upgraded sord (0.16.10-2 -> 0.16.12-3)
[2022-07-30T16:21:53+0300] [ALPM] upgraded signal-desktop (5.50.1-1 -> 5.51.1-1)
[2022-07-30T16:21:52+0300] [ALPM] upgraded serd (0.30.12-2 -> 0.30.14-1)
[2022-07-30T16:21:52+0300] [ALPM] upgraded samba (4.16.3-1 -> 4.16.4-1)
[2022-07-30T16:21:52+0300] [ALPM] upgraded smbclient (4.16.3-1 -> 4.16.4-1)
[2022-07-30T16:21:52+0300] [ALPM] upgraded ruby-bundler (2.3.17-1 -> 2.3.18-1)
[2022-07-30T16:21:52+0300] [ALPM] upgraded qt5-wayland (5.15.5+kde+r38-1 -> 5.15.5+kde+r38-3)
[2022-07-30T16:21:52+0300] [ALPM] upgraded qt5-svg (5.15.5+kde+r10-1 -> 5.15.5+kde+r11-1)
[2022-07-30T16:21:52+0300] [ALPM] upgraded python-uritemplate (3.0.1-6 -> 4.1.1-1)
[2022-07-30T16:21:52+0300] [ALPM] upgraded python-rsa (4.8-3 -> 4.9-1)
[2022-07-30T16:21:52+0300] [ALPM] upgraded python-pip (22.1.2-1 -> 22.2-1)
[2022-07-30T16:21:52+0300] [ALPM] upgraded python-trove-classifiers (2022.6.26-1 -> 2022.7.22-1)
[2022-07-30T16:21:52+0300] [ALPM] upgraded python-numpy (1.23.0-1 -> 1.23.1-1)
[2022-07-30T16:21:52+0300] [ALPM] upgraded python-googleapis-common-protos (1.56.2-1 -> 1.56.3-1)
[2022-07-30T16:21:52+0300] [ALPM] upgraded python-protobuf (21.2-1 -> 21.4-1)
[2022-07-30T16:21:52+0300] [ALPM] upgraded prison (5.96.0-1 -> 5.96.0-2)
[2022-07-30T16:21:52+0300] [ALPM] upgraded qt5-base (5.15.5+kde+r170-1 -> 5.15.5+kde+r173-1)
[2022-07-30T16:21:51+0300] [ALPM] upgraded ostree (2022.4-1 -> 2022.5-1)
[2022-07-30T16:21:51+0300] [ALPM] upgraded openjdk-src (18.0.1.1.u2-1 -> 18.0.2.u9-1)
[2022-07-30T16:21:51+0300] [ALPM] upgraded openjdk-doc (18.0.1.1.u2-1 -> 18.0.2.u9-1)
[2022-07-30T16:21:50+0300] [ALPM] upgraded npm (8.14.0-1 -> 8.15.1-1)
[2022-07-30T16:21:50+0300] [ALPM] upgraded modemmanager (1.18.10-1 -> 1.18.10-2)
[2022-07-30T16:21:50+0300] [ALPM] upgraded mobile-broadband-provider-info (20220511-1 -> 20220725-1)
[2022-07-30T16:21:50+0300] [ALPM] upgraded manjaro-release (21.3.5-1 -> 21.3.6-1)
[2022-07-30T16:21:50+0300] [ALPM] upgraded lv2 (1.18.4-2 -> 1.18.6-1)
[2022-07-30T16:21:50+0300] [ALPM] upgraded logrotate (3.19.0-1 -> 3.20.1-1)
[2022-07-30T16:21:50+0300] [ALPM] upgraded llvm (14.0.6-1 -> 14.0.6-2)
[2022-07-30T16:21:41+0300] [ALPM] upgraded linux515-virtualbox-host-modules (6.1.34-24 -> 6.1.36-4)
[2022-07-30T16:21:34+0300] [ALPM] upgraded linux515-nvidia (515.57-6 -> 515.57-9)
[2022-07-30T16:21:34+0300] [ALPM] upgraded linux515-headers (5.15.55-1 -> 5.15.57-2)
[2022-07-30T16:21:33+0300] [ALPM] upgraded linux515 (5.15.55-1 -> 5.15.57-2)
[2022-07-30T16:21:32+0300] [ALPM] upgraded libvirt (1:8.5.0-2 -> 1:8.5.0-3)
[2022-07-30T16:21:31+0300] [ALPM] upgraded libvips (8.12.2-1 -> 8.13.0-1)
[2022-07-30T16:21:31+0300] [ALPM] upgraded libva-mesa-driver (22.1.3-1 -> 22.1.4-1)
[2022-07-30T16:21:31+0300] [ALPM] upgraded libuv (1.43.0-1 -> 1.44.2-1)
[2022-07-30T16:21:31+0300] [ALPM] upgraded libtorrent-rasterbar (1:2.0.6-2 -> 1:2.0.7-1)
[2022-07-30T16:21:31+0300] [ALPM] upgraded libplacebo (4.192.1-3 -> 4.208.0-1)
[2022-07-30T16:21:31+0300] [ALPM] upgraded libbpf (0.8.0-1 -> 0.8.1-1)
[2022-07-30T16:21:31+0300] [ALPM] upgraded lib32-nss (3.80-1 -> 3.81-1)
[2022-07-30T16:21:31+0300] [ALPM] upgraded lib32-mesa (22.1.3-1 -> 22.1.4-1)
[2022-07-30T16:21:31+0300] [ALPM] upgraded lib32-libva-mesa-driver (22.1.3-1 -> 22.1.4-1)
[2022-07-30T16:21:31+0300] [ALPM] upgraded lib32-llvm-libs (14.0.6-1 -> 14.0.6-2)
[2022-07-30T16:21:31+0300] [ALPM] upgraded lib32-libcap (2.64-1 -> 2.65-1)
[2022-07-30T16:21:31+0300] [ALPM] upgraded lib32-harfbuzz (4.4.1-1 -> 5.0.1-1)
[2022-07-30T16:21:31+0300] [ALPM] upgraded lib32-gcc-libs (12.1.0-2 -> 12.1.0-3)
[2022-07-30T16:21:30+0300] [ALPM] upgraded ldb (2:2.5.1-1 -> 2:2.5.2-1)
