@scotty65
Inxi:
❯ inxi -zv8
Kernel: 7.3.0-rc1-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
parameters: BOOT_IMAGE=/vmlinuz-7.3-x86_64
root=UUID=2265a3ee-fe59-4b09-b0ba-e389b7f9bdc7 rw quiet splash apparmor=1
resume=UUID=c0c12262-a803-4893-a052-04811cabcec1
nvme_core.default_ps_max_latency_us=0 pcie_aspm=off pcie_port_pm=off
Desktop: GNOME v: 50.4 tk: GTK v: 3.24.52 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 50.3 Distro: Manjaro
base: Arch Linux
Mobo: ASUSTeK model: TUF GAMING X670E-PLUS v: Rev 1.xx
Firmware: UEFI vendor: American Megatrends v: 3881 date: 06/17/2026
System RAM: total: 32 GiB available: 30.49 GiB used: 5.45 GiB (17.9%)
Array-1: capacity: 256 GiB slots: 4 modules: 2 EC: None
max-module-size: 64 GiB note: est.
Device-1: Channel-A DIMM 0 type: no module installed
Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: 4800 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: KF552C40-16 serial: <filter>
Device-3: Channel-B DIMM 0 type: no module installed
Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 4
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB
desc: 12x1024 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3604 min/max: 415/5738 boost: disabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3604 2: 3604 3: 3604
4: 3604 5: 3604 6: 3604 7: 3604 8: 3604 9: 3604 10: 3604 11: 3604 12: 3604
13: 3604 14: 3604 15: 3604 16: 3604 17: 3604 18: 3604 19: 3604 20: 3604
21: 3604 22: 3604 23: 3604 24: 3604 bogomips: 225162
apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
clflushopt clwb clzero cmov cmp_legacy constant_tsc cppc cpuid
cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt gfni ht
hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv lm mba
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx ospke osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb perfmon_v2
pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed
rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean vme
vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves xtopology
conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6900 XT]
vendor: XFX driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-2 empty: DP-1, DP-3, HDMI-A-1, Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:73af class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: ASUSTeK
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-4,HDMI-A-2,Writeback-2 bus-ID: 14:00.0 chip-ID: 1002:164e
class-ID: 0300 temp: 39.0 C
Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
compositor: gnome-shell driver: X: loaded: amdgpu dri: radeonsi gpu: amdgpu
display-ID: 0
Monitor-1: DP-2 model: Philips PHL 499P9 serial: <filter> built: 2021
res: 3840x1080 dpi: 82 gamma: 1.2 chroma: red: x: 0.675 y: 0.314 green:
x: 0.278 y: 0.647 blue: x: 0.149 y: 0.067 white: x: 0.314 y: 0.329
size: 1193x336mm (46.97x13.23") diag: 1239mm (48.8") modes: 3840x1080,
5120x1440, 2560x1440, 1920x1080, 1280x1024, 1280x720, 1024x768, 832x624,
800x600, 720x576, 720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unknown tag 112
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi
surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 vendor: amd mesa v: 26.2.2-arch1.1 glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 6900 XT (radeonsi navi21 ACO DRM
3.64 7.3.0-rc1-2-MANJARO) device-ID: 1002:73af memory: 15.62 GiB
unified: no display-ID: :0.0
API: Vulkan v: 1.4.357 layers: 10 device: 0 type: discrete-gpu name: AMD
Radeon RX 6900 XT (RADV NAVI21) driver: mesa radv v: 26.2.2-arch1.1
device-ID: 1002:73af surfaces: N/A device: 1 type: integrated-gpu name: AMD
Ryzen 9 7900X 12-Core Processor (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 26.2.2-arch1.1 device-ID: 1002:164e surfaces: N/A device: 2 type: cpu
name: llvmpipe (LLVM 22.1.8 256 bits) driver: mesa llvmpipe
v: 26.2.2-arch1.1 (LLVM 22.1.8) device-ID: 10005:0000 surfaces: N/A
Info: Tools: api: eglinfo, glxinfo, vulkaninfo gpu: lact,radeontop
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 14:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: ASUSTeK
bus-ID: 14:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k7.3.0-rc1-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8127 10GbE driver: r8169 v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 2 port: d000 bus-ID: 0b:00.0 chip-ID: 10ec:8127
class-ID: 0200
IF: enp11s0 state: up speed: 10000 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic scope: global
IP v6: <filter> virtual: proto kernel_ll scope: link
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 0c:00.0
IF: eno1 state: up speed: 2500 Mbps duplex: full mac: <filter>
IF-ID-1: vlan11 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-2: vlan30 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-3: vlan32 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-4: vlan64 state: up speed: 10000 Mbps duplex: full mac: <filter>
Info: services: smbd, systemd-networkd, systemd-timesyncd, wpa_supplicant
Device-1: Realtek Bluetooth 5.4 Radio driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-5.3:7
chip-ID: 0bda:a728 class-ID: e001 serial: <filter>
Report: btmgmt ID: hci1 rfk-id: 1 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 24.56 TiB used: 5.43 TiB (22.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with
Heatsink 1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7
temp: 46.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:13 vendor: Western Digital
model: WD Blue SN570 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 234140WD temp: 44.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:12 vendor: Western Digital
fw-rev: 234140WD temp: 41.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 model: iSCSI Disk size: 10 TiB block-size:
physical: 32768 B logical: 512 B tech: N/A serial: <filter> fw-rev: 3100
scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 model: iSCSI Disk size: 10.01 TiB block-size:
physical: 16384 B logical: 512 B tech: N/A serial: <filter> fw-rev: 3100
scheme: GPT
ID-1: / raw-size: 128 GiB size: 125.68 GiB (98.19%) used: 20.53 GiB (16.3%)
fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7 label: Manjaro Root
uuid: 2265a3ee-fe59-4b09-b0ba-e389b7f9bdc7
ID-2: /boot raw-size: 2 GiB size: 1.94 GiB (96.93%)
used: 277.1 MiB (14.0%) fs: ext3 dev: /dev/nvme0n1p6 maj-min: 259:6
label: Manjaro Boot uuid: ffd33209-8d4b-48e4-8eec-4d4b2f958ee2
ID-3: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%)
used: 113 MiB (44.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 58B0-1F88
ID-4: /home raw-size: 64 GiB size: 61.94 GiB (96.79%)
used: 22.83 GiB (36.9%) fs: ext4 dev: /dev/nvme2n1p3 maj-min: 259:16
label: Manjaro Homes uuid: 8a0c2ec7-053b-45a2-840a-241fac0c9500
ID-5: /mnt/Games-Linux-iSCSI raw-size: 10 TiB size: 9.92 TiB (99.20%)
used: 5.38 TiB (54.3%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
label: Games-Linux uuid: bb7dd672-3d2a-48c4-8c96-e351d50e7c33
ID-1: swap-1 type: partition size: 48 GiB used: 0 KiB (0.0%) priority: -1
dev: /dev/nvme0n1p10 maj-min: 259:10 label: LSwap
uuid: c0c12262-a803-4893-a052-04811cabcec1
ID-1: /dev/nvme0n1p11 maj-min: 259:11 size: 48 GiB fs: swap
label: CachyOS-Swap uuid: 79eed85e-fcd1-4766-8d10-431e55b3b84b
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 255.11 GiB fs: ntfs
label: Win11Pro_x86_64 uuid: B236B1ED36B1B2A9
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 905 MiB fs: ntfs label: N/A
uuid: 801A11A21A1195EE
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 707 MiB fs: ntfs label: N/A
uuid: CE2252C12252AE69
ID-6: /dev/nvme0n1p8 maj-min: 259:8 size: 4 GiB fs: vfat label: N/A
uuid: 111C-8682
ID-7: /dev/nvme0n1p9 maj-min: 259:9 size: 160 GiB fs: btrfs
label: CachyOS Root uuid: e3dcb25a-e1ba-468b-ac23-648ce3812b26
ID-8: /dev/nvme1n1p1 maj-min: 259:17 size: 1.62 TiB fs: btrfs
label: CachyOS Homes uuid: 3d25f519-7254-4e10-971b-26ec2f512e0d
ID-9: /dev/nvme2n1p1 maj-min: 259:14 size: 512 GiB fs: ntfs
label: Daten & FTP uuid: 60EAE03AEAE00E5A
ID-10: /dev/nvme2n1p2 maj-min: 259:15 size: 256 GiB fs: ntfs
label: lokale Games uuid: C6AAF89CAAF88A67
ID-11: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
ID-12: /dev/sdb2 maj-min: 8:18 size: 10 TiB fs: ntfs label: Games-iSCSI
uuid: BA924C0F924BCE97
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-4: 3-3:2 info: VIA Labs VL820 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2820
Hub-5: 3-3.1:3 info: Super Top 4-Port hub ports: 4 rev: 2.0
chip-ID: 14cd:8601 class-ID: 0900
Device-1: 3-3.1.2:4 info: VIA Labs PD 3.0 USB-C Device type: billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 2109:0102 class-ID: 1100 serial: <filter>
Hub-6: 4-0:1 info: super-speed hub ports: 5 rev: 3.1
Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-8: 5-5:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 5-5.1:4 info: QinHeng CH340 serial converter
type: <vendor specific> driver: ch341,ch341-uart interfaces: 1 rev: 1.1
chip-ID: 1a86:7523 class-ID: ff00
Device-2: 5-5.2:6 info: QinHeng CH340 serial converter
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 96mA
Device-3: 5-5.3:7 info: Realtek Bluetooth 5.4 Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:a728 class-ID: e001 serial: <filter>
Device-4: 5-8:3 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
serial: <filter>
Device-5: 5-9:5 info: MCT Elektronikladen aquaero type: keyboard,HID
driver: aquacomputer_d5next,usbhid interfaces: 3 rev: 2.0
chip-ID: 0c70:f001 class-ID: 0300 serial: <filter>
Hub-9: 6-0:1 info: super-speed hub ports: 6 rev: 3.1
Hub-10: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-11: 7-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 7-2.2:3 info: Razer USA RZ03-0203 Gaming Keyboard [BlackWidow
Chroma V2] type: keyboard,mouse driver: razerkbd,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 500mA
chip-ID: 1532:0221 class-ID: 0300
