Manjaro install halts at Failed to start Light Display Manager
Booting with UEFI (Secure Boot disabled) from manjaro-mate-21.1.2-210907-linux513.iso on an IODD-2531 and only one monitor plugged in (via DisplayPort) with either open source or proprietary video drivers:
fr_333_size640
The details:
  Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
  misobasedir=manjaro misolabel=MANJARO_MATE_2112 quiet systemd.show_status=1
  driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
  Console: tty 3 DM: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
  Mobo: ASUSTeK model: ROG CROSSHAIR VIII IMPACT v: Rev X.0x serial: <filter>
  UEFI: American Megatrends v: 3801 date: 07/30/2021
  RAM: total: 31.26 GiB used: 1.12 GiB (3.6%)
  Array-1: capacity: 128 GiB slots: 2 EC: None max-module-size: 64 GiB
  note: est.
  Device-1: DIMM_A1 size: 16 GiB speed: 2666 MT/s type: DDR4
  detail: synchronous unbuffered (unregistered) bus-width: 64 bits
  total: 64 bits manufacturer: Crucial Technology part-no: BL16G32C16U4B.16FE
  serial: <filter>
  Device-2: DIMM_B1 size: 16 GiB speed: 2666 MT/s type: DDR4
  serial: <filter>
  Info: 6-Core model: AMD Ryzen 5 5600X socket: AM4 bits: 64 type: MT MCP
  arch: Zen 3 family: 19 (25) model-id: 21 (33) stepping: 0 microcode: A201016
  cache: L1: 384 KiB L2: 3 MiB L3: 32 MiB bogomips: 88659
  Speed: 2195 MHz min/max: 2200/3700 MHz base/boost: 3700/4650 boost: enabled
  volts: 1.1 V ext-clock: 100 MHz Core speeds (MHz): 1: 2195 2: 2555 3: 2245
  4: 2871 5: 2872 6: 2414 7: 2566 8: 2870 9: 3587 10: 2870 11: 2872 12: 2872
  cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
  flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
  invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
  movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
  overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
  perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
  rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
  sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
  topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean
  vme vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  xsaves
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
  STIBP: always-on, RSB filling
  Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: eVga.com.
  driver: N/A alternate: nouveau bus-ID: 09:00.0 chip-ID: 10de:2504
  class-ID: 0300
  Display: server: X.org 1.20.13 driver: loaded: N/A unloaded: modesetting
  alternate: fbdev,nouveau,nv,vesa tty: 128x48
  Message: Advanced graphics data unavailable in console for root.
  Device-1: NVIDIA vendor: eVga.com. driver: snd_hda_intel v: kernel
  bus-ID: 09:00.1 chip-ID: 10de:228e class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel bus-ID: 0b:00.4 chip-ID: 1022:1487
  class-ID: 0403
  Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
  Sound Server-3: PulseAudio v: 15.0 running: no
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
  chip-ID: 8086:2723 class-ID: 0280
  Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
  port: f000 bus-ID: 05:00.0 chip-ID: 8086:1539 class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IP v6: <filter> type: noprefixroute scope: global
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-5:2
  Local Storage: total: 5.57 TiB used: 0 KiB (0.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket 4.0 Plus
  lanes: 4 type: SSD serial: <filter> rev: RKT4P1.2 temp: 34.9 C scheme: GPT
  SMART: yes health: PASSED on: 6d 11h cycles: 62 read-units: 875,577 [448 GB]
  written-units: 383,640 [196 GB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
  model: WDS400T2B0A-00SM50 size: 3.64 TiB block-size: physical: 512 B
  logical: 512 B sata: 3.3 speed: 6.0 Gb/s type: SSD serial: <filter>
  rev: 20WD temp: 29 C
  SMART: yes state: enabled health: PASSED on: 2 hrs cycles: 7 read: 0 KiB
  written: 0 KiB
  ID-3: /dev/sdb maj-min: 8:16 type: USB model: iODD External HDD
  drive model: SSD 840 EVO 120GB family: based SSDs size: 111.79 GiB
  block-size: physical: 512 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s
  type: SSD serial: <filter> drive serial: <filter> rev: EXT0BB6Q temp: 29 C
  scheme: MBR
  SMART: yes state: enabled health: PASSED on: 293d 10h cycles: 568
  written: 1.95 TiB
  Optical-1: /dev/sr0 vendor: iODD model: Virtual CD-Rom rev:
  dev-links: cdrom
  Features: speed: 8 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw
  state: running
  Message: No partition data found.
