As I understand it, version 6.5 of plasma finally supports session recall when running Wayland.
Can anyone tell me whether sessions are remembered across protocols (either automatically or by copying some files from one config directory to another), or whether the session layout has to be rebuilt from scratch on Wayland?
I have no idea - I don’t use the feature - but as Wayland is the primary - my guess is that you will need to recreate your session.
Login using Wayland Session - check with system settings → scroll down to session → if you activate the option When session was manually saved - then logout and relogin - see if the session load - you might be in luck - but as said - I don’t know.
Under Wayland the session is restored since a year or so I think.
I think there is some misunderstanding. Restoring a session under Wayland doesn’t mean the application windows’ positions would be restored. The applications/windows will be there (and tabs inside the windows too) but all the windows are cluttered on a single desktop after restoring. I think this is what you refer to somehow - and there is no change in 6.5 because Wayland doesn’t support the required functionality to position the windows as far as i know. I think it’s still in discussion.
For me personally this isn’t much of an issue since i don’t leave the session unless i have to reboot.
It seems to have at least some. For example, when I open the laptop lid and its screen activates, Teams flips from the monitor to the position I had it on the laptop display. It also returns to its same position on the main monitor when I close the laptop display.
I managed to test a few things out on a much lighter desktop than my main workstation, from what I see:
The actual programs & windows are preserved across X & Wayland (one of two dolphin instances was lost on the W→X switch).
All are deposited on one monitor of the current workspace (as in which one was shown when I logged out).
As a Linux user of well-nigh 30 years, including both KDE and Manjaro from day 2 of their public availability, I can’t help feeling this changeover is going to be a mess of the same class as glibc2 and KDE4.
I’ll try to put in a feature request for full session restore (I think it should go to plasma-desktop, with possible escalation to Wayland).