Device-2: 7-2.4:4 info: Maxxter Wireless Receiver type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 248a:8073 class-ID: 0301
Hub-12: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-13: 9-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-14: 10-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-15: 11-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
System Temperatures: cpu: 42.0 C mobo: 36.0 C
Fan Speeds (rpm): cpu: 0 fan-1: 0 fan-2: 3452 fan-3: 0 fan-4: 0 fan-5: 0
fan-6: 0 fan-7: 0
GPU: device: amdgpu temp: 38.0 C device: amdgpu temp: 40.0 C mem: 34.0 C
fan: 0 watts: 5.00
Packages: pm: pacman pkgs: 1622 libs: 466 tools: gnome-software,pamac
pm: flatpak pkgs: 0
1: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
2: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 602
1: cpu: 30.3% command: vivaldi-bin pid: 7933 mem: 1672.9 MiB (5.3%)
2: cpu: 9.2% command: vivaldi-bin pid: 8704 mem: 461.1 MiB (1.4%)
3: cpu: 7.8% command: vivaldi-bin pid: 8069 mem: 302.9 MiB (0.9%)
4: cpu: 6.0% command: vivaldi-bin pid: 8892 mem: 257.2 MiB (0.8%)
5: cpu: 5.5% command: gnome-shell pid: 4676 mem: 280.6 MiB (0.8%)
Memory top: 5 of 602
1: mem: 1672.9 MiB (5.3%) command: vivaldi-bin pid: 7933 cpu: 30.3%
2: mem: 461.1 MiB (1.4%) command: vivaldi-bin pid: 8704 cpu: 9.2%
3: mem: 302.9 MiB (0.9%) command: vivaldi-bin pid: 8069 cpu: 7.8%
4: mem: 294.7 MiB (0.9%) command: vivaldi-bin pid: 8492 cpu: 3.8%
5: mem: 280.6 MiB (0.8%) command: gnome-shell pid: 4676 cpu: 5.5%
Processes: 602 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.14 GiB services: gsd-power,upowerd
Init: systemd v: 261 default: graphical tool: systemctl
Compilers: clang: 22.1.8 gcc: 16.2.1 Shell: Zsh v: 5.9.2 running-in: kgx
inxi: 3.3.41
Next i’ll try switching the Branch…
7.3.0rc4-2 is the same:
[ 40.198800] rfkill: input handler enabled
[ 41.108881] rfkill: input handler disabled
[ 41.259037] block nvme1n1: No UUID available providing old NGUID
[ 120.769626] connection3:0: detected conn error (1020)
[ 212.929886] connection3:0: detected conn error (1020)
[ 212.929934] sd 14:0:0:0: [sdb] tag#66 timing out command, waited 180s
[ 212.929967] sd 14:0:0:0: [sdb] tag#66 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=184s
[ 212.929971] sd 14:0:0:0: [sdb] tag#66 CDB: Write(16) 8a 00 00 00 00 00 00 54 7f f8 00 00 40 00 00 00
[ 212.929973] I/O error, dev sdb, sector 5537784 op 0x1:(WRITE) flags 0x4000 phys_seg 2048 prio class 2
[ 212.929989] sd 14:0:0:0: [sdb] tag#68 timing out command, waited 180s
[ 212.930017] sd 14:0:0:0: [sdb] tag#68 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=184s
[ 212.930019] sd 14:0:0:0: [sdb] tag#68 CDB: Write(16) 8a 00 00 00 00 00 00 54 bf f8 00 00 40 00 00 00
[ 212.930021] I/O error, dev sdb, sector 5554168 op 0x1:(WRITE) flags 0x4000 phys_seg 2048 prio class 2
[ 212.930031] sd 14:0:0:0: [sdb] tag#69 timing out command, waited 180s
[ 212.930058] sd 14:0:0:0: [sdb] tag#69 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=184s
[ 212.930060] sd 14:0:0:0: [sdb] tag#69 CDB: Write(16) 8a 00 00 00 00 00 00 54 ff f8 00 00 40 00 00 00
[ 212.930061] I/O error, dev sdb, sector 5570552 op 0x1:(WRITE) flags 0x4000 phys_seg 2048 prio class 2
[ 212.930071] sd 14:0:0:0: [sdb] tag#70 timing out command, waited 180s
[ 212.930097] sd 14:0:0:0: [sdb] tag#70 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=184s
[ 212.930100] sd 14:0:0:0: [sdb] tag#70 CDB: Write(16) 8a 00 00 00 00 00 00 55 3f f8 00 00 40 00 00 00
[ 212.930101] I/O error, dev sdb, sector 5586936 op 0x1:(WRITE) flags 0x4000 phys_seg 2048 prio class 2
[ 212.930109] sd 14:0:0:0: [sdb] tag#71 timing out command, waited 180s
[ 212.930136] sd 14:0:0:0: [sdb] tag#71 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=184s
[ 212.930138] sd 14:0:0:0: [sdb] tag#71 CDB: Write(16) 8a 00 00 00 00 00 00 55 7f f8 00 00 40 00 00 00
[ 212.930140] I/O error, dev sdb, sector 5603320 op 0x1:(WRITE) flags 0x4000 phys_seg 2048 prio class 2
[ 212.930148] sd 14:0:0:0: [sdb] tag#73 timing out command, waited 180s
[ 212.930175] sd 14:0:0:0: [sdb] tag#73 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=184s
[ 212.930177] sd 14:0:0:0: [sdb] tag#73 CDB: Write(16) 8a 00 00 00 00 00 00 55 bf f8 00 00 40 00 00 00
[ 212.930178] I/O error, dev sdb, sector 5619704 op 0x1:(WRITE) flags 0x4000 phys_seg 2048 prio class 2
[ 212.930187] sd 14:0:0:0: [sdb] tag#74 timing out command, waited 180s
[ 212.930214] sd 14:0:0:0: [sdb] tag#74 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=184s
[ 212.930216] sd 14:0:0:0: [sdb] tag#74 CDB: Write(16) 8a 00 00 00 00 00 00 55 ff f8 00 00 40 00 00 00
[ 212.930218] I/O error, dev sdb, sector 5636088 op 0x1:(WRITE) flags 0x4000 phys_seg 2048 prio class 2
[ 212.930226] sd 14:0:0:0: [sdb] tag#75 timing out command, waited 180s
[ 212.930253] sd 14:0:0:0: [sdb] tag#75 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=184s
[ 212.930255] sd 14:0:0:0: [sdb] tag#75 CDB: Write(16) 8a 00 00 00 00 00 00 56 3f f8 00 00 40 00 00 00
[ 212.930256] I/O error, dev sdb, sector 5652472 op 0x1:(WRITE) flags 0x0 phys_seg 2048 prio class 2
[ 212.952561] sd 14:0:0:0: Power-on or device reset occurred
[ 303.046169] connection1:0: detected conn error (1020)
[ 303.482536] sd 12:0:0:0: Power-on or device reset occurred
[ 369.724556] INFO: task kworker/u97:0:164 blocked in I/O wait for more than 122 seconds.
[ 369.724564] Tainted: G OE 7.3.0-rc4-2-MANJARO #1
[ 369.724566] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 369.724568] task:kworker/u97:0 state:D stack:0 pid:164 tgid:164 ppid:2 task_flags:0x4248160 flags:0x00080000
[ 369.724574] Workqueue: writeback wb_workfn (flush-8:0)
[ 369.724582] Call Trace:
[ 369.724584] <TASK>
[ 369.724588] __schedule+0x420/0x1780
[ 369.724595] ? __pfx_wbt_inflight_cb+0x10/0x10
[ 369.724600] ? srso_alias_return_thunk+0x5/0xfbef5
[ 369.724604] ? blk_mq_flush_plug_list+0x51/0x1a0
[ 369.724608] ? srso_alias_return_thunk+0x5/0xfbef5
[ 369.724611] ? __blk_flush_plug+0x105/0x170
[ 369.724614] ? srso_alias_return_thunk+0x5/0xfbef5
[ 369.724618] ? __pfx_wbt_inflight_cb+0x10/0x10
[ 369.724620] ? __pfx_wbt_cleanup_cb+0x10/0x10
[ 369.724623] schedule+0x28/0xa0
[ 369.724626] io_schedule+0x46/0x70
[ 369.724630] rq_qos_wait+0xe5/0x1b0
[ 369.724634] ? __pfx_rq_qos_wake_function+0x10/0x10
[ 369.724637] ? __pfx_wbt_inflight_cb+0x10/0x10
[ 369.724641] wbt_wait+0xbb/0x120
[ 369.724645] __rq_qos_throttle+0x27/0x40
[ 369.724648] blk_mq_submit_bio+0x2fc/0x9f0
[ 369.724653] submit_bio_noacct_nocheck+0x2a6/0x390
[ 369.724658] ext4_io_submit+0x40/0x70
[ 369.724663] ext4_do_writepages+0x4ce/0xf00
[ 369.724672] ? ext4_writepages+0xf0/0x1c0
[ 369.724674] ext4_writepages+0xf0/0x1c0
[ 369.724677] ? cpu_util+0x7f/0x150
[ 369.724684] do_writepages+0xd0/0x160
[ 369.724690] __writeback_single_inode+0x53/0x390
[ 369.724693] ? srso_alias_return_thunk+0x5/0xfbef5
[ 369.724696] ? wbc_detach_inode+0x117/0x290
[ 369.724699] writeback_sb_inodes+0x284/0x5a0
[ 369.724712] __writeback_inodes_wb+0x5d/0x110
[ 369.724716] wb_writeback+0x2dd/0x360
[ 369.724722] wb_workfn+0x36c/0x580
[ 369.724728] process_one_work+0x1d3/0x3c0
[ 369.724734] worker_thread+0x1b1/0x310
[ 369.724737] ? __pfx_worker_thread+0x10/0x10
[ 369.724740] kthread+0xe6/0x120
[ 369.724743] ? __pfx_kthread+0x10/0x10
[ 369.724746] ret_from_fork+0x2a9/0x340
[ 369.724750] ? __pfx_kthread+0x10/0x10
[ 369.724753] ret_from_fork_asm+0x1a/0x30
[ 369.724761] </TASK>
[ 395.202721] connection1:0: detected conn error (1020)
[ 395.202771] sd 12:0:0:0: [sda] tag#40 timing out command, waited 180s
[ 395.202791] sd 12:0:0:0: [sda] tag#40 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=183s
[ 395.202797] sd 12:0:0:0: [sda] tag#40 CDB: Write(16) 8a 00 00 00 00 00 7d a2 48 00 00 00 40 00 00 00
[ 395.202800] I/O error, dev sda, sector 2107787264 op 0x1:(WRITE) flags 0x0 phys_seg 2048 prio class 2
[ 395.202808] EXT4-fs warning (device sda1): ext4_end_bio:360: I/O error 10 writing to inode 46727181 starting block 263473408)
[ 395.202831] EXT4-fs (sda1): failed to convert unwritten extents to written extents -- potential data loss! (inode 46727181, error -5)
[ 395.202834] sd 12:0:0:0: [sda] tag#36 timing out command, waited 180s
[ 395.202841] Buffer I/O error on device sda1, logical block 263473152
[ 395.202844] Buffer I/O error on device sda1, logical block 263473153
[ 395.202845] sd 12:0:0:0: [sda] tag#36 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=183s
[ 395.202846] Buffer I/O error on device sda1, logical block 263473154
[ 395.202848] sd 12:0:0:0: [sda] tag#36 CDB: Write(16) 8a 00 00 00 00 00 7d 31 48 00 00 00 40 00 00 00
[ 395.202848] Buffer I/O error on device sda1, logical block 263473155
[ 395.202849] Buffer I/O error on device sda1, logical block 263473156
[ 395.202850] I/O error, dev sda, sector 2100381696 op 0x1:(WRITE) flags 0x0 phys_seg 2048 prio class 2
[ 395.202851] Buffer I/O error on device sda1, logical block 263473157
[ 395.202853] Buffer I/O error on device sda1, logical block 263473158
[ 395.202853] EXT4-fs warning (device sda1): ext4_end_bio:360: I/O error 10 writing to inode 46727175 starting block 262547712)
[ 395.202855] Buffer I/O error on device sda1, logical block 263473159
[ 395.202856] Buffer I/O error on device sda1, logical block 263473160
[ 395.202858] Buffer I/O error on device sda1, logical block 263473161
[ 395.202865] sd 12:0:0:0: [sda] tag#39 timing out command, waited 180s
[ 395.202875] sd 12:0:0:0: [sda] tag#39 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=183s
[ 395.202877] sd 12:0:0:0: [sda] tag#39 CDB: Write(16) 8a 00 00 00 00 00 7d 6c 48 00 00 00 40 00 00 00
[ 395.202878] I/O error, dev sda, sector 2104248320 op 0x1:(WRITE) flags 0x0 phys_seg 2048 prio class 2
[ 395.202881] EXT4-fs warning (device sda1): ext4_end_bio:360: I/O error 10 writing to inode 46727176 starting block 263031040)
[ 395.202895] sd 12:0:0:0: [sda] tag#34 timing out command, waited 180s