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: N/A label: N/A
  uuid: N/A
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 1.82 TiB fs: ntfs label: Storage
  uuid: 50484C1B484BFE6A
  ID-3: /dev/sdb1 maj-min: 8:17 size: 111.78 GiB fs: ntfs label: N/A
  uuid: 7340657B173F41DB
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
  Device-1: 1-5:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
  class-ID: e001
  Device-2: 1-6:3 info: ASUSTek AURA LED Controller type: HID
  driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
  chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
  Device-1: 2-3:2 info: Fujitsu iodd2531 type: Mass Storage
  driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 744mA
  chip-ID: 04c5:2028 class-ID: 0806 serial: <filter>
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 5-2:2 info: Logitech G9 Laser Mouse type: Mouse,HID
  driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 98mA
  chip-ID: 046d:c048 class-ID: 0300 serial: <filter>
  Hub-6: 5-3:3 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  power: 100mA chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 5-3.3:5 info: Microdia Foot Switch type: Keyboard,Mouse
  driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
  power: 100mA chip-ID: 0c45:7403 class-ID: 0301
  Device-2: 5-3.4:6 info: Microdia Foot Switch type: Keyboard,Mouse
  Device-3: 5-4:4 info: Winbond Varmilo Mechanical Keyboard type: Keyboard,HID
  driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
  power: 500mA chip-ID: 0416:e324 class-ID: 0300
  Hub-7: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 34.4 C mobo: N/A
  Processes: 237 Uptime: 11m wakeups: 0 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: N/A Packages: pacman: 1043 lib: 282 Shell: Bash (sudo)
  v: 5.1.8 running-in: tty 3 inxi: 3.3.06
lightdm.log
[+0.00s] DEBUG: Logging to /var/log/lightdm/lightdm.log
[+0.00s] DEBUG: Starting Light Display Manager 1.30.0, UID=0 PID=2470
[+0.00s] DEBUG: Loading configuration dirs from /usr/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /usr/local/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /etc/xdg/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration from /etc/lightdm/lightdm.conf
[+0.00s] DEBUG: Registered seat module local
[+0.00s] DEBUG: Registered seat module xremote
[+0.00s] DEBUG: Using D-Bus name org.freedesktop.DisplayManager
[+0.00s] DEBUG: _g_io_module_get_default: Found default implementation local (GLocalVfs) for ‘gio-vfs’
[+0.00s] DEBUG: Monitoring logind for seats
[+0.00s] DEBUG: New seat added from logind: seat0
[+0.00s] DEBUG: Seat seat0: Loading properties from config section Seat:*
[+0.01s] DEBUG: Seat seat0 has property CanMultiSession=no
[+0.01s] DEBUG: Seat seat0: Starting
[+0.01s] DEBUG: Seat seat0: Creating user session
[+0.01s] DEBUG: Loading users from org.freedesktop.Accounts
[+0.01s] DEBUG: User /org/freedesktop/Accounts/User1000 added
[+0.01s] DEBUG: Seat seat0: Creating display server of type x
[+0.01s] DEBUG: Could not run plymouth --ping: Failed to execute child process “plymouth” (No such file or directory)
[+0.01s] DEBUG: Using VT 7
[+0.01s] DEBUG: Seat seat0: Starting local X display on VT 7
[+0.01s] DEBUG: XServer 0: Logging to /var/log/lightdm/x-0.log
[+0.01s] DEBUG: XServer 0: Writing X server authority to /run/lightdm/root/:0
[+0.01s] DEBUG: XServer 0: Launching X Server
[+0.01s] DEBUG: Launching process 2475: /usr/bin/X :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+0.01s] DEBUG: XServer 0: Waiting for ready signal from X server :0
[+0.01s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+0.01s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+0.02s] DEBUG: Seat seat0 changes active session to
[+0.02s] DEBUG: Process 2475 exited with return value 1
[+0.02s] DEBUG: XServer 0: X server stopped
