Second monitor stopped working after update (HUION Display Graphics Tablet)
Hello! Please help me?
  • I just booted my PC today after running pacman -Syu yesterday.
  • Secondary monitor not detected upon booting today.
    • HUION Kamvas 16, has always worked fine for me for years, default system drivers
Not sure if relevant:
  • I remember seeing something about Linux kernel versions during the update (it asked me what option I wanted, I don’t remember what it was about)
  • I had used 6.12 until the update, it seem I am now at 6.18.
  • Last time I tried to install official linux drivers from HUION’s website it bricked my system (I reinstalled it fresh to fix it, even made sure it was THOSE drivers that were causing it by running multiple reinstalls and re-bricked it), so I don’t think I’m running ANY drivers other than whatever’s default now.
  • I use an NVIDIA graphics card, though never had much problem with that
inxi --full --admin --verbosity=7 --filter --no-host
  Kernel: 6.18.42-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    root=UUID=53d834ed-18f6-4563-832a-591a2c9bfef3 rw quiet splash
    udev.log_priority=3 bluetooth.disable_ertm=1
  Desktop: GNOME v: 50.4 tk: GTK v: 3.24.52 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 50.2 Distro: Manjaro
    base: Arch Linux
  Type: Desktop Mobo: ASRock model: B550 Steel Legend
    serial: <superuser required> uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends v: P1.80 date: 12/01/2020
  System RAM: total: 32 GiB available: 31.26 GiB used: 5.52 GiB (17.7%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 16 GiB speed: 3600 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMW32GX4M2Z3600C18 serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA20102E
    desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3564 min/max: 556/4854 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3564 2: 3564 3: 3564
    4: 3564 5: 3564 6: 3564 7: 3564 8: 3564 9: 3564 10: 3564 11: 3564 12: 3564
    13: 3564 14: 3564 15: 3564 16: 3564 bogomips: 121372
    vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    xtopology
    affected
  Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti] driver: N/A
    alternate: nouveau, nova_core non-free: 550-6xx.xx+
    status: current (as of 2026-07) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0a:00.0 chip-ID: 10de:2486 class-ID: 0300
  Device-2: A4Tech PK-635G driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:4 chip-ID: 09da:2690
    class-ID: 0102 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    compositor: gnome-shell driver: X: loaded: modesetting,nouveau
    alternate: fbdev,nv,vesa gpu: N/A display-ID: 0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: Unknown-1 mapped: None-1 res: mode: 1920x1080 hz: 60
    scale: 100% (1) dpi: 96 size: 508x285mm (20x11.22") modes: 1920x1080
  API: EGL v: 1.5 platforms: device: 0 drv: swrast surfaceless: drv: swrast
    wayland: drv: swrast x11: drv: swrast inactive: gbm
  API: OpenGL v: 4.6 vendor: mesa v: 26.1.6-arch1.1 glx-v: 1.4
    direct-render: yes renderer: llvmpipe (LLVM 22.1.8 256 bits)
    device-ID: ffffffff:ffffffff memory: 30.53 GiB unified: yes
    display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo gpu: nvidia-smi x11: xprop,xrandr
  Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 10de:228b
    class-ID: 0403
    vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Trust GXT 232 Microphone
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-2:3 chip-ID: 145f:0254 class-ID: 0300
  Device-4: A4Tech PK-635G driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
  API: ALSA v: k6.18.42-1-MANJARO status: kernel-api tools: N/A
  Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