[2022-07-30T16:21:30+0300] [ALPM] upgraded jre17-openjdk (17.0.3.u7-2 -> 17.0.4.u8-2)
[2022-07-30T16:21:30+0300] [ALPM] upgraded jre17-openjdk-headless (17.0.3.u7-2 -> 17.0.4.u8-2)
[2022-07-30T16:21:30+0300] [ALPM] upgraded jdk11-openjdk (11.0.15.u10-2 -> 11.0.16.u8-2)
[2022-07-30T16:21:30+0300] [ALPM] upgraded jre11-openjdk (11.0.15.u10-2 -> 11.0.16.u8-2)
[2022-07-30T16:21:30+0300] [ALPM] upgraded jre11-openjdk-headless (11.0.15.u10-2 -> 11.0.16.u8-2)
[2022-07-30T16:21:29+0300] [ALPM] upgraded jdk-openjdk (18.0.1.1.u2-1 -> 18.0.2.u9-1)
[2022-07-30T16:21:29+0300] [ALPM] upgraded jre-openjdk (18.0.1.1.u2-1 -> 18.0.2.u9-1)
[2022-07-30T16:21:29+0300] [ALPM] upgraded jre-openjdk-headless (18.0.1.1.u2-1 -> 18.0.2.u9-1)
[2022-07-30T16:21:28+0300] [ALPM] upgraded inxi (3.3.19.1-1 -> 3.3.20.1-1)
[2022-07-30T16:21:28+0300] [ALPM] upgraded imagemagick (7.1.0.43-1 -> 7.1.0.44-1)
[2022-07-30T16:21:28+0300] [ALPM] upgraded hwloc (2.7.1-1 -> 2.8.0-1)
[2022-07-30T16:21:28+0300] [ALPM] upgraded harfbuzz-icu (4.4.1-1 -> 5.0.1-1)
[2022-07-30T16:21:28+0300] [ALPM] upgraded gegl (0.4.36-3 -> 0.4.38-1)
[2022-07-30T16:21:28+0300] [ALPM] upgraded luajit (2.1.0.beta3.r422.g4c2441c1-1 -> 2.1.0.beta3.r431.g5677985d-1)
[2022-07-30T16:21:28+0300] [ALPM] upgraded libspiro (1:20200505-2 -> 1:20220722-1)
[2022-07-30T16:21:28+0300] [ALPM] upgraded gcc (12.1.0-2 -> 12.1.0-3)
[2022-07-30T16:21:27+0300] [ALPM] upgraded fwupd (1.8.2-2 -> 1.8.3-1)
[2022-07-30T16:21:27+0300] [ALPM] upgraded protobuf (21.2-1 -> 21.4-1)
[2022-07-30T16:21:27+0300] [ALPM] upgraded libmm-glib (1.18.10-1 -> 1.18.10-2)
[2022-07-30T16:21:27+0300] [ALPM] upgraded firefox-i18n-ro (102.0.1-1 -> 103.0-1)
[2022-07-30T16:21:27+0300] [ALPM] upgraded firefox-i18n-en-us (102.0.1-1 -> 103.0-1)
[2022-07-30T16:21:27+0300] [ALPM] upgraded firefox (102.0.1-1 -> 103.0-1)
[2022-07-30T16:21:26+0300] [ALPM] upgraded lame (3.100-3 -> 3.100-4)
[2022-07-30T16:21:26+0300] [ALPM] upgraded gsm (1.0.19-1 -> 1.0.20-1)
[2022-07-30T16:21:26+0300] [ALPM] upgraded nss (3.80-1 -> 3.81-1)
[2022-07-30T16:21:26+0300] [ALPM] upgraded babl (0.1.90-2 -> 0.1.92-1)
[2022-07-30T16:21:26+0300] [ALPM] upgraded archlinux-appstream-data (20220618-1 -> 20220727-1)
[2022-07-30T16:21:26+0300] [ALPM] upgraded appstream-glib (0.7.18-3 -> 0.8.0-1)
[2022-07-30T16:21:26+0300] [ALPM] upgraded mesa (22.1.3-1 -> 22.1.4-1)
[2022-07-30T16:21:26+0300] [ALPM] upgraded harfbuzz (4.4.1-1 -> 5.0.1-1)
[2022-07-30T16:21:26+0300] [ALPM] upgraded llvm-libs (14.0.6-1 -> 14.0.6-2)
[2022-07-30T16:21:26+0300] [ALPM] upgraded iso-codes (4.10.0-1 -> 4.11.0-1)
[2022-07-30T16:21:26+0300] [ALPM] upgraded pacman (6.0.1-11 -> 6.0.1-12)
[2022-07-30T16:21:25+0300] [ALPM] upgraded ca-certificates-mozilla (3.80-1 -> 3.81-1)
[2022-07-30T16:21:25+0300] [ALPM] upgraded libcap (2.64-1 -> 2.65-1)
[2022-07-30T16:21:25+0300] [ALPM] upgraded gcc-libs (12.1.0-2 -> 12.1.0-3)
[2022-07-30T16:18:12+0300] [ALPM] upgraded manjaro-system (20220202-2 -> 20220727-1)
[2022-07-30T16:18:12+0300] [ALPM] installed base (3-2)
[2022-07-30T16:18:10+0300] [ALPM] upgraded archlinux-keyring (20220713-1 -> 20220713-2)
[2022-07-30T16:18:08+0300] [ALPM] upgraded manjaro-keyring (20220514-1 -> 20220514-2)
System info using inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.15.57-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=7cd5db68-6feb-4517-849d-790babb1108d rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Gigabyte model: Z97MX-Gaming 5 v: x.x
serial: <superuser required> UEFI: American Megatrends v: F6
date: 09/18/2015
RAM: total: 15.49 GiB used: 2 GiB (12.9%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i7-4790K bits: 64 type: MT MCP arch: Haswell
