Secondary Monitor colours too dark with 7.2 kernel
On Kernel 7.2 my secondary monitor has the colours far too dark. Going back to 7.1 and 7.0 the issue is not present. As I have not updated in a while I wasn’t sure where the issue came in and at first thought it might be related to this:
Which then led me to find that I do not have that colour accuracy option in KDE settings. Searching for it in settings tells me that it is present under Display Configuration, but I cannot actually see that setting.
Any ideas on why kernel 7.2 is causing this issue or why the colour accuracy option is missing for me in KDE settings?
Both of these kernels have reached EOL.
I suggest kernel 6.18 (LTS) instead, and perhaps 6.12 (LTS) as your fallback. When kernel 7.3 in more mature, you might try that for size.
None, but I’m aware there have been a few similar reports - the general resolve seems to be reverting to the LTS kernel, for the time being until more information is known.
Well I’ll just stick with 7.1 for now, its only just EOL. I have the LTS kernels installed as a fallback.
Honestly more concerned right now about the fact that I appear to be missing a setting that should supposedly be there as that issue is present regardless of what kernel version I am on.
you will have to wait for drm - amdgpu
Do not use EOL, you won’t have any security updates.
You can install the 7.2 kernel with mhwd-kernel -i linux72, or linux618 if you want LTS.
Having security updates is absolutely necessary, your system will be subject to vulnerabilities running on EOL.
Was that in response to me? If so what do you mean?
I know what I am doing, 7.1 only just went EOL in this release, most likely by the next release 7.3 will be available. I won’t be getting any updates in between anyway. If 7.3 is not out by then I will adjust my active kernel at that time.
check on report issues
@koeshi
I’ve moved your post and its replies to this dedicated Topic for individual attention. :slight_smile:
@stephane is correct that no updates will be forthcoming for kernel 7.1 now that it’s EOL (two weeks ago). You should also be aware that continuing to use an EOL kernel technically places you in an unsupported state.
Just two of the reasons 6.18 (LTS) was recommended. :wink:
Well, kernel 7.3 RC3 (a release candidate only) was released almost a week ago and is available in Unstable branch. If you wanted to try it now you would need to make the switch from Stable to Unstable.
Linus Torvalds has announced the third release candidate (RC3) for the upcoming Linux Kernel 7.3 version on September 13, 2026. This release lands right on schedule as the testing phase for Linux 7.3 gains momentum.
@soundofthunder
I understand all of that, however it isn’t really EOL until a release cycle goes by without it getting updated. Also even in Manjaro Settings Manager while 7.0 is marked Unsupported 7.1 isn’t.
@stephane
Sorry if I am just being stupid, but I am not sure what you want me to do here. Are you saying that the issue is already reported or that I should raise it there?
Mod edit:- Please avoid consecutive posts. Leverage the @mentions feature instead to address different members from the same post.
Is there any chance you could provide some system information, so that this thread can (hopefully) progress towards a resolution of the issue?
Please provide the output of:
inxi --filter --verbosity=8
inxi -zv8
Running `inxi` in `chroot`
Providing `inxi` when you cannot access your desktop environment
Any code or command output (such as inxi output) should be placed within a scrollable pre-formatted text enclosure according to forum guidelines.
See here for instructions :point_down:
[Mini How-To] format code or command output
Select and copy all the text in the Terminal window (minus the prompt, if you are using zsh).
Then paste the output in between two lines containing three backticks:
or three tildes:
Or:
Copy & paste, then highlight the pasted text and click the </> button at the top of the reply window (easier for smaller outputs).
…and for a very different reason – kernel information in MSM is only updated when the package itself is updated, and that happens less regularly than packages inherited from Arch.
Of course, now there is manjaro-settings-manager-qt6 as well; I’m uncertain whether the infrequent updates hold true for that.
In any case, my comments regarding kernel 7.1 were ancillary and clarifying by nature – the main takeaway which may have been of interest was that you could try kernel 7.3 (rc3) even now, if you wished.
