Would the following be considered?
- ID=manjaro-arm
- ID_LIKE=manjaro arch
+ ID="manjaro-arm"
+ ID_LIKE="manjaro arch"
I symbolically link /etc/os-release to /usr/lib/os-release as I use systemd in my initramfs, which seems to use this file. I am also testing the use of dracut, and during the creation of the initramfs, it produces the following error:
dracut: *** Including module: base ***
/etc/os-release: line 3: arch: command not found
If I make a “/usr/bin/arch”, it will execute it. So while I can work around it, it is not a desired or expected result.
Edit: This is actually a fairly bad bug in dracut. Since it turns this non-executable file into an executable one, due to a syntax error.
Edit 2: I opened a bug report with dracut.
