Absolutely all working so nice by my own, fantastic stability and strongly fiability in all kind of usage…but the total infinite perfection not being from this world there will always be a little thing to disturb the Nirvana open door
Mine is while the Manjaro boot is one of the fasted (really! whow!!) i never seen his shutdown so paradoxly the worsted, really !!
Real problem here becoming an urgent issue to fix
And it’s always mutating even worse and worse with the timelaps going on:
after install a “stopping job” was taking 1mn 29s to stop, about ~ 2min to shutdown, ok no problem with that at this point (sorry for the bad image quality)
after about 15 or 20 shutdown later this stopping job suddenly jumped to a second/same “stopping job” process, i mean after 1mn 29 it’s re-begin to countdown to 4min 30s
after about 15 or 20 shutdown more later those two additionned process gave birth to a third/same process during 6min
I mean 1m29s + 4min30s + 6min = 12mn to shutdown !!!
What the ■■■■ ???
But it’s not finished, a new step has suddenly rised up, since two shut ago now after the end of the third repetition a long line code is repeating into infinite every 30s, i have no choice to shutdown by hand “comme un bourrin”, happily all goes totally right next boot, Ctrl+Alt+Suppr or Ctrl+Alt+Tab nothing effect, Ctrl+Alt+Fn to try a tty nothing effect
The logs don’t speaking to me, just ten miles long of code reserved to the engineers developpers and programmers, it’s nothing but like reading Cambodgian or Chineese alphabet to me
So what the hell can be this “stopping job” during the eternity clock in hand?
> Are there any external drives, network shares or non linux filesystems mounted in your system while shutdown?
Yep, an external 2To USB drive to make commun sharing files between my dual boot Manjaro/Feren-OS, no network shared and absolutely any Windows signature anywhere once the exception of GP7.exe played on Playonlinux but nothing to do with this issue
… but perhaps to someone else here in the forum. So if you think the logs you mention point to the issue feel free to show us.
tried to test a shutdown after umount my external USB drive, when umount it get a message “do you want to free your trash before action”, sad i not get the reflexe to screengrab that advertissement just to show…in the doubt i answerd NO and rebooted → impossible have finished by hand
restart and retry a shutdown in the same configuration to answer YES…and a really progress here i’m back in the only 1mn29s process
So i still don’t know what my external USB drive have to do with my trash folder contents
I even less understant what my trash folder has to do with the shuting down process
But obviously it has somewhere to do ??
