in the other linux distros that I have the sensor plugin shows my Nvidia temperature, but not here , it only shows coretemp and acpi .
check you have lm_sensors installed
no I only use the xfce one
I just done a reinstall and that is the plugin that I always use, I have it on Mintxfce and MX, and in those it works perfect, on those panels I can see both, my CPU and the GPU temperatures, but in here the NVIDIA option is not showing up
a quick google tells me what you need is in aur, the standard sensor is not built with nvidia support.
thank you very much !!!
