Should i disable these Kernel messages?
Hi,
Journalctl telles me;
Nov 04 00:48:58 manjaro kernel: INFO: task kworker/5:2:95545 blocked for more than 860 seconds.
Nov 04 00:48:58 manjaro kernel:       Tainted: P           OE     5.10.70-1-MANJARO #1
Nov 04 00:48:58 manjaro kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Nov 04 00:48:58 manjaro kernel: task:kworker/5:2     state:D stack:    0 pid:95545 ppid:     2 flags:0x00004080
Nov 04 00:48:58 manjaro kernel: Workqueue: events rtl_work_func_t [r8152]
Nov 04 00:48:58 manjaro kernel: Call Trace:
Nov 04 00:48:58 manjaro kernel:  __schedule+0x288/0x800
Nov 04 00:48:58 manjaro kernel:  schedule+0x5b/0xc0
Nov 04 00:48:58 manjaro kernel:  rpm_resume+0x160/0x7d0
Nov 04 00:48:58 manjaro kernel:  ? add_wait_queue_exclusive+0x70/0x70
Nov 04 00:48:58 manjaro kernel:  rpm_resume+0x2e1/0x7d0
Nov 04 00:48:58 manjaro kernel:  ? dequeue_entity+0xc3/0x460
Nov 04 00:48:58 manjaro kernel:  ? newidle_balance+0xe1/0x3f0
Nov 04 00:48:58 manjaro kernel:  __pm_runtime_resume+0x3b/0x60
Nov 04 00:48:58 manjaro kernel:  usb_autopm_get_interface+0x18/0x40
Nov 04 00:48:58 manjaro kernel:  rtl_work_func_t+0x69/0x2d0 [r8152]
Nov 04 00:48:58 manjaro kernel:  ? __schedule+0x290/0x800
Nov 04 00:48:58 manjaro kernel:  process_one_work+0x1ad/0x370
Nov 04 00:48:58 manjaro kernel:  worker_thread+0x50/0x3b0
Nov 04 00:48:58 manjaro kernel:  ? rescuer_thread+0x380/0x380
Nov 04 00:48:58 manjaro kernel:  kthread+0x133/0x150
Nov 04 00:48:58 manjaro kernel:  ? kthread_associate_blkcg+0xc0/0xc0
Nov 04 00:48:58 manjaro kernel:  ret_from_fork+0x1f/0x30
A) What is happening with kworker?
B) Should i disable these messages?
Generated on 2021-09-30 11:51:1632995497
#################### inxi -Fxzc0 ########################
System:    Kernel: 5.10.68-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: Xfce 4.16.0
Machine:   Type: Laptop System: LENOVO product: 81RS v: Lenovo Yoga S740-14IIL serial: <filter>
           Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter> UEFI: LENOVO
           v: BYCN38WW date: 12/10/2020
Battery:   ID-1: BAT0 charge: 61.8 Wh (94.6%) condition: 65.3/62.0 Wh (105.3%) volts: 17.0
           min: 15.4 model: LGC L19L4PD2 status: Unknown
CPU:       Info: Quad Core model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake rev: 5
           cache: L2: 8 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23968
           Speed: 1200 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 1200 2: 1201 3: 1200
           4: 1200 5: 1201 6: 1202 7: 1201 8: 1200
Graphics:  Device-1: Intel Iris Plus Graphics G7 vendor: Lenovo driver: i915 v: kernel
           bus-ID: 00:02.0
           Device-2: NVIDIA GP108M [GeForce MX250] vendor: Lenovo driver: nvidia v: 470.63.01
           bus-ID: 2b:00.0
           Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 3-5:4
           Display: x11 server: X.Org 1.20.13 driver: loaded: modesetting,nvidia unloaded: nouveau
           resolution: 1: 1680x1050~60Hz 2: 1680x1050~60Hz
Audio:     Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo driver: sof-audio-pci
           bus-ID: 00:1f.3
           Sound Server-1: ALSA v: k5.10.68-1-MANJARO running: yes
           Sound Server-3: JACK v: 1.9.19 running: no
           Sound Server-4: PulseAudio v: 15.0 running: yes
Network:   Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel port: 4000
           bus-ID: 00:14.3
           IF: wlp0s20f3 state: down mac: <filter>
           Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
           bus-ID: 3-1:2
           IF: enp0s20f0u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
           IF-ID-1: pan1 state: down mac: <filter>
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:6
           Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Drives:    Local Storage: total: 1.86 TiB used: 364.15 GiB (19.1%)
           ID-1: /dev/nvme0n1 vendor: Micron model: MTFDHBA1T0TCK size: 953.87 GiB temp: 38.9 C
           ID-2: /dev/sda type: USB vendor: Western Digital model: WD10EARX-00N0YB0
           ID-3: /dev/sdb type: USB vendor: Kingston model: DataTraveler 2.0 size: 14.54 GiB
           ID-4: /dev/sdc type: USB model: Kindle Internal Storage size: 2.77 GiB
Partition: ID-1: / size: 57.9 GiB used: 34.27 GiB (59.2%) fs: ext4 dev: /dev/nvme0n1p8
           ID-2: /boot/efi size: 259.5 MiB used: 105.5 MiB (40.7%) fs: vfat dev: /dev/nvme0n1p1
Swap:      ID-1: swap-1 type: partition size: 16.67 GiB used: 4.5 MiB (0.0%) dev: /dev/nvme0n1p9
Sensors:   System Temperatures: cpu: 48.0 C mobo: N/A
Info:      Processes: 276 Uptime: 1d 15h 31m Memory: 15.2 GiB used: 1.99 GiB (13.1%) Init: systemd
           Compilers: gcc: 11.1.0 Packages: 1744 Client: Unknown Client: wrapper-2.0 inxi: 3.3.06
Thanks for your advice :slight_smile:
The problem is this:
Disabling it will probably only hide the from, not solve it. The problem appears to be related to the r8152 kernel module and/or usb.