    status: active 2: wireplumber status: active
  Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0
  IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 2357:0604
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.1
    lmp-v: 10 status: discoverable: no pairing: no class-ID: 6c0104
  Local Storage: total: 4.77 TiB used: 2.64 TiB (55.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP510
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: ECFM22.6 temp: 42.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 980 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B4QFXO7 temp: 38.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM004-2CV104
    size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 5425 serial: <filter> fw-rev: 0001 scheme: GPT
  ID-1: / raw-size: 96 GiB size: 93.93 GiB (97.85%) used: 35.99 GiB (38.3%)
    fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:6 label: Venom
    uuid: 53d834ed-18f6-4563-832a-591a2c9bfef3
  ID-2: /boot/efi raw-size: 2 GiB size: 2 GiB (99.80%) used: 25.9 MiB (1.3%)
    fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:5 label: N/A uuid: 34A4-2C55
  ID-3: /home raw-size: 432.76 GiB size: 424.9 GiB (98.18%)
    used: 333.1 GiB (78.4%) fs: ext4 dev: /dev/nvme1n1p4 maj-min: 259:8
    label: Zoness uuid: 7006a8bb-3ed5-48a8-b4fe-fa5c946a3459
  ID-4: /run/media/coffeecat/Cerinia raw-size: 1.56 TiB
    size: 1.54 TiB (98.36%) used: 277.25 GiB (17.6%) fs: ext4 dev: /dev/sda1
    maj-min: 8:1 label: Cerinia uuid: 1c5fcbc2-8c07-42b2-bcef-c31c3b2cf5bb
  ID-5: /run/media/coffeecat/Macbeth raw-size: 2.08 TiB
    size: 2.08 TiB (100.00%) used: 2.01 TiB (96.6%) fs: ntfs dev: /dev/sda2
    maj-min: 8:2 label: Macbeth uuid: 490E736A4B804665
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 100 MiB fs: vfat label: N/A
    uuid: 78F1-7B46
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 223.46 GiB fs: ntfs
    label: Corneria uuid: 3E56854D568506BD
  ID-4: /dev/nvme1n1p3 maj-min: 259:7 size: 400.75 GiB fs: ntfs
    label: Katina uuid: 3A8A7D5B3A16D299
  Device-1: 1-3:2 info: TP-Link UB500 Adapter type: bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 2357:0604 class-ID: e001 serial: <filter>
  Device-2: 1-6:18 info: HUION Tablet_GS1562 type: mouse,HID
    driver: hid-multitouch,uclogic,usbhid interfaces: 3 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 480mA
    chip-ID: 256c:006d class-ID: 0300
  Hub-2: 1-7:8 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-8:9 info: Kingston HyperX Alloy Origins type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 0951:16e5 class-ID: 0300
  Device-2: 1-10:10 info: ASRock LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 26ce:01a2 class-ID: 0300
    serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-1:2 info: Holtek Gaming Mouse [Redragon M602-RGB]
    type: mouse,keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    chip-ID: 04d9:fc38 class-ID: 0300
  Device-2: 3-2:3 info: Trust GXT 232 Microphone type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
  Device-3: 3-3:4 info: A4Tech PK-635G type: video,audio
    chip-ID: 09da:2690 class-ID: 0102 serial: <filter>
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 54.4 C mobo: 44.5 C
  Fan Speeds (rpm): N/A
  Processes: 337 Power: uptime: 17m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.41 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
    tool: systemctl
  Packages: 1344 pm: pacman pkgs: 1325 libs: 385 tools: gnome-software,pamac
    pm: flatpak pkgs: 19 Compilers: gcc: 16.1.1 Shell: Zsh v: 5.9.2
    running-in: kgx inxi: 3.3.41
xrandr --verbose
Screen 0: minimum 16 x 16, current 1920 x 1080, maximum 32767 x 32767