[ 395.202905] sd 12:0:0:0: [sda] tag#34 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=183s
[ 395.202907] sd 12:0:0:0: [sda] tag#34 CDB: Write(16) 8a 00 00 00 00 00 7d a3 c8 00 00 00 40 00 00 00
[ 395.202908] I/O error, dev sda, sector 2107885568 op 0x1:(WRITE) flags 0x0 phys_seg 2048 prio class 2
[ 395.202910] EXT4-fs warning (device sda1): ext4_end_bio:360: I/O error 10 writing to inode 46727181 starting block 263485696)
[ 395.202920] sd 12:0:0:0: [sda] tag#32 timing out command, waited 180s
[ 395.202926] sd 12:0:0:0: [sda] tag#32 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=183s
[ 395.202929] sd 12:0:0:0: [sda] tag#32 CDB: Write(16) 8a 00 00 00 00 00 7e 0b 04 88 00 00 27 38 00 00
[ 395.202930] I/O error, dev sda, sector 2114651272 op 0x1:(WRITE) flags 0x0 phys_seg 1255 prio class 2
[ 395.202932] EXT4-fs warning (device sda1): ext4_end_bio:360: I/O error 10 writing to inode 46727176 starting block 264331409)
[ 395.202938] sd 12:0:0:0: [sda] tag#41 timing out command, waited 180s
[ 395.202947] sd 12:0:0:0: [sda] tag#41 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=183s
[ 395.202949] sd 12:0:0:0: [sda] tag#41 CDB: Write(16) 8a 00 00 00 00 00 7e 23 48 00 00 00 40 00 00 00
[ 395.202951] I/O error, dev sda, sector 2116241408 op 0x1:(WRITE) flags 0x0 phys_seg 2048 prio class 2
[ 395.202953] EXT4-fs warning (device sda1): ext4_end_bio:360: I/O error 10 writing to inode 46727181 starting block 264530176)
[ 395.202960] sd 12:0:0:0: [sda] tag#37 timing out command, waited 180s
[ 395.202966] sd 12:0:0:0: [sda] tag#37 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=183s
[ 395.202969] sd 12:0:0:0: [sda] tag#37 CDB: Write(16) 8a 00 00 00 00 00 7e 0a 44 e0 00 00 27 50 00 00
[ 395.202970] I/O error, dev sda, sector 2114602208 op 0x1:(WRITE) flags 0x0 phys_seg 1258 prio class 2
[ 395.202972] EXT4-fs warning (device sda1): ext4_end_bio:360: I/O error 10 writing to inode 46727175 starting block 264325276)
[ 395.202978] sd 12:0:0:0: [sda] tag#35 timing out command, waited 180s
[ 395.202987] sd 12:0:0:0: [sda] tag#35 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=183s
[ 395.202989] sd 12:0:0:0: [sda] tag#35 CDB: Write(16) 8a 00 00 00 00 00 7c 9a 88 00 00 00 40 00 00 00
[ 395.202990] I/O error, dev sda, sector 2090502144 op 0x1:(WRITE) flags 0x0 phys_seg 2048 prio class 2
[ 395.202993] EXT4-fs warning (device sda1): ext4_end_bio:360: I/O error 10 writing to inode 46727175 starting block 261312768)
[ 395.203002] sd 12:0:0:0: [sda] tag#44 timing out command, waited 180s
[ 395.203005] sd 12:0:0:0: [sda] tag#44 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=183s
[ 395.203008] sd 12:0:0:0: [sda] tag#44 CDB: Write(16) 8a 00 00 00 00 00 b2 a7 d8 08 00 00 00 08 00 00
[ 395.203009] I/O error, dev sda, sector 2997344264 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[ 395.203011] EXT4-fs warning (device sda1): ext4_end_bio:360: I/O error 10 writing to inode 46727180 starting block 374668033)
[ 395.203015] sd 12:0:0:0: [sda] tag#38 timing out command, waited 180s
[ 395.203023] sd 12:0:0:0: [sda] tag#38 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=183s
[ 395.203026] sd 12:0:0:0: [sda] tag#38 CDB: Write(16) 8a 00 00 00 00 00 7d 61 88 00 00 00 40 00 00 00
[ 395.203027] I/O error, dev sda, sector 2103543808 op 0x1:(WRITE) flags 0x0 phys_seg 2048 prio class 2
[ 395.203029] EXT4-fs warning (device sda1): ext4_end_bio:360: I/O error 10 writing to inode 46727176 starting block 262942976)
[ 395.203064] EXT4-fs (sda1): failed to convert unwritten extents to written extents -- potential data loss! (inode 46727175, error -5)
[ 395.203207] EXT4-fs (sda1): failed to convert unwritten extents to written extents -- potential data loss! (inode 46727175, error -5)
[ 395.203293] EXT4-fs (sda1): failed to convert unwritten extents to written extents -- potential data loss! (inode 46727175, error -5)
[ 395.203469] EXT4-fs (sda1): failed to convert unwritten extents to written extents -- potential data loss! (inode 46727176, error -5)
[ 395.203603] EXT4-fs (sda1): failed to convert unwritten extents to written extents -- potential data loss! (inode 46727176, error -5)
[ 395.203742] EXT4-fs (sda1): failed to convert unwritten extents to written extents -- potential data loss! (inode 46727176, error -5)
[ 395.203953] EXT4-fs (sda1): failed to convert unwritten extents to written extents -- potential data loss! (inode 46727181, error -5)
[ 395.204096] EXT4-fs (sda1): failed to convert unwritten extents to written extents -- potential data loss! (inode 46727181, error -5)
[ 395.204265] EXT4-fs (sda1): failed to convert unwritten extents to written extents -- potential data loss! (inode 46727180, error -5)
[ 395.217239] sd 12:0:0:0: Power-on or device reset occurred
[ 487.363258] connection1:0: detected conn error (1020)
[ 487.389898] sd 12:0:0:0: Power-on or device reset occurred
[ 492.605359] INFO: task jbd2/sda1-8:1979 blocked in I/O wait for more than 122 seconds.
[ 492.605367] Tainted: G OE 7.3.0-rc4-2-MANJARO #1
[ 492.605370] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 492.605371] task:jbd2/sda1-8 state:D stack:0 pid:1979 tgid:1979 ppid:2 task_flags:0x240040 flags:0x00080000
[ 492.605377] Call Trace:
[ 492.605379] <TASK>
[ 492.605383] __schedule+0x420/0x1780
[ 492.605390] ? blk_insert_flush+0x15e/0x1a0
[ 492.605394] ? srso_alias_return_thunk+0x5/0xfbef5
[ 492.605399] ? blk_mq_submit_bio+0x741/0x9f0
[ 492.605402] ? srso_alias_return_thunk+0x5/0xfbef5
[ 492.605406] ? __pfx_bit_wait_io+0x10/0x10
[ 492.605409] schedule+0x28/0xa0
[ 492.605412] io_schedule+0x46/0x70
[ 492.605415] bit_wait_io+0x11/0x70
[ 492.605418] __wait_on_bit+0x92/0xb0
[ 492.605422] out_of_line_wait_on_bit+0x97/0xc0
[ 492.605426] ? __pfx_wake_bit_function+0x10/0x10
[ 492.605431] jbd2_journal_commit_transaction+0x1573/0x1990
[ 492.605441] ? autoremove_wake_function+0x16/0x70
[ 492.605446] ? __pfx_kjournald2+0x10/0x10
[ 492.605450] kjournald2+0xac/0x270
[ 492.605454] ? __pfx_autoremove_wake_function+0x10/0x10
[ 492.605458] ? srso_alias_return_thunk+0x5/0xfbef5
[ 492.605460] kthread+0xe6/0x120
[ 492.605464] ? __pfx_kthread+0x10/0x10
[ 492.605467] ret_from_fork+0x2a9/0x340
[ 492.605471] ? __pfx_kthread+0x10/0x10
[ 492.605474] ret_from_fork_asm+0x1a/0x30
[ 492.605481] </TASK>
[ 610.243871] connection1:0: detected conn error (1020)
[ 610.243930] sd 12:0:0:0: [sda] tag#38 timing out command, waited 180s
[ 610.243945] sd 12:0:0:0: [sda] tag#38 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=215s
[ 610.243950] sd 12:0:0:0: [sda] tag#38 CDB: Write(16) 8a 00 00 00 00 00 7f 32 c8 00 00 00 40 00 00 00
[ 610.243952] I/O error, dev sda, sector 2134034432 op 0x1:(WRITE) flags 0x0 phys_seg 2048 prio class 2
[ 610.243956] EXT4-fs warning (device sda1): ext4_end_bio:360: I/O error 10 writing to inode 46727181 starting block 266754304)
[ 610.243961] EXT4-fs warning (device sda1): ext4_end_bio:360: I/O error 10 writing to inode 46727181 starting block 266755328)
[ 610.243973] sd 12:0:0:0: [sda] tag#33 timing out command, waited 180s
[ 610.243979] sd 12:0:0:0: [sda] tag#33 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=215s
[ 610.243982] sd 12:0:0:0: [sda] tag#33 CDB: Write(16) 8a 00 00 00 00 00 0a 8a 88 00 00 00 20 00 00 00
[ 610.243983] I/O error, dev sda, sector 176850944 op 0x1:(WRITE) flags 0x0 phys_seg 1024 prio class 2
[ 610.243986] EXT4-fs warning (device sda1): ext4_end_bio:360: I/O error 10 writing to inode 46727184 starting block 22106368)
[ 610.243992] sd 12:0:0:0: [sda] tag#36 timing out command, waited 180s
[ 610.244001] sd 12:0:0:0: [sda] tag#36 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=215s
[ 610.244003] sd 12:0:0:0: [sda] tag#36 CDB: Write(16) 8a 00 00 00 00 00 7e b5 88 00 00 00 40 00 00 00
[ 610.244004] I/O error, dev sda, sector 2125826048 op 0x1:(WRITE) flags 0x0 phys_seg 2048 prio class 2
[ 610.244007] EXT4-fs warning (device sda1): ext4_end_bio:360: I/O error 10 writing to inode 46727183 starting block 265728256)
[ 610.244009] EXT4-fs warning (device sda1): ext4_end_bio:360: I/O error 10 writing to inode 46727183 starting block 265729280)
[ 610.244017] sd 12:0:0:0: [sda] tag#44 timing out command, waited 180s
[ 610.244026] sd 12:0:0:0: [sda] tag#44 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=215s
[ 610.244028] sd 12:0:0:0: [sda] tag#44 CDB: Write(16) 8a 00 00 00 00 00 7e f5 c8 00 00 00 40 00 00 00
[ 610.244029] I/O error, dev sda, sector 2130036736 op 0x1:(WRITE) flags 0x0 phys_seg 2048 prio class 2
[ 610.244031] EXT4-fs warning (device sda1): ext4_end_bio:360: I/O error 10 writing to inode 46727190 starting block 266254592)
[ 610.244034] EXT4-fs warning (device sda1): ext4_end_bio:360: I/O error 10 writing to inode 46727190 starting block 266255616)
[ 610.244042] sd 12:0:0:0: [sda] tag#37 timing out command, waited 180s
[ 610.244050] sd 12:0:0:0: [sda] tag#37 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=215s
[ 610.244052] sd 12:0:0:0: [sda] tag#37 CDB: Write(16) 8a 00 00 00 00 00 7e 31 48 00 00 00 40 00 00 00
[ 610.244054] I/O error, dev sda, sector 2117158912 op 0x1:(WRITE) flags 0x0 phys_seg 2048 prio class 2
[ 610.244056] EXT4-fs warning (device sda1): ext4_end_bio:360: I/O error 10 writing to inode 46727181 starting block 264644864)
[ 610.244064] sd 12:0:0:0: [sda] tag#41 timing out command, waited 180s
[ 610.244073] sd 12:0:0:0: [sda] tag#41 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=215s
[ 610.244075] sd 12:0:0:0: [sda] tag#41 CDB: Write(16) 8a 00 00 00 00 00 7e a8 88 00 00 00 40 00 00 00
[ 610.244076] I/O error, dev sda, sector 2124974080 op 0x1:(WRITE) flags 0x0 phys_seg 2048 prio class 2
[ 610.244079] EXT4-fs warning (device sda1): ext4_end_bio:360: I/O error 10 writing to inode 46727182 starting block 265621760)
[ 610.244081] EXT4-fs warning (device sda1): ext4_end_bio:360: I/O error 10 writing to inode 46727182 starting block 265622784)
[ 610.244089] sd 12:0:0:0: [sda] tag#47 timing out command, waited 180s
