Hi everyone. Hope life is treating you well…
I’m getting long shutdown and restart times. It wasn’t always like this and use to be faster.
❯ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=324638ed-d935-42fa-9251-4bbc18fbaebf ro quiet apparmor=1
security=apparmor resume=UUID=4ae6e0ca-52e6-4d07-b210-d38df577c23d
udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: MSI product: MS-7922 v: 2.0 serial: <filter>
Mobo: MSI model: Z97S SLI Krait Edition (MS-7922) v: 2.0 serial: <filter>
UEFI: American Megatrends v: 10.7 date: 02/16/2016
Device-1: hid-98:5a:eb:bf:ae:bd-battery model: Ricky C’s Keyboard
serial: N/A charge: N/A status: Discharging
Device-2: hidpp_battery_0 model: Logitech Wireless Mouse M325
status: Discharging
RAM: total: 15.58 GiB used: 5.04 GiB (32.4%)
Info: Quad Core model: Intel Core i5-4690K bits: 64 type: MCP arch: Haswell
family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache: L2: 6 MiB
bogomips: 28008
Speed: 4000 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 4000 2: 4000
3: 4000 4: 4000
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb
pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
Type: l1tf
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: ASUSTeK driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1401 class-ID: 0300
Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x292mm (20.6x11.5")
s-diag: 600mm (23.6")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.5x11.5")
diag: 598mm (23.5")
OpenGL: renderer: NVIDIA GeForce GTX 960/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
direct render: Yes
Device-1: Intel 9 Series Family HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
class-ID: 0403
Device-2: NVIDIA GM206 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fba
class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-030a54b41084 state: down mac: <filter>
IF-ID-2: br-6978431ae62c state: down mac: <filter>
IF-ID-3: br-8bec24f9e8f9 state: down mac: <filter>
IF-ID-4: br-904e6f6f3517 state: down mac: <filter>
IF-ID-5: br-97c02913e7d7 state: down mac: <filter>
IF-ID-6: br-af1331942708 state: down mac: <filter>
IF-ID-7: br-e3ce9afd929d state: down mac: <filter>
IF-ID-8: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IP v6: <filter> scope: link
IF-ID-9: vethf259f28 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-10: virbr0 state: down mac: <filter>
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 3-6:3 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
Local Storage: total: 2.49 TiB used: 1.41 TiB (56.6%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000BEKT-00KA9T0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: B1D2 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
model: WD My Passport 0820 size: 931.48 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1007 scheme: MBR
Optical-1: /dev/sr0 vendor: ASUS DVD model: RAM GH95N rev: AS00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 150 GiB size: 146.65 GiB (97.76%) used: 76.68 GiB (52.3%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: Root
uuid: 324638ed-d935-42fa-9251-4bbc18fbaebf
ID-2: /boot/efi raw-size: 5.5 GiB size: 5.49 GiB (99.80%)
used: 312 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: B620-9F81
ID-3: /extra raw-size: 400.01 GiB size: 392.73 GiB (98.18%)
used: 290.76 GiB (74.0%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: Extra uuid: 10c8746e-ef2e-48ed-a054-3a35bf984320
ID-4: /home raw-size: 360 GiB size: 353.35 GiB (98.15%)
used: 102.99 GiB (29.1%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: Home uuid: 2267d406-2fe1-433e-a9da-dc6952d4ab54
ID-5: /wd raw-size: 465.76 GiB size: 457.45 GiB (98.22%)
used: 296.86 GiB (64.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: WD
uuid: bb0e0a16-91ee-44e0-8e7e-d9d21afa60a8
ID-6: /wdusb raw-size: 931.48 GiB size: 915.86 GiB (98.32%)
used: 677.66 GiB (74.0%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: WDusb
uuid: 841a94ff-6090-46f7-9e96-9172f21cd30b
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 16 GiB used: 256 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 4ae6e0ca-52e6-4d07-b210-d38df577c23d
ID-1: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: vfat label: N/A
uuid: 1099-ADA2
ID-2: /dev/sdb2 maj-min: 8:18 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sdb3 maj-min: 8:19 size: 222.97 GiB fs: ntfs label: Win10
uuid: 1278AB1378AAF51F
ID-4: /dev/sdb4 maj-min: 8:20 size: 499 MiB fs: ntfs label: N/A
uuid: 90A847FEA847E0F8
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel ports: 6 rev: 2.0 speed: 480 Mb/s
chip-ID: 8087:8009 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s
chip-ID: 8087:8001 class-ID: 0900
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0
Device-1: 3-5:2 info: digital-X type: Keyboard,Mouse
power: 100mA chip-ID: 0513:0318 class-ID: 0301
Device-2: 3-6:3 info: Broadcom BCM20702A0 Bluetooth 4.0 type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:21e8
Hub-6: 3-8:4 info: Apple Keyboard Hub ports: 3 rev: 2.0 speed: 480 Mb/s
power: 300mA chip-ID: 05ac:1005 class-ID: 0900
Device-1: 3-8.2:6 info: Apple Aluminum Mini Keyboard (ANSI)
type: Keyboard,HID driver: apple,usbhid interfaces: 2 rev: 2.0
speed: 1.5 Mb/s power: 20mA chip-ID: 05ac:021d class-ID: 0300
Hub-7: 3-10:5 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2813 class-ID: 0900
Device-1: 3-11:7 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
Device-1: 4-3:2 info: Western Digital My Passport Ultra (WDBMWV WDBZFP)
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 896mA chip-ID: 1058:0820 class-ID: 0806 serial: <filter>
Hub-9: 4-4:3 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 2109:0813 class-ID: 0900
Device-1: 4-4.2:4 info: Genesys Logic SD Card Reader and Writer
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s
power: 896mA chip-ID: 05e3:0749 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 36.5 C mobo: 32.0 C gpu: nvidia temp: 50 C
Fan Speeds (RPM): cpu: 850 mobo: 5869 fan-1: 0 fan-3: 811 fan-4: 755 fan-5:
gpu: nvidia fan: 15%
Processes: 261 Uptime: 5m wakeups: 4 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 alt: 10 clang: 12.0.1 Packages: 1836 pacman: 1826
lib: 461 flatpak: 10 Shell: Zsh v: 5.8 running-in: yakuake inxi: 3.3.06
Here’s my journalctl -b -1
output but, I’m not really sure what to be looking for:
Per some other posts on the topic, I tried nowatchdog zswap.enabled=0 audit=0
but, that didn’t seem to help (not sure if it would have mattered, either way.)
Any direction would be appreciated, thanks!