gen: core 4 built: 2013-15 process: Intel 22nm family: 6 model-id: 0x3C (60)
stepping: 3 microcode: 0x28
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3999 high: 4401 min/max: 800/4400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 4401 2: 4382 3: 4353
4: 1750 5: 4401 6: 4385 7: 3975 8: 4351 bogomips: 64033
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xsave xsaveopt xtopology xtpr
vulnerable
prctl and seccomp
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel arch: Gen-5.75 process: Intel 45nm
built: 2010 ports: active: none empty: HDMI-A-1,HDMI-A-2,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0412 class-ID: 0300
Device-2: NVIDIA GM204 [GeForce GTX 970] vendor: Gigabyte driver: nvidia
v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-07) arch: Maxwell code: GMxxx process: TSMC 28nm
built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:13c2 class-ID: 0300
Device-3: Creative Live! Cam Sync [VF0520] type: USB driver: uvcvideo
bus-ID: 3-13:3 chip-ID: 041e:406c class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa gpu: i915,nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.02x10.71")
s-diag: 554mm (21.82")
Monitor-1: DVI-I-0 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.78x10.55") diag: 547mm (21.54") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 515.57
direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
class-ID: 0403
Device-2: Intel 9 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
class-ID: 0403
Device-3: NVIDIA GM204 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
Sound Server-1: ALSA v: k5.15.57-2-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 16.1 running: yes
Sound Server-5: PipeWire v: 0.3.56 running: yes
Device-1: Qualcomm Atheros Killer E220x Gigabit Ethernet vendor: Gigabyte
driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 03:00.0 chip-ID: 1969:e091 class-ID: 0200
IP v6: <filter> type: noprefixroute scope: global
Local Storage: total: 2.73 TiB used: 1.06 TiB (39.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus
2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
temp: 41.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1ER162
type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSB0 rev: LM01
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 631.96 GiB (34.5%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 7cd5db68-6feb-4517-849d-790babb1108d
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 288 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
uuid: 05BD-8023
ID-3: /run/media/icefinity/bf32eda9-2890-43cf-bfc2-4b66de5a2710
raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 457.05 GiB (49.9%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: bf32eda9-2890-43cf-bfc2-4b66de5a2710
ID-1: /dev/sda1 maj-min: 8:1 size: 300 MiB fs: vfat label: NO_LABEL
uuid: 55A8-D0CA
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel ports: 6 rev: 2.0 speed: 480 Mb/s
chip-ID: 8087:8009 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s
chip-ID: 8087:8001 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 3-5:2 info: SiGma Micro XM102K Optical Wheel Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 1c4f:0034 class-ID: 0301
Device-2: 3-13:3 info: Creative Live! Cam Sync [VF0520] type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 100mA
Hub-6: 4-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 41.0 C mobo: N/A gpu: nvidia temp: 36 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 49%
Processes: 242 Uptime: 12m wakeups: 0 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6
Packages: 1646 pacman: 1637 lib: 412 flatpak: 9 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.20
