So recently when attempting to shutdown my system its been taking forever, giving these errors.
It took over 10 mins for it to give me this and didn’t seem to be getting anywhere. This problem just started last night and i don’t know what changed for it to start doing this.
System: Kernel: 5.11.6-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: Xfce 4.16.0 tk: Gtk 3.24.24
info: xfce4-panel wm: xfwm4 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME X470-PRO v: Rev X.0x serial: <filter> BIOS: American Megatrends v: 5809
date: 12/03/2020
Memory: RAM: total: 31.33 GiB used: 3.39 GiB (10.8%)
CPU: Info: 12-Core model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 rev: 0 cache: L2: 6 MiB bogomips: 182135
Speed: 2760 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz): 1: 2760 2: 3592 3: 3596 4: 3500 5: 3593
6: 3592 7: 2052 8: 2118 9: 2145 10: 3818 11: 2195 12: 2577 13: 2050 14: 2190 15: 2122 16: 3469 17: 4342 18: 2051
19: 2108 20: 3685 21: 2195 22: 2380 23: 2196 24: 2115
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht
hw_pstate ibpb ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev
sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall
tce topoext tsc tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Graphics: Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: Micro-Star MSI driver: nvidia v: 460.56 bus-ID: 09:00.0
chip-ID: 10de:1f06 class-ID: 0300
Display: x11 server: X.Org 1.20.10 driver: loaded: nvidia resolution: 1: 3840x2160~60Hz 2: 3840x2160~60Hz
s-dpi: 162
OpenGL: renderer: GeForce RTX 2060 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56 direct render: Yes
Audio: Device-1: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 09:00.1
chip-ID: 10de:10f9 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Corsair HS60 Surround Adapter type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 7-3:3
chip-ID: 1b1c:0a3b class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.11.6-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: no
Network: Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel port: e000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter driver: ath9k v: kernel port: d000 bus-ID: 0a:00.0
chip-ID: 168c:0030 class-ID: 0280
IF: wlp10s0 state: up mac: <filter>
Bluetooth: Message: No Bluetooth data was found.
Logical: Message: No LVM data was found.
RAID: Message: No RAID data was found.
Drives: Local Storage: total: 2.76 TiB used: 1.24 TiB (45.0%)
ID-1: /dev/nvme0n1 model: PCIe SSD size: 953.87 GiB speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: EDFM00.5 temp: 30.9 C scheme: MBR
ID-2: /dev/sda vendor: HGST (Hitachi) model: HTS725050A7E630 size: 465.76 GiB speed: 6.0 Gb/s rotation: 7200 rpm
serial: <filter> rev: A420 scheme: MBR
ID-3: /dev/sdb vendor: Samsung model: SSD 850 PRO 512GB size: 476.94 GiB speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: 3B6Q scheme: GPT
ID-4: /dev/sdc vendor: Western Digital model: WD10SPZX-11Z10T0 size: 931.51 GiB speed: 6.0 Gb/s rotation: 5400 rpm
serial: <filter> rev: 1A01 scheme: GPT
Partition: ID-1: / size: 937.82 GiB used: 437.75 GiB (46.7%) fs: ext4 dev: /dev/nvme0n1p1 label: N/A
uuid: 6720cb34-e3f6-4ac7-bfd6-1b0dd0759313
ID-2: /run/timeshift/backup size: 915.89 GiB used: 833.92 GiB (91.0%) fs: ext4 dev: /dev/sdc1 label: Linux Hdd
uuid: c3a55342-93f7-44a9-9190-4f0bd293e2e9
Swap: Alert: No Swap data was found.
Unmounted: ID-1: /dev/sda1 size: 465.76 GiB fs: ntfs label: N/A uuid: E8443B35443B05BA
ID-2: /dev/sdb1 size: 450 MiB fs: ntfs label: Recovery uuid: F6F24A95F24A59CF
ID-3: /dev/sdb2 size: 100 MiB fs: vfat label: N/A uuid: 704A-EF1D
ID-4: /dev/sdb3 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
ID-5: /dev/sdb4 size: 475.88 GiB fs: ntfs label: N/A uuid: B4A24CD5A24C9DAC
ID-6: /dev/sdb5 size: 516 MiB fs: ntfs label: N/A uuid: DE346138346114B5
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 1-3:2 info: Silicon Motion - Taiwan (formerly Feiya ) Flash Drive type: Mass Storage driver: usb-storage
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 300mA chip-ID: 090c:1000 class-ID: 0806 serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 3-2:2 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID driver: hid-generic,usbhid interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 300mA chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-7: 7-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-8: 7-2:2 info: Unknown Manufacturer hub ports: 4 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0a05:7211
Device-1: 7-2.1:4 info: SHARKOON [Mediatrack Edge Mini Keyboard] type: Keyboard,Mouse driver: hid-generic,usbhid
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 1ea7:0066 class-ID: 0301
Device-2: 7-3:3 info: Corsair HS60 Surround Adapter type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid
interfaces: 4 rev: 1.1 speed: 12 Mb/s power: 500mA chip-ID: 1b1c:0a3b class-ID: 0300 serial: <filter>
Hub-9: 8-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Sensors: System Temperatures: cpu: 53.0 C mobo: N/A gpu: nvidia temp: 47 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 17%
Info: Processes: 425 Uptime: 6h 36m wakeups: 0 Init: systemd v: 247 Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1218
pacman: 1215 snap: 3 Shell: Bash v: 5.1.0 running-in: terminator inxi: 3.3.03
