Setting the Screen Resolution of your Raspberry Pi
Hi!
I can't get 1080p 60Hz using hdmi_force_hotplug option.
I have two Raspberry Pi 4 and want to turn they on while disconnected from TV/monitor.
When I connect either one to TV/monitor, they are always at 1024x768 @60Hz.
References:
https://pimylifeup.com/raspberry-pi-screen-resolution/
https://www.raspberrypi.org/documentation/configuration/config-txt/video.md
Tried with hdmi_group as CEA and as DMT. Same results.
Content of /boot/config.txt
# See /boot/overlays/README for all available options
gpu_mem=64
kernel=kernel8.img
arm_64bit=1
enable_gic=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
hdmi_force_hotplug:1=1
hdmi_group:1=1
hdmi_mode:1=16
hdmi_force_mode:1=1
#hdmi_force_hotplug:1=1
#hdmi_group:1=2
#hdmi_mode:1=82
#hdmi_force_mode:1=1
What else can I try? :thinking:
hdmi_force_edid_3d:1=1
hdmi_mode:1=16
hdmi_group:1=1
hdmi_force_mode:1=1
hdmi_ignore_edid:1=0xa5000080
Thanks @Darksky !!!
It worked! :partying_face:
Awesome!
Remember every time the kernel updates your /boot/config.txt will get over written but it will save yours in a .pacsave so you will have to make adjustments again in the /boot/config.txt before rebooting.
Pushed linux-rpi4-4.19.113 and linux-rpi4-mainline-5.5.13 to the unstable branch today (along with the new firmware: raspberrypi-bootloader-20200326 / raspberrypi-bootloader-x-20200326) so it will not be long before the kernel will want to upgrade.
Also remember to make adjustments for our repo change:
Another mirror transition - Manual intervention required!
This topic was automatically closed after 90 days. New replies are no longer allowed.
