after update there are option for “manjaro linux” and “advanced options for manjaro” like before and also there are new options “manjaro linux 20.1” and “advanced options for 20.1”
the first option is useless. if I select this the system will not start. the option “manjaro linux 20.1” is the working one.
why the old useless boot option is still there?
sudo update-grub
should solve this if there is only one manjaro installation on your drive.
yes there is only one manjaro installation.
the problem is there after the new update.
Myself i have no problem. Still the same. “manjaro linux”, “advanced options for manjaro” and “EFI Firmware” is there. That’s it. Check your configs
sudo update-grub
[sudo] password for abdun:
Found linux image: /boot/vmlinuz-4.19-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.19-x86_64.img
Found initrd fallback image: /boot/initramfs-4.19-x86_64-fallback.img
Found Manjaro Linux (20.1) on /dev/sda2
done
something’s fishy
Please check lsblk
, just to keep sure there is only one installation
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 55.3M 1 loop /var/lib/snapd/snap/core18/1885
loop1 7:1 0 96.6M 1 loop /var/lib/snapd/snap/core/9804
loop2 7:2 0 62.1M 1 loop /var/lib/snapd/snap/gtk-common-themes/1506
loop3 7:3 0 29.9M 1 loop /var/lib/snapd/snap/snapd/8542
loop4 7:4 0 29.9M 1 loop /var/lib/snapd/snap/snapd/8790
loop5 7:5 0 74M 1 loop /var/lib/snapd/snap/wine-platform-3-stable/6
loop6 7:6 0 226.7M 1 loop /var/lib/snapd/snap/wine-platform-runtime/145
sda 8:0 0 931.5G 0 disk
├─sda1 8:1 0 301M 0 part /boot/efi
├─sda2 8:2 0 815.8G 0 part /run/timeshift/backup
└─sda4 8:4 0 107.1G 0 part /mnt/46F2C1A639AC7995
sr0 11:0 1 1024M 0 rom
Any way you can possible post your grub.cfg
via pastebin or the
Hide details
To use this, click the icon in the post editor and click the
details
button
option in the forum?
GRUB finds the images under /boot
and then finds another installation in /dev/sda2
. The second entry should be from timeshift. I don’t use timeshift, but I think this is normal.
here is my grub.cfg
grub.cfg
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
insmod part_gpt
insmod part_msdos
if [ -s $prefix/grubenv ]; then
load_env
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="${saved_entry}"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
set menu_color_normal=light-gray/black
set menu_color_highlight=green/black
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_gpt
insmod ext2
set root='hd0,gpt2'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-ieee1275='ieee1275//disk@0,gpt2' --hint-bios=hd0,gpt2 --hint-efi=hd0,gpt2 --hint-baremetal=ahci0,gpt2 559b919a-0ba0-4aaa-a1b9-5c1e2ad82aff
else
search --no-floppy --fs-uuid --set=root 559b919a-0ba0-4aaa-a1b9-5c1e2ad82aff
fi
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=en_US
insmod gettext
fi
terminal_input console
terminal_output gfxterm
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=hidden
set timeout=10
# Fallback hidden-timeout code in case the timeout_style feature is
# unavailable.
elif sleep --interruptible 10 ; then
set timeout=0
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'Manjaro Linux' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-559b919a-0ba0-4aaa-a1b9-5c1e2ad82aff' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
set root='hd0,gpt2'
else
fi
linux /boot/vmlinuz-4.19-x86_64 root=UUID=559b919a-0ba0-4aaa-a1b9-5c1e2ad82aff rw quiet apparmor=1 security=apparmor udev.log_priority=3 resume=/dev/disk/by-uuid/559b919a-0ba0-4aaa-a1b9-5c1e2ad82aff resume_offset=2541568
initrd /boot/intel-ucode.img /boot/initramfs-4.19-x86_64.img
submenu 'Advanced options for Manjaro Linux' $menuentry_id_option 'gnulinux-advanced-559b919a-0ba0-4aaa-a1b9-5c1e2ad82aff' {
menuentry 'Manjaro Linux (Kernel: 4.19.138-1-MANJARO x64)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.19.138-1-MANJARO x64-advanced-559b919a-0ba0-4aaa-a1b9-5c1e2ad82aff' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
set root='hd0,gpt2'
else
fi
menuentry 'Manjaro Linux (Kernel: 4.19.138-1-MANJARO x64 - fallback initramfs)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.19.138-1-MANJARO x64-fallback-559b919a-0ba0-4aaa-a1b9-5c1e2ad82aff' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