[+0.02s] DEBUG: Releasing VT 7
[+0.02s] DEBUG: XServer 0: Removing X server authority /run/lightdm/root/:0
[+0.02s] DEBUG: Seat seat0: Display server stopped
[+0.02s] DEBUG: Seat seat0: Stopping session
[+0.02s] DEBUG: Seat seat0: Session stopped
[+0.02s] DEBUG: Seat seat0: Stopping display server, no sessions require it
[+0.02s] DEBUG: Seat seat0: Active display server stopped, starting greeter
[+0.02s] DEBUG: Seat seat0: Creating greeter session
[+0.02s] DEBUG: Seat seat0: Creating display server of type x
[+0.02s] DEBUG: Using VT 7
[+0.02s] DEBUG: Seat seat0: Starting local X display on VT 7
[+0.02s] DEBUG: XServer 0: Logging to /var/log/lightdm/x-0.log
[+0.02s] DEBUG: XServer 0: Writing X server authority to /run/lightdm/root/:0
[+0.02s] DEBUG: XServer 0: Launching X Server
[+0.02s] DEBUG: Launching process 2476: /usr/bin/X :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+0.02s] DEBUG: XServer 0: Waiting for ready signal from X server :0
[+0.03s] DEBUG: Process 2476 exited with return value 1
[+0.03s] DEBUG: XServer 0: X server stopped
[+0.03s] DEBUG: Releasing VT 7
[+0.03s] DEBUG: XServer 0: Removing X server authority /run/lightdm/root/:0
[+0.03s] DEBUG: Seat seat0: Display server stopped
[+0.03s] DEBUG: Seat seat0: Stopping session
[+0.03s] DEBUG: Seat seat0: Session stopped
[+0.03s] DEBUG: Seat seat0: Stopping display server, no sessions require it
[+0.03s] DEBUG: Seat seat0: Stopping; greeter display server failed to start
[+0.03s] DEBUG: Seat seat0: Stopped
[+0.03s] DEBUG: Required seat has stopped
[+0.03s] DEBUG: Stopping display manager
[+0.03s] DEBUG: Display manager stopped
[+0.03s] DEBUG: Stopping daemon
[+0.03s] DEBUG: Exiting with return value 1
drivers nvida are not loaded
have you selected no free drivers on boot USB live Iso ?
if you do not get display manager you should check in
sudo journalctl -b0
I have.
I have tried both Boot with open source drivers and Boot with proprietary drivers however the result is the same. Previous inxi output was from ‘proprietary’, here is the output after booting with ‘open source’:
  driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  Console: tty 2 DM: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
  RAM: total: 31.26 GiB used: 1.2 GiB (3.9%)
  note: est.
  serial: <filter>
  serial: <filter>
  cache: L1: 384 KiB L2: 3 MiB L3: 32 MiB bogomips: 88662
  Speed: 3591 MHz min/max: 2200/3700 MHz base/boost: 3700/4650 boost: enabled
  volts: 1.1 V ext-clock: 100 MHz Core speeds (MHz): 1: 3591 2: 2193 3: 2569
  4: 2546 5: 2869 6: 2432 7: 2582 8: 2870 9: 3584 10: 2876 11: 2870 12: 2869
  xsaves
  class-ID: 0300
  Display: server: X.org 1.20.13 driver: loaded: nouveau unloaded: modesetting
  alternate: fbdev,nv,vesa tty: 128x48
  class-ID: 0403
  lanes: 4 type: SSD serial: <filter> rev: RKT4P1.2 temp: 22.9 C scheme: GPT
  SMART: yes health: PASSED on: 6d 14h cycles: 63 read-units: 875,604 [448 GB]
  rev: 20WD temp: 25 C
  SMART: yes state: enabled health: PASSED on: 4 hrs cycles: 8 read: 0 KiB
  written: 0 KiB
  type: SSD serial: <filter> drive serial: <filter> rev: EXT0BB6Q temp: 26 C
  scheme: MBR
  SMART: yes state: enabled health: PASSED on: 293d 12h cycles: 569
  written: 1.95 TiB
  dev-links: cdrom
  state: running
  uuid: N/A
  class-ID: e001
  System Temperatures: cpu: 32.1 C mobo: N/A
  Processes: 260 Uptime: 5m wakeups: 0 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: N/A Packages: pacman: 1059 lib: 291 Shell: Bash (sudo)
  v: 5.1.8 running-in: tty 2 inxi: 3.3.06
Output of journalctl command (too long for the forum):
https://pastebin.ubuntu.com/p/fpxddTC7zS/
i see this in the log
nouveau
Oct 06 06:56:08 manjaro-mate kernel: nouveau 0000:09:00.0: unknown chipset (b76000a1)
errors on connexion
