I am trying to update eclipse-java, but while installing, it also compiles eclipse for various other languages and ultimately runs out of space on the partition.
Is it possible to tell yay to use a different location to store the build files during this process so that it does not run out of space?
Except I think I in fact have the eclipse package installed. I only need Java though, not any of the other languages.
The AUR page says to remove eclipse-common, but doing so gives another error as removing eclipse-common breaks dependency 'eclipse-common=4.14-1' required by eclipse-java
try to remove all eclipse-* packages you compiled from AUR and start from scratch. You won’t lose any user config. pacman -Qm will list all AUR packages.