set root='hd0,gpt2'
else
fi
initrd /boot/initramfs-4.19-x86_64-fallback.img
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Manjaro Linux (20.1) (on /dev/sda2)' --class manjarolinux --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-559b919a-0ba0-4aaa-a1b9-5c1e2ad82aff' {
savedefault
insmod part_gpt
insmod ext2
set root='hd0,gpt2'
else
fi
submenu 'Advanced options for Manjaro Linux (20.1) (on /dev/sda2)' $menuentry_id_option 'osprober-gnulinux-advanced-559b919a-0ba0-4aaa-a1b9-5c1e2ad82aff' {
menuentry 'Manjaro Linux (on /dev/sda2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.19-x86_64--559b919a-0ba0-4aaa-a1b9-5c1e2ad82aff' {
savedefault
insmod part_gpt
insmod ext2
set root='hd0,gpt2'
else
fi
menuentry 'Manjaro Linux (Kernel 4.19.138-1-MANJARO x64) (on /dev/sda2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.19-x86_64--559b919a-0ba0-4aaa-a1b9-5c1e2ad82aff' {
savedefault
insmod part_gpt
insmod ext2
set root='hd0,gpt2'
else
fi
menuentry 'Manjaro Linux (Kernel 4.19.138-1-MANJARO x64 - fallback initramfs) (on /dev/sda2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.19-x86_64--559b919a-0ba0-4aaa-a1b9-5c1e2ad82aff' {
savedefault
insmod part_gpt
insmod ext2
set root='hd0,gpt2'
else
fi
menuentry 'Memory Tester (memtest86+) (on /dev/sda2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/memtest86+/memtest.bin--559b919a-0ba0-4aaa-a1b9-5c1e2ad82aff' {
savedefault
insmod part_gpt
insmod ext2
set root='hd0,gpt2'
else
fi
linux /boot/memtest86+/memtest.bin
set timeout_style=menu
if [ "${timeout}" = 0 ]; then
set timeout=10
fi
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
menuentry 'UEFI Firmware Settings' $menuentry_id_option 'uefi-firmware' {
fwsetup
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
### BEGIN /etc/grub.d/60_memtest86+ ###
if [ "${grub_platform}" == "pc" ]; then
menuentry "Memory Tester (memtest86+)" --class memtest86 --class gnu --class tool {
search --fs-uuid --no-floppy --set=root --hint-ieee1275='ieee1275//disk@0,gpt2' --hint-bios=hd0,gpt2 --hint-efi=hd0,gpt2 --hint-baremetal=ahci0,gpt2 559b919a-0ba0-4aaa-a1b9-5c1e2ad82aff
linux16 /boot/memtest86+/memtest.bin
fi
### END /etc/grub.d/60_memtest86+ ###
yes.
And I, also think that this was caused by timeshift. when the update was running, a Timeshift Backup was also running.
I’ve deleted all Timeshift Snapshots and /run/timeshift folder also.
Still the extra boot option is there.
But why? if you don’t want timeshift uninstall it and remove the partition. Then update GRUB and the entry will be gone.
there is no separate partition for timeshift. It is the system partition where timeshift stores backups in a folder. and don’t want to remove timeshift. I was using it also before the update. And the extra boot entry was not there before the update. and also the menu was invisible untill I press shift.
It is a partition for timeshift backups. That’s what I meant.
Maybe there’s an hook for backup before updating and this is the first time it was triggered?
This can be triggered with some option /etc/default/grub
There’s also another way to set it through the command line, but, honestly, I don’t remember how. It shouldn’t be hard to find it out though.
I had the same Problem.
Reason: Machine with only one Operatingsystem!
Go to " /etc/default/grub/ " (sudo required!)
and change entry to: GRUB_DISABLE_OS_PROBER=true
I didn’t understand
umm… I think this problem was not my fault?
/etc/default/grub/
grub
GRUB_DEFAULT=saved
GRUB_TIMEOUT=10
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3 resume=/dev/disk/by-uuid/559b919a-0ba0-4aaa-a1b9-5c1e2ad82aff resume_offset=2541568"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
#GRUB_THEME="/path/to/gfxtheme"
#GRUB_INIT_TUNE="480 440 1"
Please edit your post and enclose terminal output within three backticks or use the button </>
Test this (after saving file: sudo update grub)
GRUB
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
# GRUB_TIMEOUT_STYLE=hidden
GRUB_GFXMODE=auto
He needs to sudo update-grub
first. @Alif sorry if this is obvious to you, but I don’t know if you’re aware of that.