[ 610.244098] sd 12:0:0:0: [sda] tag#47 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=215s
[ 610.244100] sd 12:0:0:0: [sda] tag#47 CDB: Write(16) 8a 00 00 00 00 00 7e 99 88 00 00 00 40 00 00 00
[ 610.244101] I/O error, dev sda, sector 2123991040 op 0x1:(WRITE) flags 0x0 phys_seg 2048 prio class 2
[ 610.244109] sd 12:0:0:0: [sda] tag#40 timing out command, waited 180s
[ 610.244118] sd 12:0:0:0: [sda] tag#40 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=215s
[ 610.244120] sd 12:0:0:0: [sda] tag#40 CDB: Write(16) 8a 00 00 00 00 00 7f 16 c8 00 00 00 40 00 00 00
[ 610.244121] I/O error, dev sda, sector 2132199424 op 0x1:(WRITE) flags 0x0 phys_seg 2048 prio class 2
[ 610.244129] sd 12:0:0:0: [sda] tag#39 timing out command, waited 180s
[ 610.244135] sd 12:0:0:0: [sda] tag#39 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=215s
[ 610.244137] sd 12:0:0:0: [sda] tag#39 CDB: Write(16) 8a 00 00 00 00 00 7f 33 08 00 00 00 20 00 00 00
[ 610.244139] I/O error, dev sda, sector 2134050816 op 0x1:(WRITE) flags 0x0 phys_seg 1024 prio class 2
[ 610.244144] sd 12:0:0:0: [sda] tag#46 timing out command, waited 180s
[ 610.244152] sd 12:0:0:0: [sda] tag#46 FAILED Result: hostbyte=DID_TRANSPORT_DISRUPTED driverbyte=DRIVER_OK cmd_age=215s
[ 610.244154] sd 12:0:0:0: [sda] tag#46 CDB: Write(16) 8a 00 00 00 00 00 7e 78 48 00 00 00 40 00 00 00
[ 610.244156] I/O error, dev sda, sector 2121811968 op 0x1:(WRITE) flags 0x0 phys_seg 2048 prio class 2
[ 610.244169] sd 12:0:0:0: [sda] tag#34 timing out command, waited 180s
[ 610.244182] sd 12:0:0:0: [sda] tag#42 timing out command, waited 180s
[ 610.244195] sd 12:0:0:0: [sda] tag#45 timing out command, waited 180s
[ 610.244209] sd 12:0:0:0: [sda] tag#35 timing out command, waited 180s
[ 610.728708] sd 12:0:0:0: Power-on or device reset occurred
[ 610.966502] EXT4-fs (sda1): failed to convert unwritten extents to written extents -- potential data loss! (inode 46727181, error -5)
[ 610.966511] buffer_io_error: 16840 callbacks suppressed
[ 610.966513] Buffer I/O error on device sda1, logical block 266754048
[ 610.966515] Buffer I/O error on device sda1, logical block 266754049
[ 610.966517] Buffer I/O error on device sda1, logical block 266754050
[ 610.966518] Buffer I/O error on device sda1, logical block 266754051
[ 610.966520] Buffer I/O error on device sda1, logical block 266754052
[ 610.966521] Buffer I/O error on device sda1, logical block 266754053
[ 610.966523] Buffer I/O error on device sda1, logical block 266754054
[ 610.966524] Buffer I/O error on device sda1, logical block 266754055
[ 610.966526] Buffer I/O error on device sda1, logical block 266754056
[ 610.966527] Buffer I/O error on device sda1, logical block 266754057
[ 610.966611] EXT4-fs (sda1): failed to convert unwritten extents to written extents -- potential data loss! (inode 46727181, error -5)
[ 610.966685] EXT4-fs (sda1): failed to convert unwritten extents to written extents -- potential data loss! (inode 46727181, error -5)
[ 610.966833] EXT4-fs (sda1): failed to convert unwritten extents to written extents -- potential data loss! (inode 46727181, error -5)
[ 610.966912] EXT4-fs (sda1): failed to convert unwritten extents to written extents -- potential data loss! (inode 46727181, error -5)
[ 610.966989] EXT4-fs (sda1): failed to convert unwritten extents to written extents -- potential data loss! (inode 46727181, error -5)
[ 610.967137] EXT4-fs (sda1): failed to convert unwritten extents to written extents -- potential data loss! (inode 46727181, error -5)
[ 610.967273] EXT4-fs (sda1): failed to convert unwritten extents to written extents -- potential data loss! (inode 46727184, error -5)
[ 610.967344] EXT4-fs (sda1): failed to convert unwritten extents to written extents -- potential data loss! (inode 46727183, error -5)
[ 610.967414] EXT4-fs (sda1): failed to convert unwritten extents to written extents -- potential data loss! (inode 46727183, error -5)
[ 615.485114] INFO: task iscsid:30150 blocked for more than 122 seconds.
[ 615.485121] Tainted: G OE 7.3.0-rc4-2-MANJARO #1
[ 615.485123] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 615.485124] task:iscsid state:D stack:0 pid:30150 tgid:30150 ppid:1918 task_flags:0x400140 flags:0x00080000
[ 615.485130] Call Trace:
[ 615.485132] <TASK>
[ 615.485137] __schedule+0x420/0x1780
[ 615.485144] ? dput.part.0+0x27/0x1a0
[ 615.485149] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485152] ? mntput+0x25/0x70
[ 615.485156] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485159] ? terminate_walk+0xd2/0xf0
[ 615.485162] ? security_file_post_open+0x48/0x130
[ 615.485167] schedule+0x28/0xa0
[ 615.485170] schedule_preempt_disabled+0x16/0x30
[ 615.485172] __mutex_lock.constprop.0+0x3e4/0x930
[ 615.485179] scsi_rescan_device+0x25/0xe0
[ 615.485183] store_rescan_field+0x19/0x30
[ 615.485187] kernfs_fop_write_iter+0x16b/0x210
[ 615.485192] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485194] vfs_write+0x281/0x570
[ 615.485201] ksys_write+0x7b/0x110
[ 615.485205] do_syscall_64+0xce/0x570
[ 615.485208] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485210] ? generic_fillattr+0x4d/0x130
[ 615.485212] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485214] ? kernfs_iop_getattr+0x78/0x90
[ 615.485216] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485217] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485219] ? cp_new_stat+0x18e/0x1c0
[ 615.485222] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485224] ? __do_sys_newfstatat+0x6c/0xa0
[ 615.485229] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485230] ? do_syscall_64+0xce/0x570
[ 615.485234] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485236] ? do_syscall_64+0xce/0x570
[ 615.485238] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485239] ? __memcg_slab_free_hook+0x14b/0x1a0
[ 615.485243] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485244] ? kmem_cache_free+0x286/0x480
[ 615.485247] ? __x64_sys_close+0x47/0xa0
[ 615.485250] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485252] ? __x64_sys_close+0x47/0xa0
[ 615.485254] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485256] ? do_syscall_64+0xce/0x570
[ 615.485257] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485259] ? do_syscall_64+0xce/0x570
[ 615.485261] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485262] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485264] ? do_syscall_64+0x35/0x570
[ 615.485266] entry_SYSCALL_64_after_hwframe+0x76/0x7e
[ 615.485268] RIP: 0033:0x7f46c2b12768
[ 615.485286] RSP: 002b:00007ffe5b77bda0 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
[ 615.485289] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f46c2b12768
[ 615.485290] RDX: 0000000000000001 RSI: 000055ca6fde7410 RDI: 0000000000000008
[ 615.485291] RBP: 00007ffe5b77bdb0 R08: 0000000000000000 R09: 0000000000000000
[ 615.485292] R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000008
[ 615.485294] R13: 000055ca6fde798e R14: 000055ca6fde7410 R15: 0000000000000001
[ 615.485297] </TASK>
[ 615.485328] INFO: task iscsid:30150 is blocked on a mutex likely owned by task iscsid:28580.
[ 615.485330] task:iscsid state:D stack:0 pid:28580 tgid:28580 ppid:1918 task_flags:0x400140 flags:0x00080801
[ 615.485332] Call Trace:
[ 615.485334] <TASK>
[ 615.485335] __schedule+0x420/0x1780
[ 615.485338] ? blk_mq_dispatch_rq_list+0x1bc/0x780
[ 615.485341] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485342] ? lock_timer_base+0x70/0x90
[ 615.485346] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485348] ? __mod_timer+0x242/0x3a0
[ 615.485351] schedule+0x28/0xa0
[ 615.485353] schedule_timeout+0xa3/0x120
[ 615.485355] ? __pfx_process_timeout+0x10/0x10
[ 615.485358] io_schedule_timeout+0x5b/0x90
[ 615.485360] wait_for_completion_io_timeout+0x93/0x180
[ 615.485363] blk_execute_rq+0xee/0x170
[ 615.485366] scsi_execute_cmd+0x10f/0x450
[ 615.485370] scsi_vpd_inquiry+0x7b/0xf0
[ 615.485374] scsi_get_vpd_buf+0x7a/0xd0
[ 615.485376] scsi_attach_vpd+0x25f/0x340
[ 615.485379] scsi_rescan_device+0x4c/0xe0
[ 615.485381] store_rescan_field+0x19/0x30
[ 615.485383] kernfs_fop_write_iter+0x16b/0x210
[ 615.485386] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485387] vfs_write+0x281/0x570
[ 615.485391] ksys_write+0x7b/0x110
[ 615.485393] do_syscall_64+0xce/0x570
[ 615.485395] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485397] ? __do_sys_newfstatat+0x6c/0xa0
[ 615.485401] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485403] ? do_syscall_64+0xce/0x570
[ 615.485405] ? __x64_sys_close+0x47/0xa0
[ 615.485407] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485409] ? __x64_sys_close+0x47/0xa0
[ 615.485411] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485413] ? do_syscall_64+0xce/0x570
[ 615.485414] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485416] ? __x64_sys_close+0x47/0xa0
[ 615.485418] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485420] ? do_syscall_64+0xce/0x570
[ 615.485422] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485424] ? do_syscall_64+0xce/0x570
[ 615.485426] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485427] ? do_syscall_64+0x35/0x570
[ 615.485430] entry_SYSCALL_64_after_hwframe+0x76/0x7e
[ 615.485431] RIP: 0033:0x7f46c2b12768
[ 615.485433] RSP: 002b:00007ffe5b77bda0 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
[ 615.485435] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f46c2b12768
[ 615.485436] RDX: 0000000000000001 RSI: 000055ca6fde7410 RDI: 0000000000000008
[ 615.485437] RBP: 00007ffe5b77bdb0 R08: 0000000000000000 R09: 0000000000000000
[ 615.485438] R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000008
[ 615.485439] R13: 000055ca6fde798e R14: 000055ca6fde7410 R15: 0000000000000001
[ 615.485442] </TASK>
[ 615.485451] INFO: task iscsid:31778 blocked for more than 122 seconds.
