Setting lowest brightness using keys turns off the screen
xfce
screen
#1
Hey guys,
I’m using Manjaro XFCE edition. When I reduce screen brightness to lowest using keys, it turns off the screen. I can bring it back by increasing the brightness.
It works fine when I manage it through Power Manager. How can I define lowest screen brightness for keys?
#2
Assign the hotkey for lowering the brightness to a shell script which checks for the current brightness and exits if the brightness value returned is the lowest possible for your system.
There is no way to do this on a distribution level.
Look at the /sys/class/backlight/* to get an idea.
did you solve this? i wish it could be added by default as this is the only thing that i’m not enjoying about manjaro
#4
hello, i dont completely understand what you’re saying, however, i would like to stop this behaviour, also, if it helps, is there some kde extension to stop this somehow
closed #5
@shucks - necrobump - topic closed
If you are dimming your light - you will eventually turn it off.
This is the nature of a dimmer.
