Hello,
I have several issue with my laptop running Manjaro KDE :
bluetooth sometimes disconnects, i have to reboot to make it work
unable to wakeup after suspend on RAM (no swap)
My hardware info :
System: Kernel: 5.11.1-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=80b2aca5-4bd7-420a-bcaf-66d8c913e258 ro quiet apparmor=1
Desktop: KDE Plasma 5.21.1 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 82A2 v: Yoga Slim 7 14ARE05 serial: Chassis: type: 10
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: UEFI: LENOVO v: DMCN38WW date: 01/18/2020
Battery: ID-1: BAT1 charge: 26.3 Wh condition: 60.7/60.7 Wh (100%) volts: 15.3/15.4 model: Celxpert L19C4PF4 type: Li-poly
serial: status: Discharging cycles: 9
CPU: Info: 8-Core model: AMD Ryzen 7 4800U with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 family: 17 (23)
model-id: 60 (96) stepping: 1 microcode: 8600106 L2 cache: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 57519
Speed: 1397 MHz min/max: 1400/1800 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 1396 3: 1374 4: 1397 5: 1397
6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397 12: 1397 13: 1397 14: 1397 15: 1397 16: 1397
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Renoir vendor: Lenovo driver: amdgpu v: kernel bus ID: 03:00.0
chip ID: 1002:1636 class ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus ID: 1-4:2 chip ID: 04f2:b6cb class ID: fe01
serial:
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9") diag: 355mm (14")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.11.1-1-MANJARO LLVM 11.1.0) v: 4.6 Mesa 20.3.4 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 03:00.1
chip ID: 1002:1637 class ID: 0403
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus ID: 03:00.5 chip ID: 1022:15e2 class ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 03:00.6 chip ID: 1022:15e3 class ID: 0403
Sound Server: ALSA v: k5.11.1-1-MANJARO
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus ID: 01:00.0 chip ID: 8086:2723 class ID: 0280
IF: wlp1s0 state: up mac:
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus ID: 3-4:2 chip ID: 8087:0029 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Drives: Local Storage: total: 953.87 GiB used: 24.78 GiB (2.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HBLR-000L2 size: 953.87 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: rev: 3L1QEXF7 temp: 33.9 C
scheme: GPT
Partition: ID-1: / raw size: 74.22 GiB size: 72.55 GiB (97.76%) used: 13.21 GiB (18.2%) fs: ext4 dev: /dev/nvme0n1p5
maj-min: 259:5
ID-2: /boot/efi raw size: 260 MiB size: 256 MiB (98.46%) used: 35.4 MiB (13.8%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw size: 488.28 GiB size: 479.62 GiB (98.23%) used: 11.54 GiB (2.4%) fs: ext4 dev: /dev/nvme0n1p6
maj-min: 259:6
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 35.1 C mobo: N/A gpu: amdgpu temp: 34.0 C
Info: Processes: 319 Uptime: 13m wakeups: 1030 Memory: 15.08 GiB used: 2.04 GiB (13.5%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1289 lib: 404 flatpak: 0 Shell: Bash v: 5.1.0 running in: yakuake
inxi: 3.3.01
And here is the errors I found :
mar 03 16:48:36 MrRobot kernel: ucsi_acpi USBC000:00: PPM init failed (-110)
mar 03 17:13:22 MrRobot kernel: amdgpu: cp queue preemption time out.
mar 03 17:13:22 MrRobot kernel: amdgpu 0000:03:00.0: [drm:amdgpu_ib_ring_tests [amdgpu]] ERROR IB test failed on comp_1.0.0 (-110).
mar 03 17:13:22 MrRobot kernel: amdgpu 0000:03:00.0: [drm:amdgpu_ib_ring_tests [amdgpu]] ERROR IB test failed on comp_1.1.0 (-110).
mar 03 17:13:22 MrRobot kernel: amdgpu 0000:03:00.0: [drm:amdgpu_ib_ring_tests [amdgpu]] ERROR IB test failed on comp_1.2.0 (-110).
mar 03 17:13:22 MrRobot kernel: amdgpu 0000:03:00.0: [drm:amdgpu_ib_ring_tests [amdgpu]] ERROR IB test failed on comp_1.3.0 (-110).
mar 03 17:13:22 MrRobot kernel: amdgpu 0000:03:00.0: [drm:amdgpu_ib_ring_tests [amdgpu]] ERROR IB test failed on comp_1.0.1 (-110).
