Can anyone point me to an Arch-wiki section where I can research this question?
I have licensed software on my main machine. I want to access the application from another box on the home LAN to avoid paying for a second license for a local installation. Seems like this should be a trivial task for Manjaro Linux but darned if I can find where to get started.
Thanks in advaance.
I guess you looking for something like AnyDesk, Teamviewer and VNC… but well there are also other ways depending on the software: blocking internet, make the app portable…
About what kind of app are you talking?
Thank you for the fast reply.
I have a licensed graphics editor on the main workstation, and wish to edit .jpg files on the local machine.
That is a no go. Software is like a book you bought - only one person can read it at any one time.
If the vendor requires license to run - then it is a violation of license terms - and Manjaro community does not endorse nor support such violation.
Topic closed - as it violates the forum rules.
