Hi there,
I recently tried to update my qt5-styleplugins through pamac because some app failed moaning about the mismatching dependency. Usually that works fine but this time pamac somehow got stuck for a long time before I killed it using ctrl+c.
Now my system is in a weird state (it does still boot at least):
sudo pacman -S archlinux-keyring
-bash: sed: command not found
-bash: sudo: Kommando nicht gefunden.
When I use “su” to get a root shell, it does miss pacman too which is not nice for possibly installing stuff back:
pacman -S sed sudo
bash: pacman: Kommando nicht gefunden.
also pamac
is not happy anymore:
pamac -S sed sudo
pamac: error while loading shared libraries: libalpm.so.13: cannot open shared object file: No such file or directory
More info:
which sed sudo pacman pamac
which: no sed in (/home/johannes/.local/bin:/home/johannes/.local/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/var/lib/snapd/snap/bin:/usr/lib/jvm/default/bin:/home/johannes/dev/flutter/bin:/run/storage/encrypted/data/code/go/bin:/home/johannes/bin:/home/johannes/.local/share/gem/ruby/3.0.0/bin:/home/johannes/.cargo/bin:/var/lib/snapd/snap/bin:/home/johannes/dev/flutter/bin:/run/storage/encrypted/data/code/go/bin:/run/storage/encrypted/data/code/go/bin:/home/johannes/.local/share/gem/ruby/3.0.0/bin:/home/johannes/.cargo/bin:/var/lib/snapd/snap/bin)
which: no sudo in (/home/johannes/.local/bin:/home/johannes/.local/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/var/lib/snapd/snap/bin:/usr/lib/jvm/default/bin:/home/johannes/dev/flutter/bin:/run/storage/encrypted/data/code/go/bin:/home/johannes/bin:/home/johannes/.local/share/gem/ruby/3.0.0/bin:/home/johannes/.cargo/bin:/var/lib/snapd/snap/bin:/home/johannes/dev/flutter/bin:/run/storage/encrypted/data/code/go/bin:/run/storage/encrypted/data/code/go/bin:/home/johannes/.local/share/gem/ruby/3.0.0/bin:/home/johannes/.cargo/bin:/var/lib/snapd/snap/bin)
which: no pacman in (/home/johannes/.local/bin:/home/johannes/.local/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/var/lib/snapd/snap/bin:/usr/lib/jvm/default/bin:/home/johannes/dev/flutter/bin:/run/storage/encrypted/data/code/go/bin:/home/johannes/bin:/home/johannes/.local/share/gem/ruby/3.0.0/bin:/home/johannes/.cargo/bin:/var/lib/snapd/snap/bin:/home/johannes/dev/flutter/bin:/run/storage/encrypted/data/code/go/bin:/run/storage/encrypted/data/code/go/bin:/home/johannes/.local/share/gem/ruby/3.0.0/bin:/home/johannes/.cargo/bin:/var/lib/snapd/snap/bin)
/usr/bin/pamac
I can boot the system, I can successfully run firefox, watch YouTube and so on. Party broken describes it best I guess.
Any ideas what I can do to fix my issues?
Thanks for your help!
Joh
