Shutdown command from xfce panel fails
The normal means for shutting down by using panel action button/Shutdown or application menu/Logout/Shutdown fail without any entry in journal, although the usual 30 second message is displayed.
Shutting down using poff (alias poff='sudo poweroff') from terminal does work.
xfce 4.14 but also occurred with earlier release
Update: since this is a remote (off site) system using the normal means for shutting down avoids a huge inconvenience.
In any case, have a standard feature of the Desktop environment not work can portend other problems.
have you tried
sudo systemctl poweroff
systemctl poweroff
I never use "sudo"
XFCE bug filed: 15850
https://bugzilla.xfce.org/show_bug.cgi?id=15850
Shutdown panel plugin works. The bug is something particular to your system.
I don't know why you don't mention the resolution of the bug report.
Apparently XFCE will not shutdown or suspend while Mythtv client is running.
