Dear all,
After installing Manjaro on an SSD I added two HDDs and set them up as RAID 10 following the Arch Linux guide
One step in this guide is:
mdadm --create --verbose --level=10 --metadata=1.2 --chunk=512 --raid-devices=2 --layout=f2 /dev/md/MyRAID10Array /dev/sdb1 /dev/sdc1
I altered the step into:
mdadm --create --verbose --level=10 --metadata=1.2 --chunk=512 --raid-devices=2 --layout=f2 /dev/md/media1 /dev/sda1 /dev/sdb1
The only difference is that I changed the mount point from /dev/md/MyRAID10Array into /dev/md/media1.
The RAID seems to be fine. sudo fdisk -l returns:
Disk /dev/sda: 1.82 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: WDC WD20EFRX-68A
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: D8FDDE3D-607C-1F4F-B096-25F18FE93387Device Start End Sectors Size Type
/dev/sda1 2048 3906824191 3906822144 1.8T Linux RAIDDisk /dev/sdb: 1.82 TiB, 2000398934016 bytes, 3907029168 sectors
Disklabel type: gpt
Disk identifier: 933A8718-9533-EB44-8F7B-CF5BB1B226E4Device Start End Sectors Size Type
/dev/sdb1 2048 3906824191 3906822144 1.8T Linux RAID…
Disk /dev/md127: 1.82 TiB, 2000157671424 bytes, 3906557952 sectors
I/O size (minimum/optimal): 524288 bytes / 1048576 bytes
Now my question: Why is the mount point /dev/md127 and not /dev/md/media1?
There is a link from /dev/md/media to /dev/md127. What are the mechanics behind it?
Thank for your help and best regards,
Fabius
