Wifi only works for a few minutes in Manjaro, works fine in Windows
On my Assus TUF gaming laptop, Wifi stops working after a few minutes.
When I restart network manager (sudo systemctl restart NetworkManager), it either works again, or it does not detect any wifi SSIDs anymore, and the network interfaces become unavailable.
In the past, there also was a period of time that my wifi regularly stopped working, and it has been working good again afterwards, but now the problem re appears, and it is worse than before.
nmcli -show         ✔  7s 
lo: connected (externally) to lo
       "lo"
       loopback (unknown), 00:00:00:00:00:00, sw, mtu 65536
       inet4 127.0.0.1/8
       inet6 ::1/128
       route6 ::1/128 metric 256
enp2s0: unavailable
       "Realtek RTL8111/8168/8411"
       ethernet (r8168), 3C:7C:3F:1A:FA:4A, hw, mtu 1500
wlp3s0: unavailable
       "Realtek RTL8822CE"
       wifi (rtw_8822ce), D8:C0:A6:0E:EB:3F, hw, mtu 1500
nmcli connection show         ✔
NAME                UUID                                  TYPE      DEVICE
lo                  0ae91f9a-9875-4689-8e8f-5680f8d3c31b  loopback  lo
aaa                 466bcb5c-789e-48b6-a3dc-796271fec3f9  wifi      --
Armonea-Guest       a00eafb3-5bc3-4034-97c0-fe5794a62fc7  wifi      --
MABO                322d6fdd-f604-4bf8-ad39-aac76823b45d  wifi      --
Wired connection 1  1cc25d2d-9fff-30e6-b4ad-02a8054a5fe3  ethernet  --
nmcli device show         ✔
GENERAL.DEVICE:                         lo
GENERAL.TYPE:                           loopback
GENERAL.HWADDR:                         00:00:00:00:00:00
GENERAL.MTU:                            65536
GENERAL.STATE:                          100 (connected (externally))
GENERAL.CONNECTION:                     lo
GENERAL.CON-PATH:                       /org/freedesktop/NetworkManager/ActiveConnection/1
IP4.ADDRESS[1]:                         127.0.0.1/8
IP4.GATEWAY:                            --
IP6.ADDRESS[1]:                         ::1/128
IP6.GATEWAY:                            --
IP6.ROUTE[1]:                           dst = ::1/128, nh = ::, mt = 256
GENERAL.DEVICE:                         enp2s0
GENERAL.TYPE:                           ethernet
GENERAL.HWADDR:                         3C:7C:3F:1A:FA:4A
GENERAL.MTU:                            1500
GENERAL.STATE:                          20 (unavailable)
GENERAL.CONNECTION:                     --
GENERAL.CON-PATH:                       --
WIRED-PROPERTIES.CARRIER:               off
IP4.GATEWAY:                            --
IP6.GATEWAY:                            --
GENERAL.DEVICE:                         wlp3s0
GENERAL.TYPE:                           wifi
GENERAL.HWADDR:                         D8:C0:A6:0E:EB:3F
GENERAL.MTU:                            1500
IP4.GATEWAY:                            --
IP6.GATEWAY:                            --
When I reboot in windows, which I normally don’t use, wifi does not work there either, but the windows troubleshooter fixes it, and when I then reboot in Manjaro, wifi works again for a few hours, and then it breaks again.
Not sure, but I am thinking it may be a driver bug that resurfaced after a Manjaro update.
Is there somewhere I can find older drivers to try if that solves the network problem, or any other way to troubleshoot and solve this issue ?
Any ideas on how to fix this ?
Another issue is that the pacman gui app does not update the system anymore.
I was able to do an update using the terminal command sudo pacman -Syyu
but a few AUR packages don’t get updated.
Pacman says "failed to prepare transaction and suggests to edit build files.
Failed to prepare transaction:
target not found:
I am running Manjaro for almost 4 years now on this laptop, and lately experimented with a number of install/uninstalls, and also installed a Brother printer driver using the Brother install script that required installing dpkg, which is a Debian package manager.
Do you think it is time for a complete re install of Manjaro and to start with a clean system to fix all of these problems ?
I forgot to mention I tried a number of different kernels, but that does not change anything.
I another forum post someone suggested using AUR package rtw88-dkms-git, but for anything from AUR I get the error message “target not found”, while AUR access is enabled in pacman.
Is there a problem with AUR at this moment ?
pacman does not provide custom package build.
I think you are mean Pamac and pamac caught a storm - the team is working out the kinks - that is why I linked you to the release topic.
I linked you to the search because there is so many issues with that device - it is impossible to know what is yours.
My guess is the card is powered off when the system idles to long - that is only a guess.