mar 03 17:13:22 MrRobot kernel: amdgpu 0000:03:00.0: [drm:amdgpu_ib_ring_tests [amdgpu]] ERROR IB test failed on comp_1.1.1 (-110).
mar 03 17:13:22 MrRobot kernel: amdgpu 0000:03:00.0: [drm:amdgpu_ib_ring_tests [amdgpu]] ERROR IB test failed on comp_1.2.1 (-110).
mar 03 17:13:22 MrRobot kernel: amdgpu 0000:03:00.0: [drm:amdgpu_ib_ring_tests [amdgpu]] ERROR IB test failed on comp_1.3.1 (-110).
mar 03 17:13:22 MrRobot kernel: [drm:process_one_work] ERROR ib ring test failed (-110).
mar 03 17:13:23 MrRobot bluetoothd[780]: profiles/input/hog-lib.c:report_value_cb() bt_uhid_send: Invalid argument (22)
mar 03 17:23:16 MrRobot systemd-coredump[8955]: Process 8949 (pipewire-media-) of user 1000 dumped core.
Stack trace of thread 8949:
#0 0x0000563c06ba603b n/a (pipewire-media-session + 0x2003b)
#1 0x0000563c06ba4a6b n/a (pipewire-media-session + 0x1ea6b)
#2 0x00007fa4bbfd5df4 n/a (libpipewire-module-protocol-native.so + 0x16df4)
#3 0x00007fa4bbfcfaa2 n/a (libpipewire-module-protocol-native.so + 0x10aa2)
#4 0x00007fa4bbfcfff8 n/a (libpipewire-module-protocol-native.so + 0x10ff8)
#5 0x00007fa4c4522d9b n/a (libspa-support.so + 0x6d9b)
#6 0x00007fa4c449c5ab pw_main_loop_run (libpipewire-0.3.so.0 + 0x425ab)
#7 0x0000563c06b927dc n/a (pipewire-media-session + 0xc7dc)
#8 0x00007fa4c415fb25 __libc_start_main (libc.so.6 + 0x27b25)
#9 0x0000563c06b92c5e n/a (pipewire-media-session + 0xcc5e)
Stack trace of thread 8950:
#0 0x00007fa4c423739e epoll_wait (libc.so.6 + 0xff39e)
#1 0x00007fa4c452c1f1 n/a (libspa-support.so + 0x101f1)
#2 0x00007fa4c4522d04 n/a (libspa-support.so + 0x6d04)
#3 0x00007fa4c4482f50 n/a (libpipewire-0.3.so.0 + 0x28f50)
#4 0x00007fa4c430e299 start_thread (libpthread.so.0 + 0x9299)
#5 0x00007fa4c4237053 __clone (libc.so.6 + 0xff053)
Boot c19980c26fac4fdd932c685cd0236a08 –
mar 03 19:18:08 MrRobot kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PCI0.LPC0.EC0], AE_NOT_FOUND (20201113/dswload2-162)
mar 03 19:18:08 MrRobot kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20201113/psobject-220)
mar 03 19:18:08 MrRobot kernel: pci 0000:00:00.2: AMD-Vi: Unable to read/write to IOMMU perf counter.
mar 03 19:18:10 MrRobot kernel: acp_pdm_mach acp_pdm_mach.0: snd_soc_register_card(acp) failed: -517
mar 03 19:18:11 MrRobot systemd-backlight[1048]: Failed to get backlight or LED device ‘backlight:acpi_video0’: No such device
mar 03 19:18:11 MrRobot systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:acpi_video0.
mar 03 19:18:11 MrRobot systemd-backlight[1049]: amdgpu_bl0: Failed to write system ‘brightness’ attribute: No such device or address
mar 03 19:18:11 MrRobot systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0.
mar 03 19:18:12 MrRobot kernel: amdgpu 0000:03:00.0: amdgpu: Unsupported power profile mode 0 on RENOIR
mar 03 19:18:19 MrRobot bluetoothd[871]: profiles/input/hog-lib.c:report_value_cb() bt_uhid_send: Invalid argument (22)
mar 03 19:18:53 MrRobot bluetoothd[871]: profiles/input/hog-lib.c:report_value_cb() bt_uhid_send: Invalid argument (22)
mar 03 19:19:09 MrRobot kernel: ucsi_acpi USBC000:00: PPM init failed (-110)
Any help would be appreciate.
Regards