[ 615.485452] Tainted: G OE 7.3.0-rc4-2-MANJARO #1
[ 615.485454] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 615.485454] task:iscsid state:D stack:0 pid:31778 tgid:31778 ppid:1918 task_flags:0x400140 flags:0x00080000
[ 615.485457] Call Trace:
[ 615.485458] <TASK>
[ 615.485459] __schedule+0x420/0x1780
[ 615.485462] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485463] ? do_sys_openat2+0x9c/0xe0
[ 615.485467] schedule+0x28/0xa0
[ 615.485469] schedule_preempt_disabled+0x16/0x30
[ 615.485470] __mutex_lock.constprop.0+0x3e4/0x930
[ 615.485474] scsi_rescan_device+0x25/0xe0
[ 615.485476] store_rescan_field+0x19/0x30
[ 615.485478] kernfs_fop_write_iter+0x16b/0x210
[ 615.485481] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485482] vfs_write+0x281/0x570
[ 615.485486] ksys_write+0x7b/0x110
[ 615.485488] do_syscall_64+0xce/0x570
[ 615.485490] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485491] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485493] ? do_syscall_64+0x35/0x570
[ 615.485495] entry_SYSCALL_64_after_hwframe+0x76/0x7e
[ 615.485497] RIP: 0033:0x7f46c2b12768
[ 615.485498] RSP: 002b:00007ffe5b77bda0 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
[ 615.485500] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f46c2b12768
[ 615.485501] RDX: 0000000000000001 RSI: 000055ca6fde7410 RDI: 0000000000000008
[ 615.485502] RBP: 00007ffe5b77bdb0 R08: 0000000000000000 R09: 0000000000000000
[ 615.485503] R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000008
[ 615.485504] R13: 000055ca6fde798e R14: 000055ca6fde7410 R15: 0000000000000001
[ 615.485507] </TASK>
[ 615.485521] INFO: task iscsid:31778 is blocked on a mutex likely owned by task iscsid:28580.
[ 615.485522] task:iscsid state:D stack:0 pid:28580 tgid:28580 ppid:1918 task_flags:0x400140 flags:0x00080801
[ 615.485524] Call Trace:
[ 615.485525] <TASK>
[ 615.485527] __schedule+0x420/0x1780
[ 615.485529] ? blk_mq_dispatch_rq_list+0x1bc/0x780
[ 615.485531] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485532] ? lock_timer_base+0x70/0x90
[ 615.485535] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485536] ? __mod_timer+0x242/0x3a0
[ 615.485539] schedule+0x28/0xa0
[ 615.485541] schedule_timeout+0xa3/0x120
[ 615.485542] ? __pfx_process_timeout+0x10/0x10
[ 615.485545] io_schedule_timeout+0x5b/0x90
[ 615.485547] wait_for_completion_io_timeout+0x93/0x180
[ 615.485550] blk_execute_rq+0xee/0x170
[ 615.485553] scsi_execute_cmd+0x10f/0x450
[ 615.485556] scsi_vpd_inquiry+0x7b/0xf0
[ 615.485559] scsi_get_vpd_buf+0x7a/0xd0
[ 615.485562] scsi_attach_vpd+0x25f/0x340
[ 615.485565] scsi_rescan_device+0x4c/0xe0
[ 615.485566] store_rescan_field+0x19/0x30
[ 615.485568] kernfs_fop_write_iter+0x16b/0x210
[ 615.485577] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485579] vfs_write+0x281/0x570
[ 615.485582] ksys_write+0x7b/0x110
[ 615.485584] do_syscall_64+0xce/0x570
[ 615.485587] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485588] ? __do_sys_newfstatat+0x6c/0xa0
[ 615.485592] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485594] ? do_syscall_64+0xce/0x570
[ 615.485596] ? __x64_sys_close+0x47/0xa0
[ 615.485622] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485627] ? __x64_sys_close+0x47/0xa0
[ 615.485631] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485634] ? do_syscall_64+0xce/0x570
[ 615.485637] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485640] ? __x64_sys_close+0x47/0xa0
[ 615.485643] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485645] ? do_syscall_64+0xce/0x570
[ 615.485649] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485652] ? do_syscall_64+0xce/0x570
[ 615.485654] ? srso_alias_return_thunk+0x5/0xfbef5
[ 615.485657] ? do_syscall_64+0x35/0x570
[ 615.485660] entry_SYSCALL_64_after_hwframe+0x76/0x7e
[ 615.485663] RIP: 0033:0x7f46c2b12768
[ 615.485670] RSP: 002b:00007ffe5b77bda0 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
[ 615.485673] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f46c2b12768
[ 615.485675] RDX: 0000000000000001 RSI: 000055ca6fde7410 RDI: 0000000000000008
[ 615.485677] RBP: 00007ffe5b77bdb0 R08: 0000000000000000 R09: 0000000000000000
[ 615.485678] R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000008
[ 615.485680] R13: 000055ca6fde798e R14: 000055ca6fde7410 R15: 0000000000000001
[ 615.485685] </TASK>
[ 705.988243] connection1:0: detected conn error (1020)
[ 706.220413] sd 12:0:0:0: Power-on or device reset occurred
[ 738.364710] INFO: task (udev-worker):29652 blocked for more than 122 seconds.
[ 738.364718] Tainted: G OE 7.3.0-rc4-2-MANJARO #1
[ 738.364721] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 738.364722] task:(udev-worker) state:D stack:0 pid:29652 tgid:29652 ppid:746 task_flags:0x400140 flags:0x00080002
[ 738.364728] Call Trace:
[ 738.364730] <TASK>
[ 738.364735] __schedule+0x420/0x1780
[ 738.364743] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.364748] ? __x64_sys_ioctl+0xb9/0x100
[ 738.364753] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.364756] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.364760] schedule+0x28/0xa0
[ 738.364763] schedule_preempt_disabled+0x16/0x30
[ 738.364766] rwsem_down_write_slowpath+0x2d7/0x7a0
[ 738.364771] ? __seccomp_filter+0x86/0x6e0
[ 738.364776] down_write+0x5c/0x60
[ 738.364779] blkdev_llseek+0x37/0x80
[ 738.364784] ksys_lseek+0x3c/0xb0
[ 738.364789] do_syscall_64+0xce/0x570
[ 738.364793] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.364796] ? do_syscall_64+0xce/0x570
[ 738.364799] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.364801] ? __handle_mm_fault+0xb90/0xf20
[ 738.364805] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.364808] ? __mod_memcg_state+0xd8/0x1a0
[ 738.364815] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.364817] ? count_memcg_events+0xc7/0x180
[ 738.364821] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.364823] ? handle_mm_fault+0x1b0/0x2e0
[ 738.364827] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.364829] ? do_user_addr_fault+0x235/0x730
[ 738.364834] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.364837] ? do_syscall_64+0x35/0x570
[ 738.364840] entry_SYSCALL_64_after_hwframe+0x76/0x7e
[ 738.364843] RIP: 0033:0x7f904f310dfb
[ 738.364861] RSP: 002b:00007ffe90128128 EFLAGS: 00000246 ORIG_RAX: 0000000000000008
[ 738.364864] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f904f310dfb
[ 738.364866] RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000019
[ 738.364868] RBP: 00007ffe90128180 R08: 0000000000000000 R09: 00007ffe901281b0
[ 738.364869] R10: 0000000000010000 R11: 0000000000000246 R12: 0000000000000000
[ 738.364871] R13: 000055c80a59e5f0 R14: 000055c80a59e5c0 R15: 000055c80a59e5c0
[ 738.364876] </TASK>
[ 738.364878] INFO: task (udev-worker):29652 is blocked on an rw-semaphore, but the owner is not found.
[ 738.364881] INFO: task iscsid:30150 blocked for more than 245 seconds.
[ 738.364883] Tainted: G OE 7.3.0-rc4-2-MANJARO #1
[ 738.364885] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 738.364886] task:iscsid state:D stack:0 pid:30150 tgid:30150 ppid:1918 task_flags:0x400140 flags:0x00080000
[ 738.364890] Call Trace:
[ 738.364891] <TASK>
[ 738.364894] __schedule+0x420/0x1780
[ 738.364898] ? dput.part.0+0x27/0x1a0
[ 738.364901] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.364904] ? mntput+0x25/0x70
[ 738.364908] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.364911] ? terminate_walk+0xd2/0xf0
[ 738.364914] ? security_file_post_open+0x48/0x130
[ 738.364919] schedule+0x28/0xa0
[ 738.364922] schedule_preempt_disabled+0x16/0x30
[ 738.364925] __mutex_lock.constprop.0+0x3e4/0x930
[ 738.364931] scsi_rescan_device+0x25/0xe0
[ 738.364936] store_rescan_field+0x19/0x30
[ 738.364940] kernfs_fop_write_iter+0x16b/0x210
[ 738.364946] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.364948] vfs_write+0x281/0x570
[ 738.364953] ksys_write+0x7b/0x110
[ 738.364957] do_syscall_64+0xce/0x570
[ 738.364960] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.364963] ? generic_fillattr+0x4d/0x130
[ 738.364967] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.364969] ? kernfs_iop_getattr+0x78/0x90
[ 738.364972] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.364974] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.364977] ? cp_new_stat+0x18e/0x1c0
[ 738.364982] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.364985] ? __do_sys_newfstatat+0x6c/0xa0
[ 738.364992] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.364994] ? do_syscall_64+0xce/0x570
[ 738.365000] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365002] ? do_syscall_64+0xce/0x570
[ 738.365005] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365008] ? __memcg_slab_free_hook+0x14b/0x1a0
[ 738.365012] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365014] ? kmem_cache_free+0x286/0x480
[ 738.365018] ? __x64_sys_close+0x47/0xa0
[ 738.365022] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365024] ? __x64_sys_close+0x47/0xa0
[ 738.365026] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365027] ? do_syscall_64+0xce/0x570
[ 738.365029] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365031] ? do_syscall_64+0xce/0x570
[ 738.365032] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365034] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365036] ? do_syscall_64+0x35/0x570
[ 738.365038] entry_SYSCALL_64_after_hwframe+0x76/0x7e
[ 738.365039] RIP: 0033:0x7f46c2b12768
[ 738.365041] RSP: 002b:00007ffe5b77bda0 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
[ 738.365043] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f46c2b12768
[ 738.365044] RDX: 0000000000000001 RSI: 000055ca6fde7410 RDI: 0000000000000008
[ 738.365045] RBP: 00007ffe5b77bdb0 R08: 0000000000000000 R09: 0000000000000000
[ 738.365046] R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000008
[ 738.365047] R13: 000055ca6fde798e R14: 000055ca6fde7410 R15: 0000000000000001
[ 738.365051] </TASK>
[ 738.365069] INFO: task iscsid:30150 is blocked on a mutex likely owned by task iscsid:28580.
