Hi all,
I have a strange behavior of a script, ftest.sh.
If I run it directly from a root-account, it does, what it should do.
sh /etc/shellscripte/fotos/fotos/ftest.sh > /home/xy/ftest.log
If I run it via crontab (cronie) it does nothing.
36 17 * * * root sh /etc/shellscripte/fotos/fotos/ftest.sh > /home/xy/fotos.log
The content of the script ftest.sh is
exiftool -charset utf-8 -csv -m -fast -r -ext jpg -c %.6f -Filename -Directory -CreateDate -XResolution -YResolution -exif:gpslatitude -exif:gpslongitude -xmp:Description -ImageWidth -ImageHeight /home/bilder/dir001 /home/bilder/dir002 /home/bilder/dir003 /home/bilder/dir004 /home/bilder/dir005 /home/bilder/dir006 /home/bilder/dir007 /home/bilder/dir008 /home/bilder/dir009 > ./allefotos.csv
Could anybody give me a hint, what could be the difference between the execution between the shell and via crontab?
Regards
CJC
cjean
6 April 2021 16:36
2
First, this command sends its output to the home directory of the xy
user.
Then,
sends (or tries to send) the output to the /~xy
directory which may not exist. The commands probably fails silently.
I would therefore explicitly write /home/xy/fotos.log
if it is indeed where it is expected to save the output.
Yes… those were typos… I have corrected them.
xabbu
6 April 2021 17:08
4
Did you checked if cornie is actually running?
systemctl status cronie
Did you see something in the journal?
sudo journalctl -u cronie --no-hostname --no-pager
Thankyou.
Apr 06 17:36:01 CROND[1654013]: (root) CMD ( sh /etc/shellscripte/fotos/fotos/ftest.sh > /home/xy/fotos.log) Apr 06 17:36:01 CROND[1654011]: (root) CMDOUT (/etc/shellscripte/fotos/fotos/ftest.sh: Zeile 1 exiftool: command not found.)
That is strange: I can start exiftool from bash. Is with cronie another path configured?
cjean
6 April 2021 17:59
6
Yes, by default, the PATH in crontab in minimal. Better put the full path in front of your command.
xabbu
6 April 2021 18:05
7
It should be just /usr/bin:/bin
system
Closed
22 April 2021 16:29
9
