Settings and Layout icons
Hi everyone - newbie here.
I was following the tutorial for installing Manjaro. Success but i noticed in the top corner I’m missing an icon for layout or something and also in the on/off icon the settings entry is now missing!
Does anyone know what might have happened here?
Thanks!!!
Screenshot from 2020-12-17 15-45-18
It might help to post a screenshot…
It wouldn’t let me embed - did that work?
Hello,
Once you finished the install and the Gnome Initial Setup took place, open up terminal and run:
sudo pacman-mirrors -f && sudo pacman -Syyu
Once the system got updated, reboot … All should be fine after that.