[ 738.365071] task:iscsid state:D stack:0 pid:28580 tgid:28580 ppid:1918 task_flags:0x400140 flags:0x00080801
[ 738.365073] Call Trace:
[ 738.365074] <TASK>
[ 738.365075] __schedule+0x420/0x1780
[ 738.365078] ? blk_mq_dispatch_rq_list+0x1bc/0x780
[ 738.365081] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365082] ? lock_timer_base+0x70/0x90
[ 738.365086] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365087] ? __mod_timer+0x242/0x3a0
[ 738.365090] schedule+0x28/0xa0
[ 738.365092] schedule_timeout+0xa3/0x120
[ 738.365095] ? __pfx_process_timeout+0x10/0x10
[ 738.365097] io_schedule_timeout+0x5b/0x90
[ 738.365100] wait_for_completion_io_timeout+0x93/0x180
[ 738.365103] blk_execute_rq+0xee/0x170
[ 738.365106] scsi_execute_cmd+0x10f/0x450
[ 738.365109] ? __blk_mq_free_request+0xfc/0x120
[ 738.365113] scsi_vpd_inquiry+0x7b/0xf0
[ 738.365116] scsi_get_vpd_size+0x75/0x110
[ 738.365119] scsi_get_vpd_buf+0x26/0xd0
[ 738.365121] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365123] scsi_attach_vpd+0x1d2/0x340
[ 738.365126] scsi_rescan_device+0x4c/0xe0
[ 738.365128] store_rescan_field+0x19/0x30
[ 738.365130] kernfs_fop_write_iter+0x16b/0x210
[ 738.365133] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365134] vfs_write+0x281/0x570
[ 738.365138] ksys_write+0x7b/0x110
[ 738.365140] do_syscall_64+0xce/0x570
[ 738.365142] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365144] ? __do_sys_newfstatat+0x6c/0xa0
[ 738.365148] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365150] ? do_syscall_64+0xce/0x570
[ 738.365152] ? __x64_sys_close+0x47/0xa0
[ 738.365154] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365156] ? __x64_sys_close+0x47/0xa0
[ 738.365158] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365159] ? do_syscall_64+0xce/0x570
[ 738.365161] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365163] ? __x64_sys_close+0x47/0xa0
[ 738.365165] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365166] ? do_syscall_64+0xce/0x570
[ 738.365169] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365171] ? do_syscall_64+0xce/0x570
[ 738.365173] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365174] ? do_syscall_64+0x35/0x570
[ 738.365176] entry_SYSCALL_64_after_hwframe+0x76/0x7e
[ 738.365178] RIP: 0033:0x7f46c2b12768
[ 738.365180] RSP: 002b:00007ffe5b77bda0 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
[ 738.365181] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f46c2b12768
[ 738.365182] RDX: 0000000000000001 RSI: 000055ca6fde7410 RDI: 0000000000000008
[ 738.365183] RBP: 00007ffe5b77bdb0 R08: 0000000000000000 R09: 0000000000000000
[ 738.365184] R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000008
[ 738.365185] R13: 000055ca6fde798e R14: 000055ca6fde7410 R15: 0000000000000001
[ 738.365189] </TASK>
[ 738.365197] INFO: task iscsid:31778 blocked for more than 245 seconds.
[ 738.365199] Tainted: G OE 7.3.0-rc4-2-MANJARO #1
[ 738.365200] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 738.365200] task:iscsid state:D stack:0 pid:31778 tgid:31778 ppid:1918 task_flags:0x400140 flags:0x00080000
[ 738.365202] Call Trace:
[ 738.365203] <TASK>
[ 738.365205] __schedule+0x420/0x1780
[ 738.365207] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365209] ? do_sys_openat2+0x9c/0xe0
[ 738.365212] schedule+0x28/0xa0
[ 738.365214] schedule_preempt_disabled+0x16/0x30
[ 738.365216] __mutex_lock.constprop.0+0x3e4/0x930
[ 738.365220] scsi_rescan_device+0x25/0xe0
[ 738.365221] store_rescan_field+0x19/0x30
[ 738.365224] kernfs_fop_write_iter+0x16b/0x210
[ 738.365226] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365228] vfs_write+0x281/0x570
[ 738.365231] ksys_write+0x7b/0x110
[ 738.365233] do_syscall_64+0xce/0x570
[ 738.365235] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365237] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365238] ? do_syscall_64+0x35/0x570
[ 738.365240] entry_SYSCALL_64_after_hwframe+0x76/0x7e
[ 738.365242] RIP: 0033:0x7f46c2b12768
[ 738.365244] RSP: 002b:00007ffe5b77bda0 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
[ 738.365245] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f46c2b12768
[ 738.365246] RDX: 0000000000000001 RSI: 000055ca6fde7410 RDI: 0000000000000008
[ 738.365247] RBP: 00007ffe5b77bdb0 R08: 0000000000000000 R09: 0000000000000000
[ 738.365248] R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000008
[ 738.365249] R13: 000055ca6fde798e R14: 000055ca6fde7410 R15: 0000000000000001
[ 738.365252] </TASK>
[ 738.365268] INFO: task iscsid:31778 is blocked on a mutex likely owned by task iscsid:28580.
[ 738.365269] task:iscsid state:D stack:0 pid:28580 tgid:28580 ppid:1918 task_flags:0x400140 flags:0x00080801
[ 738.365271] Call Trace:
[ 738.365272] <TASK>
[ 738.365274] __schedule+0x420/0x1780
[ 738.365276] ? blk_mq_dispatch_rq_list+0x1bc/0x780
[ 738.365278] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365279] ? lock_timer_base+0x70/0x90
[ 738.365281] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365283] ? __mod_timer+0x242/0x3a0
[ 738.365285] schedule+0x28/0xa0
[ 738.365287] schedule_timeout+0xa3/0x120
[ 738.365289] ? __pfx_process_timeout+0x10/0x10
[ 738.365292] io_schedule_timeout+0x5b/0x90
[ 738.365294] wait_for_completion_io_timeout+0x93/0x180
[ 738.365297] blk_execute_rq+0xee/0x170
[ 738.365299] scsi_execute_cmd+0x10f/0x450
[ 738.365301] ? __blk_mq_free_request+0xfc/0x120
[ 738.365304] scsi_vpd_inquiry+0x7b/0xf0
[ 738.365307] scsi_get_vpd_size+0x75/0x110
[ 738.365310] scsi_get_vpd_buf+0x26/0xd0
[ 738.365312] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365314] scsi_attach_vpd+0x1d2/0x340
[ 738.365316] scsi_rescan_device+0x4c/0xe0
[ 738.365318] store_rescan_field+0x19/0x30
[ 738.365320] kernfs_fop_write_iter+0x16b/0x210
[ 738.365323] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365324] vfs_write+0x281/0x570
[ 738.365327] ksys_write+0x7b/0x110
[ 738.365330] do_syscall_64+0xce/0x570
[ 738.365332] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365334] ? __do_sys_newfstatat+0x6c/0xa0
[ 738.365338] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365340] ? do_syscall_64+0xce/0x570
[ 738.365341] ? __x64_sys_close+0x47/0xa0
[ 738.365344] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365345] ? __x64_sys_close+0x47/0xa0
[ 738.365347] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365349] ? do_syscall_64+0xce/0x570
[ 738.365351] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365353] ? __x64_sys_close+0x47/0xa0
[ 738.365355] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365356] ? do_syscall_64+0xce/0x570
[ 738.365359] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365360] ? do_syscall_64+0xce/0x570
[ 738.365362] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365364] ? do_syscall_64+0x35/0x570
[ 738.365366] entry_SYSCALL_64_after_hwframe+0x76/0x7e
[ 738.365368] RIP: 0033:0x7f46c2b12768
[ 738.365369] RSP: 002b:00007ffe5b77bda0 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
[ 738.365371] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f46c2b12768
[ 738.365372] RDX: 0000000000000001 RSI: 000055ca6fde7410 RDI: 0000000000000008
[ 738.365373] RBP: 00007ffe5b77bdb0 R08: 0000000000000000 R09: 0000000000000000
[ 738.365374] R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000008
[ 738.365375] R13: 000055ca6fde798e R14: 000055ca6fde7410 R15: 0000000000000001
[ 738.365378] </TASK>
[ 738.365380] INFO: task iscsid:33781 blocked for more than 122 seconds.
[ 738.365382] Tainted: G OE 7.3.0-rc4-2-MANJARO #1
[ 738.365383] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 738.365383] task:iscsid state:D stack:0 pid:33781 tgid:33781 ppid:1918 task_flags:0x400140 flags:0x00080000
[ 738.365385] Call Trace:
[ 738.365386] <TASK>
[ 738.365388] __schedule+0x420/0x1780
[ 738.365392] schedule+0x28/0xa0
[ 738.365394] schedule_preempt_disabled+0x16/0x30
[ 738.365395] __mutex_lock.constprop.0+0x3e4/0x930
[ 738.365399] scsi_rescan_device+0x25/0xe0
[ 738.365401] store_rescan_field+0x19/0x30
[ 738.365403] kernfs_fop_write_iter+0x16b/0x210
[ 738.365405] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365407] vfs_write+0x281/0x570
[ 738.365410] ksys_write+0x7b/0x110
[ 738.365412] do_syscall_64+0xce/0x570
[ 738.365415] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365417] ? do_syscall_64+0xce/0x570
[ 738.365421] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365422] ? do_syscall_64+0xce/0x570
[ 738.365424] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365426] ? do_syscall_64+0xce/0x570
[ 738.365428] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365429] ? do_syscall_64+0xce/0x570
[ 738.365431] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365433] ? do_syscall_64+0x35/0x570
[ 738.365435] entry_SYSCALL_64_after_hwframe+0x76/0x7e
[ 738.365436] RIP: 0033:0x7f46c2b12768
[ 738.365438] RSP: 002b:00007ffe5b77bda0 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
[ 738.365440] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f46c2b12768
[ 738.365441] RDX: 0000000000000001 RSI: 000055ca6fde7410 RDI: 0000000000000008
[ 738.365441] RBP: 00007ffe5b77bdb0 R08: 0000000000000000 R09: 0000000000000000
[ 738.365442] R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000008
[ 738.365443] R13: 000055ca6fde798e R14: 000055ca6fde7410 R15: 0000000000000001
[ 738.365447] </TASK>
[ 738.365457] INFO: task iscsid:33781 is blocked on a mutex likely owned by task iscsid:28580.