None-1 connected primary 1920x1080+0+0 (0x41) normal (normal left inverted right x axis y axis) 508mm x 285mm
	Identifier: 0x21
	Timestamp:  35089
	Subpixel:   unknown
	Gamma:      1.0:1.0:1.0
	Brightness: 0.0
	Clones:
	CRTC:       0
	CRTCs:      0
	Transform:  1.000000 0.000000 0.000000
	            0.000000 1.000000 0.000000
	            0.000000 0.000000 1.000000
	           filter:
	RANDR Emulation: 1
	non-desktop: 0
		supported: 0, 1
  1920x1080 (0x41) 173.000MHz -HSync +VSync *current +preferred
        h: width  1920 start 2048 end 2248 total 2576 skew    0 clock  67.16KHz
        v: height 1080 start 1083 end 1088 total 1120           clock  59.96Hz
  1440x1080 (0x42) 129.000MHz -HSync +VSync
        h: width  1440 start 1528 end 1680 total 1920 skew    0 clock  67.19KHz
        v: height 1080 start 1083 end 1087 total 1120           clock  59.99Hz
  1400x1050 (0x43) 121.750MHz -HSync +VSync
        h: width  1400 start 1488 end 1632 total 1864 skew    0 clock  65.32KHz
        v: height 1050 start 1053 end 1057 total 1089           clock  59.98Hz
  1280x1024 (0x44) 109.000MHz -HSync +VSync
        h: width  1280 start 1360 end 1496 total 1712 skew    0 clock  63.67KHz
        v: height 1024 start 1027 end 1034 total 1063           clock  59.89Hz
  1280x960 (0x45) 101.250MHz -HSync +VSync
        h: width  1280 start 1360 end 1488 total 1696 skew    0 clock  59.70KHz
        v: height  960 start  963 end  967 total  996           clock  59.94Hz
  1152x864 (0x46) 81.750MHz -HSync +VSync
        h: width  1152 start 1216 end 1336 total 1520 skew    0 clock  53.78KHz
        v: height  864 start  867 end  871 total  897           clock  59.96Hz
  1024x768 (0x47) 63.500MHz -HSync +VSync
        h: width  1024 start 1072 end 1176 total 1328 skew    0 clock  47.82KHz
        v: height  768 start  771 end  775 total  798           clock  59.92Hz
  800x600 (0x48) 38.250MHz -HSync +VSync
        h: width   800 start  832 end  912 total 1024 skew    0 clock  37.35KHz
        v: height  600 start  603 end  607 total  624           clock  59.86Hz
  640x480 (0x49) 23.750MHz -HSync +VSync
        h: width   640 start  656 end  720 total  800 skew    0 clock  29.69KHz
        v: height  480 start  483 end  487 total  500           clock  59.38Hz
  320x240 (0x4a)  6.000MHz -HSync +VSync
        h: width   320 start  328 end  360 total  400 skew    0 clock  15.00KHz
        v: height  240 start  243 end  247 total  253           clock  59.29Hz
  1680x1050 (0x4b) 146.250MHz -HSync +VSync
        h: width  1680 start 1784 end 1960 total 2240 skew    0 clock  65.29KHz
        v: height 1050 start 1053 end 1059 total 1089           clock  59.95Hz
  1440x900 (0x4c) 106.500MHz -HSync +VSync
        h: width  1440 start 1520 end 1672 total 1904 skew    0 clock  55.93KHz
        v: height  900 start  903 end  909 total  934           clock  59.89Hz
  1280x800 (0x4d) 83.500MHz -HSync +VSync
        h: width  1280 start 1352 end 1480 total 1680 skew    0 clock  49.70KHz
        v: height  800 start  803 end  809 total  831           clock  59.81Hz
  1152x720 (0x4e) 66.750MHz -HSync +VSync
        h: width  1152 start 1208 end 1320 total 1488 skew    0 clock  44.86KHz
        v: height  720 start  723 end  729 total  748           clock  59.97Hz
  960x600 (0x4f) 45.250MHz -HSync +VSync
        h: width   960 start  992 end 1088 total 1216 skew    0 clock  37.21KHz
        v: height  600 start  603 end  609 total  624           clock  59.63Hz
  928x580 (0x50) 42.750MHz -HSync +VSync
        h: width   928 start  968 end 1056 total 1184 skew    0 clock  36.11KHz
        v: height  580 start  583 end  589 total  603           clock  59.88Hz
  800x500 (0x51) 30.750MHz -HSync +VSync
        h: width   800 start  824 end  896 total  992 skew    0 clock  31.00KHz
