Hi all,
I have spent some time looking up commands to try and find which USB port is the offending USB port that holds up every shutdown or reboot for several minutes. When I run various commands no USB devices seem to match the usb6-port3 which it claims is faulty and cannot enable. No idea why it wants to enable when the system is shutting down but anyway. I have tried running a few commands but I will post the closest results below.
So what I want is to either find and fix the offending hub or disable it so I no longer get this error holding up shutdown/reboot.
lsusb:
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
find /dev/bus:
/dev/bus/usb/006
/dev/bus/usb/006/001
find /sys/bus/usb/devices/usb*/ -name dev:
/sys/bus/usb/devices/usb6/dev
susb -D /dev/bus/usb/006/001:
Device: ID 1d6b:0003 Linux Foundation 3.0 root hub
Couldn’t open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 3
bMaxPacketSize0 9
idVendor 0x1d6b Linux Foundation
idProduct 0x0003 3.0 root hub
bcdDevice 5.04
iManufacturer 3
iProduct 2
iSerial 1
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x001f
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:the closest results below.
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
bMaxBurst 0