[ 738.365458] task:iscsid state:D stack:0 pid:28580 tgid:28580 ppid:1918 task_flags:0x400140 flags:0x00080801
[ 738.365460] Call Trace:
[ 738.365462] <TASK>
[ 738.365464] __schedule+0x420/0x1780
[ 738.365466] ? blk_mq_dispatch_rq_list+0x1bc/0x780
[ 738.365468] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365469] ? lock_timer_base+0x70/0x90
[ 738.365479] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365482] ? __mod_timer+0x242/0x3a0
[ 738.365484] schedule+0x28/0xa0
[ 738.365486] schedule_timeout+0xa3/0x120
[ 738.365488] ? __pfx_process_timeout+0x10/0x10
[ 738.365490] io_schedule_timeout+0x5b/0x90
[ 738.365492] wait_for_completion_io_timeout+0x93/0x180
[ 738.365495] blk_execute_rq+0xee/0x170
[ 738.365498] scsi_execute_cmd+0x10f/0x450
[ 738.365500] ? __blk_mq_free_request+0xfc/0x120
[ 738.365503] scsi_vpd_inquiry+0x7b/0xf0
[ 738.365506] scsi_get_vpd_size+0x75/0x110
[ 738.365508] scsi_get_vpd_buf+0x26/0xd0
[ 738.365510] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365512] scsi_attach_vpd+0x1d2/0x340
[ 738.365515] scsi_rescan_device+0x4c/0xe0
[ 738.365517] store_rescan_field+0x19/0x30
[ 738.365519] kernfs_fop_write_iter+0x16b/0x210
[ 738.365521] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365523] vfs_write+0x281/0x570
[ 738.365526] ksys_write+0x7b/0x110
[ 738.365528] do_syscall_64+0xce/0x570
[ 738.365531] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365532] ? __do_sys_newfstatat+0x6c/0xa0
[ 738.365537] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365538] ? do_syscall_64+0xce/0x570
[ 738.365540] ? __x64_sys_close+0x47/0xa0
[ 738.365542] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365544] ? __x64_sys_close+0x47/0xa0
[ 738.365546] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365548] ? do_syscall_64+0xce/0x570
[ 738.365550] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365553] ? __x64_sys_close+0x47/0xa0
[ 738.365556] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365558] ? do_syscall_64+0xce/0x570
[ 738.365561] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365562] ? do_syscall_64+0xce/0x570
[ 738.365564] ? srso_alias_return_thunk+0x5/0xfbef5
[ 738.365566] ? do_syscall_64+0x35/0x570
[ 738.365568] entry_SYSCALL_64_after_hwframe+0x76/0x7e
[ 738.365569] RIP: 0033:0x7f46c2b12768
[ 738.365571] RSP: 002b:00007ffe5b77bda0 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
[ 738.365573] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f46c2b12768
[ 738.365574] RDX: 0000000000000001 RSI: 000055ca6fde7410 RDI: 0000000000000008
[ 738.365575] RBP: 00007ffe5b77bdb0 R08: 0000000000000000 R09: 0000000000000000
[ 738.365576] R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000008
[ 738.365577] R13: 000055ca6fde798e R14: 000055ca6fde7410 R15: 0000000000000001
[ 738.365581] </TASK>
[ 849.860915] connection1:0: detected conn error (1020)
[ 849.860984] sd 12:0:0:0: [sda] tag#39 timing out command, waited 120s
[ 851.280727] sd 12:0:0:0: Power-on or device reset occurred
[ 861.244654] INFO: task kworker/u97:0:164 blocked in I/O wait for more than 122 seconds.
[ 861.244658] Tainted: G OE 7.3.0-rc4-2-MANJARO #1
[ 861.244660] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 861.244661] task:kworker/u97:0 state:D stack:0 pid:164 tgid:164 ppid:2 task_flags:0x4248160 flags:0x00080000
[ 861.244665] Workqueue: writeback wb_workfn (flush-8:0)
[ 861.244672] Call Trace:
[ 861.244673] <TASK>
[ 861.244676] __schedule+0x420/0x1780
[ 861.244681] ? __pfx_wbt_inflight_cb+0x10/0x10
[ 861.244685] ? srso_alias_return_thunk+0x5/0xfbef5
[ 861.244688] ? blk_mq_flush_plug_list+0x51/0x1a0
[ 861.244691] ? srso_alias_return_thunk+0x5/0xfbef5
[ 861.244693] ? __blk_flush_plug+0x105/0x170
[ 861.244695] ? srso_alias_return_thunk+0x5/0xfbef5
[ 861.244697] ? __pfx_wbt_inflight_cb+0x10/0x10
[ 861.244699] ? __pfx_wbt_cleanup_cb+0x10/0x10
[ 861.244701] schedule+0x28/0xa0
[ 861.244703] io_schedule+0x46/0x70
[ 861.244705] rq_qos_wait+0xe5/0x1b0
[ 861.244708] ? __pfx_rq_qos_wake_function+0x10/0x10
[ 861.244710] ? __pfx_wbt_inflight_cb+0x10/0x10
[ 861.244713] wbt_wait+0xbb/0x120
[ 861.244716] __rq_qos_throttle+0x27/0x40
[ 861.244718] blk_mq_submit_bio+0x2fc/0x9f0
[ 861.244721] submit_bio_noacct_nocheck+0x2a6/0x390
[ 861.244725] ext4_io_submit+0x40/0x70
[ 861.244729] ext4_do_writepages+0x4ce/0xf00
[ 861.244735] ? ext4_writepages+0xf0/0x1c0
[ 861.244737] ext4_writepages+0xf0/0x1c0
[ 861.244741] do_writepages+0xd0/0x160
[ 861.244746] ? __wake_up_common+0x8a/0xd0
[ 861.244750] __writeback_single_inode+0x53/0x390
[ 861.244753] ? srso_alias_return_thunk+0x5/0xfbef5
[ 861.244756] ? wbc_detach_inode+0x117/0x290
[ 861.244759] writeback_sb_inodes+0x284/0x5a0
[ 861.244768] __writeback_inodes_wb+0x5d/0x110
[ 861.244770] ? srso_alias_return_thunk+0x5/0xfbef5
[ 861.244773] wb_writeback+0x2dd/0x360
[ 861.244777] wb_workfn+0x36c/0x580
[ 861.244781] process_one_work+0x1d3/0x3c0
[ 861.244786] worker_thread+0x1b1/0x310
[ 861.244788] ? __pfx_worker_thread+0x10/0x10
[ 861.244790] kthread+0xe6/0x120
[ 861.244793] ? __pfx_kthread+0x10/0x10
[ 861.244795] ret_from_fork+0x2a9/0x340
[ 861.244798] ? __pfx_kthread+0x10/0x10
[ 861.244800] ret_from_fork_asm+0x1a/0x30
[ 861.244806] </TASK>
[ 861.244818] INFO: task kworker/u97:5:385 blocked in I/O wait for more than 122 seconds.
[ 861.244820] Tainted: G OE 7.3.0-rc4-2-MANJARO #1
[ 861.244821] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 861.244822] task:kworker/u97:5 state:D stack:0 pid:385 tgid:385 ppid:2 task_flags:0x4208060 flags:0x00080000
[ 861.244825] Workqueue: writeback wb_workfn (flush-8:0)
[ 861.244828] Call Trace:
[ 861.244829] <TASK>
[ 861.244830] __schedule+0x420/0x1780
[ 861.244833] ? srso_alias_return_thunk+0x5/0xfbef5
[ 861.244836] ? dcn20_update_plane_addr+0xaa/0x280 [amdgpu 87bec5fc1e6feb781d4f58d54b3179c7b980423c]
[ 861.245142] ? srso_alias_return_thunk+0x5/0xfbef5
[ 861.245144] ? __blk_flush_plug+0x105/0x170
[ 861.245146] ? srso_alias_return_thunk+0x5/0xfbef5
[ 861.245148] ? __pfx_wbt_inflight_cb+0x10/0x10
[ 861.245150] ? __pfx_wbt_cleanup_cb+0x10/0x10
[ 861.245152] schedule+0x28/0xa0
[ 861.245155] io_schedule+0x46/0x70
[ 861.245157] rq_qos_wait+0xe5/0x1b0
[ 861.245159] ? __pfx_rq_qos_wake_function+0x10/0x10
[ 861.245161] ? __pfx_wbt_inflight_cb+0x10/0x10
[ 861.245164] wbt_wait+0xbb/0x120
[ 861.245166] __rq_qos_throttle+0x27/0x40
[ 861.245168] blk_mq_submit_bio+0x2fc/0x9f0
[ 861.245172] submit_bio_noacct_nocheck+0x2a6/0x390
[ 861.245173] ? srso_alias_return_thunk+0x5/0xfbef5
[ 861.245175] ? srso_alias_return_thunk+0x5/0xfbef5
[ 861.245178] __block_write_full_folio+0x240/0x430
[ 861.245181] ? __pfx_blkdev_get_block+0x10/0x10
[ 861.245185] blkdev_writepages+0x9d/0xf0
[ 861.245186] ? psi_task_switch+0x1c6/0x2e0
[ 861.245190] ? __schedule+0x428/0x1780
[ 861.245192] do_writepages+0xd0/0x160
[ 861.245195] __writeback_single_inode+0x53/0x390
[ 861.245198] writeback_sb_inodes+0x284/0x5a0
[ 861.245207] __writeback_inodes_wb+0x5d/0x110
[ 861.245209] ? srso_alias_return_thunk+0x5/0xfbef5
[ 861.245211] wb_writeback+0x2dd/0x360
[ 861.245215] wb_workfn+0x36c/0x580
[ 861.245219] process_one_work+0x1d3/0x3c0
[ 861.245222] worker_thread+0x1b1/0x310
[ 861.245224] ? __pfx_worker_thread+0x10/0x10
[ 861.245226] kthread+0xe6/0x120
[ 861.245228] ? __pfx_kthread+0x10/0x10
[ 861.245230] ret_from_fork+0x2a9/0x340
[ 861.245232] ? __pfx_kthread+0x10/0x10
[ 861.245233] ret_from_fork_asm+0x1a/0x30
[ 861.245238] </TASK>
[ 861.245239] Future hung task reports are suppressed, see sysctl kernel.hung_task_warnings
Next i’ll try switching the network adapter, testing if its really Realtek related or iSCSI…
I hope i find a suitable adapter…
Found an old Intel X520 Adapter and it is working flawless as expected, no iSCSI or ext4 errors.
So definitely something with r8169 is borked since (including) 7.2.3…
inxi with intel:
❯ inxi -zv8
Kernel: 7.3.0-rc4-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
parameters: BOOT_IMAGE=/vmlinuz-7.3-x86_64
root=UUID=2265a3ee-fe59-4b09-b0ba-e389b7f9bdc7 rw quiet splash apparmor=1
resume=UUID=c0c12262-a803-4893-a052-04811cabcec1
nvme_core.default_ps_max_latency_us=0 pcie_aspm=off pcie_port_pm=off
Desktop: GNOME v: 50.5 tk: GTK v: 3.24.52 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 50.3 Distro: Manjaro
base: Arch Linux
Mobo: ASUSTeK model: TUF GAMING X670E-PLUS v: Rev 1.xx
Firmware: UEFI vendor: American Megatrends v: 3881 date: 06/17/2026
System RAM: total: 32 GiB available: 30.49 GiB used: 2.86 GiB (9.4%)
Array-1: capacity: 256 GiB slots: 4 modules: 2 EC: None
max-module-size: 64 GiB note: est.
