Remove it.
Not necessary at all.
Run sbctl to create your own personal keys
sudo sbctl create-keys
Then edit the file /etc/mkinitcpio.d/<kernel>.preset.
Example /etc/mkinitcpio.d/linux618.preset
$ cat /etc/mkinitcpio.d/linux618.preset
# mkinitcpio preset file for the '6.18-x86_64' package
#ALL_config="/etc/mkinitcpio.conf"
ALL_kver="/boot/vmlinuz-6.18-x86_64"
PRESETS=('default')
#PRESETS=('default' 'fallback')
#default_config="/etc/mkinitcpio.conf"
#default_image="/boot/initramfs-6.18-x86_64.img"
default_uki="/efi/EFI/Linux/manjaro-6.18.efi"
default_options="--splash /usr/share/systemd/bootctl/splash-manjaro.bmp"
#fallback_config="/etc/mkinitcpio.conf"
#fallback_image="/boot/initramfs-6.18-x86_64-fallback.img"
#fallback_uki="/efi/EFI/Linux/manjaro-6.18-x86_64-fallback.efi"
#fallback_options="-S autodetect"
Create the folder /boot/efi/EFI/Linux
sudo mkdir /boot/efi/EFI/Linux
After you have created the folder run mkinitcpio
sudo mkinitcpio -p linux618
The endresult is a UKI (Unified Kernel Image) which will get signed when you run mkinitcpio.
Create an entry in your systems firmware for the new UKI (assuming your primary disk is nvme0n1 and the first partition is your EFI partition)
sudo efibootmgr --create --disk /dev/nvme0n1 --part 1 --loader "/EFI/Linux/manjaro-6.18.efi" --label "Manjaro 6.18" --unicode
Reboot into your system’s firmware
systemctl reboot firmware-setup
Then ensure Secure Boot is changed to setup mode - save the changes and reboot into your Manjaro Linux system.
When booted open a terminal and enroll your personal secure boot key to the firmware (it is important that you add the –microsoft flag, - if you don’t you may brick your system)
$ sudo sbctl enroll-keys --microsoft
[sudo] password for nix:
Enrolling keys to EFI variables...
With vendor keys from microsoft...✓
Enrolled keys to the EFI variables!
Check
$ sbctl status
Installed: ✓ sbctl is installed
Owner GUID: 6203b16f-d516-4f71-9b0a-215c046f3bdc
Setup Mode: ✓ Disabled
Secure Boot: ✗ Disabled
Vendor Keys: microsoft
Reboot into your firmware and enable secure boot - save the changes and reboot
Check
$ sbctl status
Secure Boot: ✓ Enabled
Congratulations - finally reboot into your system’s firmware and password protect the access.
