Shutdown[1]: Failed to wait for process: Protocol error
#62
@xabbu: can you update the issue so upstream can work on a fix?
#63
Well I’ve just started getting this shutting down errors on Arch testing the last few days I don’t have encryption, running systemd 238.0.1 kernel 4.15.10-1 if that’s any help
[Stable Update] 2018-03-27 - Kernels, Krita, Grub, Deepin, Pamac, Pacman-Mirrors, Firefox
[Testing Update] 2018-03-23 - Kernels, Krita v4.0, F2FS support for Grub, Systemd, Deepin
#64
@sueridgepipe can you try this workaround on your system too?
add to your mounts in fstab the option x-systemd.requires=systemd-cryptsetup@XX.service
Replace the XX with the name you used in your crypttab for this LUKS device.
You can also look at the github issue report for a better example.
#65
Please test if we didn’t add any regressions with systemd v238.51-1
#66
No Problems with 238.51-1.1 on my systems.
#67
Can also confirm - 238.51-1.1 - is fine with me.
#68
Thx for confirming that we didn’t add any new regressions to Systemd.