Device-1: Channel-A DIMM 0 type: no module installed
Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: 4800 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: KF552C40-16 serial: <filter>
Device-3: Channel-B DIMM 0 type: no module installed
Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 4
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB
desc: 12x1024 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 4691 min/max: 415/5738 boost: disabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 4691 2: 4691 3: 4691
4: 4691 5: 4691 6: 4691 7: 4691 8: 4691 9: 4691 10: 4691 11: 4691 12: 4691
13: 4691 14: 4691 15: 4691 16: 4691 17: 4691 18: 4691 19: 4691 20: 4691
21: 4691 22: 4691 23: 4691 24: 4691 bogomips: 225162
apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
clflushopt clwb clzero cmov cmp_legacy constant_tsc cppc cpuid
cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt gfni ht
hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv lm mba
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx ospke osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb perfmon_v2
pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed
rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean vme
vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves xtopology
conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6900 XT]
vendor: XFX driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-2 empty: DP-1, DP-3, HDMI-A-1, Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:73af class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: ASUSTeK
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-4,HDMI-A-2,Writeback-2 bus-ID: 15:00.0 chip-ID: 1002:164e
class-ID: 0300 temp: 35.0 C
Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
compositor: gnome-shell driver: X: loaded: amdgpu dri: radeonsi gpu: amdgpu
display-ID: 0
Monitor-1: DP-2 model: Philips PHL 499P9 serial: <filter> built: 2021
res: 3840x1080 dpi: 82 gamma: 1.2 chroma: red: x: 0.675 y: 0.314 green:
x: 0.278 y: 0.647 blue: x: 0.149 y: 0.067 white: x: 0.314 y: 0.329
size: 1193x336mm (46.97x13.23") diag: 1239mm (48.8") modes: 3840x1080,
5120x1440, 2560x1440, 1920x1080, 1280x1024, 1280x720, 1024x768, 832x624,
800x600, 720x576, 720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unknown tag 112
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi
surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 vendor: amd mesa v: 26.2.3-arch1.1 glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 6900 XT (radeonsi navi21 ACO DRM
3.64 7.3.0-rc4-2-MANJARO) device-ID: 1002:73af memory: 15.62 GiB
unified: no display-ID: :0.0
API: Vulkan v: 1.4.357 layers: 10 device: 0 type: discrete-gpu name: AMD
Radeon RX 6900 XT (RADV NAVI21) driver: mesa radv v: 26.2.3-arch1.1
device-ID: 1002:73af surfaces: N/A device: 1 type: integrated-gpu name: AMD
Ryzen 9 7900X 12-Core Processor (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 26.2.3-arch1.1 device-ID: 1002:164e surfaces: N/A device: 2 type: cpu
name: llvmpipe (LLVM 22.1.8 256 bits) driver: mesa llvmpipe
v: 26.2.3-arch1.1 (LLVM 22.1.8) device-ID: 10005:0000 surfaces: N/A
Info: Tools: api: eglinfo, glxinfo, vulkaninfo gpu: lact,radeontop
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 15:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: ASUSTeK
bus-ID: 15:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k7.3.0-rc4-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.9 status: active with: 1: pipewire-pulse
Device-1: Intel 82599ES 10-Gigabit SFI/SFP+ Network driver: ixgbe v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 8 port: d000
bus-ID: 0b:00.0 chip-ID: 8086:10fb class-ID: 0200
IF: enp11s0 state: up speed: 10000 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic scope: global
IP v6: <filter> virtual: proto kernel_ll scope: link
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 0d:00.0
IF: eno1 state: up speed: 2500 Mbps duplex: full mac: <filter>
IF-ID-1: vlan11 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-2: vlan30 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-3: vlan32 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-4: vlan64 state: up speed: 10000 Mbps duplex: full mac: <filter>
Info: services: smbd, systemd-networkd, systemd-timesyncd, wpa_supplicant
Device-1: Realtek Bluetooth 5.4 Radio driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-5.3:7
chip-ID: 0bda:a728 class-ID: e001 serial: <filter>
Report: btmgmt ID: hci1 rfk-id: 1 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 24.56 TiB used: 9.94 TiB (40.5%)
ID-1: /dev/nvme0n1 maj-min: 259:13 vendor: Western Digital
model: WD Blue SN570 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 234140WD temp: 37.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with
Heatsink 1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7
temp: 39.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:12 vendor: Western Digital
fw-rev: 234140WD temp: 35.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 model: iSCSI Disk size: 10 TiB block-size:
physical: 32768 B logical: 512 B tech: N/A serial: <filter> fw-rev: 3100
scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 model: iSCSI Disk size: 10.01 TiB block-size:
physical: 16384 B logical: 512 B tech: N/A serial: <filter> fw-rev: 3100
scheme: GPT
ID-1: / raw-size: 128 GiB size: 125.68 GiB (98.19%) used: 21.79 GiB (17.3%)
fs: ext4 dev: /dev/nvme1n1p7 maj-min: 259:7 label: Manjaro Root
uuid: 2265a3ee-fe59-4b09-b0ba-e389b7f9bdc7
ID-2: /boot raw-size: 2 GiB size: 1.94 GiB (96.93%)
used: 217.7 MiB (11.0%) fs: ext3 dev: /dev/nvme1n1p6 maj-min: 259:6
label: Manjaro Boot uuid: ffd33209-8d4b-48e4-8eec-4d4b2f958ee2
ID-3: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%)
used: 114.2 MiB (45.3%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
label: N/A uuid: 58B0-1F88
ID-4: /home raw-size: 64 GiB size: 61.94 GiB (96.79%)
used: 48.52 GiB (78.3%) fs: ext4 dev: /dev/nvme2n1p3 maj-min: 259:16
label: Manjaro Homes uuid: 8a0c2ec7-053b-45a2-840a-241fac0c9500
ID-5: /mnt/Games-Linux-iSCSI raw-size: 10 TiB size: 9.92 TiB (99.20%)
used: 5.38 TiB (54.3%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
label: Games-Linux uuid: bb7dd672-3d2a-48c4-8c96-e351d50e7c33
ID-6: /mnt/Games-iSCSI raw-size: 10 TiB size: 10 TiB (100.00%)
used: 4.49 TiB (44.9%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18
label: Games-iSCSI uuid: BA924C0F924BCE97
ID-7: /mnt/cifs/dlna raw-size: N/A size: 13.62 TiB used: 640 KiB (0.0%)
fs: cifs dev: /dev/dlna
ID-1: swap-1 type: partition size: 48 GiB used: 0 KiB (0.0%) priority: -1
dev: /dev/nvme1n1p10 maj-min: 259:10 label: LSwap
uuid: c0c12262-a803-4893-a052-04811cabcec1
ID-1: /dev/nvme0n1p1 maj-min: 259:17 size: 1.62 TiB fs: btrfs
label: CachyOS Homes uuid: 3d25f519-7254-4e10-971b-26ec2f512e0d
ID-2: /dev/nvme1n1p11 maj-min: 259:11 size: 48 GiB fs: swap
label: CachyOS-Swap uuid: 79eed85e-fcd1-4766-8d10-431e55b3b84b
ID-3: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/nvme1n1p3 maj-min: 259:3 size: 255.11 GiB fs: ntfs
label: Win11Pro_x86_64 uuid: B236B1ED36B1B2A9
ID-5: /dev/nvme1n1p4 maj-min: 259:4 size: 905 MiB fs: ntfs label: N/A
uuid: 801A11A21A1195EE
ID-6: /dev/nvme1n1p5 maj-min: 259:5 size: 707 MiB fs: ntfs label: N/A
uuid: CE2252C12252AE69
ID-7: /dev/nvme1n1p8 maj-min: 259:8 size: 4 GiB fs: vfat label: N/A
uuid: 111C-8682
ID-8: /dev/nvme1n1p9 maj-min: 259:9 size: 160 GiB fs: btrfs
label: CachyOS Root uuid: e3dcb25a-e1ba-468b-ac23-648ce3812b26
ID-9: /dev/nvme2n1p1 maj-min: 259:14 size: 512 GiB fs: ntfs
label: Daten & FTP uuid: 60EAE03AEAE00E5A
ID-10: /dev/nvme2n1p2 maj-min: 259:15 size: 256 GiB fs: ntfs
label: lokale Games uuid: C6AAF89CAAF88A67
ID-11: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-4: 3-3:2 info: VIA Labs VL820 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2820
Hub-5: 3-3.1:3 info: Super Top 4-Port hub ports: 4 rev: 2.0
chip-ID: 14cd:8601 class-ID: 0900
Device-1: 3-3.1.2:4 info: VIA Labs PD 3.0 USB-C Device type: billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 2109:0102 class-ID: 1100 serial: <filter>
Hub-6: 4-0:1 info: super-speed hub ports: 5 rev: 3.1
Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-8: 5-5:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 5-5.1:4 info: QinHeng CH340 serial converter
type: <vendor specific> driver: ch341,ch341-uart interfaces: 1 rev: 1.1
chip-ID: 1a86:7523 class-ID: ff00
Device-2: 5-5.2:6 info: QinHeng CH340 serial converter
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 96mA
Device-3: 5-5.3:7 info: Realtek Bluetooth 5.4 Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:a728 class-ID: e001 serial: <filter>
Device-4: 5-8:3 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
serial: <filter>
Device-5: 5-9:5 info: MCT Elektronikladen aquaero type: keyboard,HID
driver: aquacomputer_d5next,usbhid interfaces: 3 rev: 2.0
chip-ID: 0c70:f001 class-ID: 0300 serial: <filter>
Hub-9: 6-0:1 info: super-speed hub ports: 6 rev: 3.1
Hub-10: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-11: 7-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 7-2.2:3 info: Razer USA RZ03-0203 Gaming Keyboard [BlackWidow
Chroma V2] type: keyboard,mouse driver: razerkbd,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 500mA
chip-ID: 1532:0221 class-ID: 0300
Device-2: 7-2.4:4 info: Maxxter Wireless Receiver type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 248a:8073 class-ID: 0301
Hub-12: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-13: 9-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-14: 10-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-15: 11-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
System Temperatures: cpu: 38.0 C mobo: 31.0 C
Fan Speeds (rpm): cpu: 0 fan-1: 0 fan-2: 3461 fan-3: 0 fan-4: 0 fan-5: 0
fan-6: 0 fan-7: 0
GPU: device: amdgpu temp: 35.0 C device: amdgpu temp: 37.0 C mem: 32.0 C
fan: 0 watts: 13.00
Packages: pm: pacman pkgs: 1623 libs: 466 tools: gnome-software,pamac
pm: flatpak pkgs: 0
1: https://ftp.gwdg.de/pub/linux/manjaro/unstable/$repo/$arch
2: https://mirror.alpix.eu/manjaro/unstable/$repo/$arch
Processes:
CPU top: 5 of 535
1: cpu: 11.7% command: localsearch-extractor-3 pid: 27189
mem: 41.7 MiB (0.1%)
2: cpu: 10.3% command: gnome-system-monitor pid: 8668
mem: 210.8 MiB (0.6%)
3: cpu: 5.4% command: doublecmd pid: 8409 mem: 215.4 MiB (0.6%)
4: cpu: 5.2% command: coolercontrold pid: 1805 mem: 112.2 MiB (0.3%)
5: cpu: 3.3% command: gnome-shell pid: 4595 mem: 287.7 MiB (0.9%)
Memory top: 5 of 535
1: mem: 287.7 MiB (0.9%) command: gnome-shell pid: 4595 cpu: 3.3%
2: mem: 252.1 MiB (0.8%) command: duplicati pid: 7950 cpu: 0.7%
3: mem: 222.6 MiB (0.7%) command: nautilus pid: 8463 cpu: 0.4%
4: mem: 215.4 MiB (0.6%) command: doublecmd pid: 8409 cpu: 5.4%
5: mem: 214.6 MiB (0.6%) command: coolercontrol pid: 4828 cpu: 0.1%
Processes: 535 Power: uptime: 9m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.14 GiB services: gsd-power,upowerd
Init: systemd v: 261 default: graphical tool: systemctl
Compilers: clang: 22.1.8 gcc: 16.2.1 Shell: Zsh v: 5.9.2 running-in: kgx
inxi: 3.3.41