:point_up:
you’ll have to wait a little bit until the manjaroteam has solved this serious problem actually. hopefully they get it fixed today.
while you’re running windows. boot to windows and DISABLE fastboot. this is one possible cause. make sure it is disabled for your wifi-device and report.
I disabled fastboot in windows, but now I no longer have any network available in linux, so I am posting this using windows now.
I rarely use windows, I left it on the PC just in case I would need a software that is not available on linux, like the application to update my car gps.
I’ll check if I have wifi access using the Manjaro live USB stick.
Try this solution: RTL8822CE Unable to enable Wifi - #4 by some_guy
Edit: Actually, scrap that for now and first post the output of:
inxi -Fazy
inxi -Fazy         ✔  3s 
 Kernel: 6.1.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
   root=UUID=6a2ac9ce-0e4d-4698-ba63-21025411cf23 rw quiet apparmor=1
 Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
 Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A17 FA706IU_FX706IU
   v: 1.0 serial: <superuser required>
 Mobo: ASUSTeK model: FA706IU v: 1.0 serial: <superuser required>
   UEFI: American Megatrends v: FA706IU.316 date: 03/12/2021
 ID-1: BAT1 charge: 35.9 Wh (50.8%) condition: 70.7/90.2 Wh (78.4%)
   volts: 14.8 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
   status: discharging
 Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
   arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
   process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
   microcode: 0x8600104
 Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
   L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
   desc: 2x4 MiB
 Speed (MHz): avg: 1396 high: 1398 min/max: 1400/2900 boost: enabled
   scaling: driver: acpi-cpufreq governor: powersave cores: 1: 1397 2: 1397
   3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1388
   12: 1397 13: 1397 14: 1396 15: 1397 16: 1398 bogomips: 92657
 Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
   protection
 Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
   always-on, RSB filling, PBRSB-eIBRS: Not affected
 Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: ASUSTeK
   driver: N/A alternate: nouveau non-free: 535.xx+
   status: current (as of 2023-07) arch: Turing code: TUxxx
   process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
   link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
 Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
   code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
   lanes: 16 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 05:00.0
   chip-ID: 1002:1636 class-ID: 0300 temp: 41.0 C
 Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
   rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:2 chip-ID: 13d3:56a2
 Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
   compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
   alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
   s-diag: 582mm (22.93")
 Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x08be built: 2019
   res: 1920x1080 hz: 120 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
   diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
 API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon Graphics (renoir LLVM
   15.0.7 DRM 3.49 6.1.38-1-MANJARO) direct-render: Yes
 Device-1: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
   driver: snd_hda_intel v: kernel pcie: speed: Unknown lanes: 63 link-max:
   gen: 6 speed: 64 GT/s bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
 Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
   bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
 Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: DekTec Digital
   Video B.V. driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
   snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
   snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
   lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
 Device-4: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel
   v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.6
   chip-ID: 1022:15e3 class-ID: 0403
 API: ALSA v: k6.1.38-1-MANJARO status: kernel-api with: aoss
 Server-3: PipeWire v: 0.3.73 status: off with: pipewire-media-session
   status: active tools: pw-cli
 Server-4: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
   type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
   vendor: ASUSTeK driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie: gen: 1
   speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168
   class-ID: 0200
 Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
   vendor: AzureWave driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
   speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s port: d000
   bus-ID: 03:00.0 chip-ID: 10ec:c822 class-ID: 0280
 IF: wlp3s0 state: down mac: <filter>
 Device-1: IMC Networks Bluetooth Radio driver: btusb v: 0.8 type: USB
   rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 13d3:3548
 Local Storage: total: 953.87 GiB used: 431.71 GiB (45.3%)
 ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
   SDBPNPZ-1T00-1002 size: 953.87 GiB block-size: physical: 512 B
   fw-rev: 21106000 temp: 38.9 C scheme: GPT
 ID-1: / raw-size: 290.3 GiB size: 284.68 GiB (98.06%) used: 95.02 GiB (33.4%)
   fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
 ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
   used: 324 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p9 maj-min: 259:9
 ID-1: swap-1 type: partition size: 35.64 GiB used: 0 KiB (0.0%)
   priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:5
 System Temperatures: cpu: 44.8 C mobo: N/A gpu: amdgpu temp: 42.0 C
 Fan Speeds (RPM): cpu: 2200
 Processes: 354 Uptime: 1h 24m wakeups: 1 Memory: total: 16 GiB note: est.
 available: 15.05 GiB used: 5.58 GiB (37.1%) Init: systemd v: 253
 default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
 Packages: 2209 pm: pacman pkgs: 2196 libs: 498 tools: pamac,yay pm: flatpak
 pkgs: 0 pm: snap pkgs: 13 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
 running-in: yakuake inxi: 3.3.28