        v: height  500 start  503 end  509 total  521           clock  59.50Hz
  768x480 (0x52) 28.750MHz -HSync +VSync
        h: width   768 start  792 end  864 total  960 skew    0 clock  29.95KHz
        v: height  480 start  483 end  489 total  500           clock  59.90Hz
  720x480 (0x53) 26.750MHz -HSync +VSync
        h: width   720 start  744 end  808 total  896 skew    0 clock  29.85KHz
        v: height  480 start  483 end  493 total  500           clock  59.71Hz
  640x400 (0x54) 20.000MHz -HSync +VSync
        h: width   640 start  656 end  720 total  800 skew    0 clock  25.00KHz
        v: height  400 start  403 end  409 total  417           clock  59.95Hz
  320x200 (0x55)  5.000MHz -HSync +VSync
        h: width   320 start  328 end  360 total  400 skew    0 clock  12.50KHz
        v: height  200 start  203 end  209 total  215           clock  58.14Hz
  1600x900 (0x56) 118.250MHz -HSync +VSync
        h: width  1600 start 1688 end 1856 total 2112 skew    0 clock  55.99KHz
        v: height  900 start  903 end  908 total  934           clock  59.95Hz
  1368x768 (0x57) 85.250MHz -HSync +VSync
        h: width  1368 start 1440 end 1576 total 1784 skew    0 clock  47.79KHz
        v: height  768 start  771 end  781 total  798           clock  59.88Hz
  1280x720 (0x58) 74.500MHz -HSync +VSync
        h: width  1280 start 1344 end 1472 total 1664 skew    0 clock  44.77KHz
        v: height  720 start  723 end  728 total  748           clock  59.86Hz
  1024x576 (0x59) 46.500MHz -HSync +VSync
        h: width  1024 start 1064 end 1160 total 1296 skew    0 clock  35.88KHz
        v: height  576 start  579 end  584 total  599           clock  59.90Hz
  864x486 (0x5a) 32.500MHz -HSync +VSync
        h: width   864 start  888 end  968 total 1072 skew    0 clock  30.32KHz
        v: height  486 start  489 end  494 total  506           clock  59.92Hz
  720x400 (0x5b) 22.250MHz -HSync +VSync
        h: width   720 start  744 end  808 total  896 skew    0 clock  24.83KHz
        v: height  400 start  403 end  413 total  419           clock  59.27Hz
  640x350 (0x5c) 17.500MHz -HSync +VSync
        h: width   640 start  656 end  720 total  800 skew    0 clock  21.88KHz
        v: height  350 start  353 end  363 total  369           clock  59.28Hz
After some debugging on my own I found out that reinstalling linux618-nvidia-open solved things.
  • 6.12 was stil installed so i rebooted into it and the graphics tablet was working normally
  • while at 6.18 the nvidia-smi was failing saying it couldn’t communicate to the NVIDIA driver
everything is workign now! yay :grinning_cat:
The NVIDIA driver is the first thing I’d check here. Your inxi output shows the RTX 3060 Ti with driver: N/A, and the display stack is falling back to nouveau/software rendering (llvmpipe). That would explain why the Huion display disappeared after the update.
I’d boot the previous 6.12 kernel from GRUB first. If the Kamvas works there, that strongly points to the kernel/graphics stack change rather than the tablet itself.
Then check:
mhwd -li
nvidia-smi
lsmod | grep -E 'nvidia|nouveau'
If nvidia-smi fails and mhwd shows no working NVIDIA driver, reinstall the appropriate Manjaro NVIDIA driver rather than installing Huion’s driver. The USB portion of the Kamvas is actually detected (256c:006d), so the problem looks more like the display/GPU path than the tablet USB connection.
Also, don’t try to fix this with xrandr yet. Your output only exposes None-1, and with GNOME Wayland + llvmpipe there isn’t a normal NVIDIA display provider available to configure.
If the previous kernel works, I’d keep using it temporarily and test the 6.18 kernel after getting the NVIDIA driver stack working.
