I’ve tried different kernels and nothing works. This started yesterday no changes to my system. Global theme installation crashes but doesn’t show as installed but appears with the list of my global themes.
Nothing to do with the kernels.
If you install from KDE store see when the theme was last updated.
Check your ~/.local/share/plasma/look-and-feel/
and see if you spot some inconsistencies.
Probably you better install the theme manually …
Everything looks fine, it does it for every theme new I try.
I’ll install them manually for now and look more into it tomorrow. Thanks though.