Oct 06 06:56:09 manjaro-mate pacman-mirrors[702]: ::WARNING https://repo.manjaro.org 'Connection: HTTPSConnectionPool(host='repo.manjaro.org', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fcba3efd970>: Failed to establish a new connection: [Errno -2] Name or service not known'))'
Oct 06 06:56:09 manjaro-mate pacman-mirrors[702]: ::WARNING https://wikipedia.org 'Connection: HTTPSConnectionPool(host='wikipedia.org', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fcba3efdca0>: Failed to establish a new connection: [Errno -2] Name or service not known'))'
Oct 06 06:56:09 manjaro-mate pacman-mirrors[702]: ::WARNING https://bitbucket.org 'Connection: HTTPSConnectionPool(host='bitbucket.org', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fcba3efdac0>: Failed to establish a new connection: [Errno -2] Name or service not known'))'
Oct 06 06:56:09 manjaro-mate pacman-mirrors[702]: ::INFO Internet connection appears to be down
Oct 06 06:56:09 manjaro-mate pacman-mirrors[702]: ::INFO Mirror ranking is not available
Oct 06 06:56:09 manjaro-mate pacman-mirrors[702]: ::INFO Mirror list is generated using random method
Oct 06 06:56:09 manjaro-mate pacman-mirrors[702]: ::INFO Writing mirror list
Oct 06 06:56:08 manjaro-mate kernel: spl: loading out-of-tree module taints kernel.
Oct 06 06:56:08 manjaro-mate kernel: spl: module verification failed: signature and/or required key missing - tainting kernel
no driver loaded ( nouveau or nvidia ) for this video card
Oct 06 06:56:12 manjaro-mate audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 06 06:56:12 manjaro-mate audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 06 06:56:12 manjaro-mate systemd[1]: lightdm.service: Start request repeated too quickly.
Oct 06 06:56:12 manjaro-mate systemd[1]: lightdm.service: Failed with result 'exit-code'.
Oct 06 06:56:12 manjaro-mate systemd[1]: Failed to start Light Display Manager.
Oct 06 06:56:43 manjaro-mate systemd-xdg-autostart-generator[1770]: Exec binary '/usr/bin/mntray' does not exist: No such file or directory
Oct 06 06:56:43 manjaro-mate systemd-xdg-autostart-generator[1770]: Not generating service for XDG autostart app-mntray@autostart.service, error parsing Exec= line: No such file or directory
error on sound output
Oct 06 06:56:09 manjaro-mate systemd[1]: Condition check resulted in Manage Sound Card State (restore and store) being skipped.
Oct 06 06:56:09 manjaro-mate alsactl[859]: /usr/bin/alsactl: load_state:1651: Cannot open /var/lib/alsa/asound.state for reading: No such file or directory
Oct 06 06:56:09 manjaro-mate alsactl[859]: alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA NVidia at 0xfc080000 irq 133)
Oct 06 06:56:09 manjaro-mate alsactl[859]: alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -6
Oct 06 06:56:09 manjaro-mate alsactl[859]: Found hardware: "HDA-Intel" "Nvidia GPU 9f HDMI/DP" "HDA:10de009f,38423656,00100100" "0x3842" "0x3656"
Oct 06 06:56:09 manjaro-mate alsactl[859]: Hardware is initialized using a generic method
Oct 06 06:56:09 manjaro-mate alsactl[859]: alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HD-Audio Generic at 0xfca00000 irq 135)
Oct 06 06:56:09 manjaro-mate alsactl[859]: alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:1 use case configuration -6
Oct 06 06:56:09 manjaro-mate alsactl[859]: Found hardware: "HDA-Intel" "Realtek ALC1220" "HDA:10ec1220,10438784,00100101" "0x1043" "0x8784"
others questions about CPU & Memory & Motherboard
you should use 3200/3000/2933/2800/2666/2400/2133
better speed memory if possible 2666 → 3200
have you underclocked you CPU Volt ?
CPU and motherboard are as you see. Memory is Crucial Ballistix 3200 MHz (BL2K16G32C16U4B). Never over/underclocked the CPU.
Without any changes to the hardware config ubuntu-mate-21.04-desktop-amd64.iso booted and installed without issue (even had sound in the installer). So I am going with that, at least for now.
Thanks
