Before
After:
Since last two weeks my shell has encountered the error in the Before picture above. After every reboot the main activities windows won’t ever load. It only corrects itself after I either:
From the activities screen, type to search for something.
Changing the layout in manjaro-layout
Reloading the Desktop.
This bug is not very big. Only a bit annoying. How should I fix this? Please help. Thank you.
Current shell settings from Neofetch. For shell extensions, disabling all extensions did not help. Bug persists after reboot.
Kernel: 5.15.41-1-MANJARO
Shell: zsh 5.9
Resolution: 1920x1080
DE: GNOME 42.1
WM: Mutter
WM Theme: Nordic-bluish-accent-v40
Theme: Nordic-bluish-accent-v40 [GTK2/3]
Icons: Tela-circle-dark [GTK2/3]
Terminal: gnome-terminal
CPU: AMD Ryzen 5 4500U with Radeon Graphics (6) @ 2.375GHz
GPU: AMD ATI 03:00.0 Renoir
Memory: 3204MiB / 7427MiB
