I have a second monitor that is hooked up to HDMI for my GPU. It has been working fine up until today. It is completely black and when I power cycle it only flickers on for a second before reverting to black. The LED indicator shows blue, indicating that it is receiving a signal and data from the GPU (it’s amber when it is asleep or not receiving data). When I use xrandr
it displays the fact that I have an HDMI output so that all seems normal. It may be that the monitor is old but I don’t think so as it works in windows the last time I checked (2 days ago, and I’d check now but I need to leave it on for work until Thursday at least). Here is my xrandr:
xrandr
Screen 0: minimum 320 x 200, current 4480 x 1440, maximum 16384 x 16384
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 531mm x 299mm
1920x1080 60.00*+ 59.96 50.00 59.94 59.99 59.93
1920x1200 59.95
1920x1080i 60.00 50.00 59.94
1600x1200 65.00 60.00
1680x1050 59.95 59.88
1400x1050 74.76 59.98
1600x900 59.95 59.82
1280x1024 75.02 60.02
1440x900 59.90
1400x900 59.96 59.88
1280x960 60.00
1440x810 59.97
1368x768 59.88 59.85
1366x768 59.79
1280x800 59.99 59.97 59.81 59.91
1152x864 75.00
1280x720 60.00 59.99 59.86 60.00 50.00 59.94 59.74
1024x768 75.05 60.04 75.03 70.07 60.00
960x720 75.00 60.00
928x696 75.00 60.05
896x672 75.05 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
832x624 74.55
960x540 59.96 59.99 59.63 59.82
800x600 75.00 70.00 65.00 60.00 72.19 75.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
720x576 50.00
700x525 74.76 59.98
800x450 59.95 59.82
720x480 60.00 59.94
640x512 75.02 60.02
700x450 59.96 59.88
640x480 60.00 75.00 72.81 75.00 66.67 60.00 59.94
720x405 59.51 58.99
720x400 70.08
684x384 59.88 59.85
640x400 59.88 59.98
576x432 75.00
640x360 59.86 59.83 59.84 59.32
512x384 75.03 70.07 60.00
512x288 60.00 59.92
416x312 74.66
480x270 59.63 59.82
400x300 72.19 75.12 60.32 56.34
432x243 59.92 59.57
320x240 72.81 75.00 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 connected primary 2560x1440+1920+0 (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 59.95 + 74.97*
1920x1440 75.00 60.00
1856x1392 75.00 60.01
1792x1344 75.00 60.01
2048x1152 59.98 59.90 59.91
1920x1200 59.88 59.95
1920x1080 59.97 59.96 60.00 50.00 59.94 49.95 59.93
1600x1200 75.00 70.00 65.00 60.00
1600x900 59.99 59.94 59.95 60.00 59.82
1440x900 59.89
1280x960 60.00
1440x810 60.00 59.97
1152x864 75.00
960x720 75.00 60.00
928x696 75.00 60.05
896x672 75.05 60.01
960x600 59.93 60.00
832x624 74.55
840x525 60.01 59.88
864x486 59.92 59.57
720x576 50.00
700x525 74.76 59.98
800x450 59.95 59.82
720x480 60.00 59.94
640x512 75.02 60.02
700x450 59.96 59.88
640x480 60.00 75.00 72.81 75.00 60.00 59.94
720x405 59.51 58.99
720x400 70.08
684x384 59.88 59.85
640x400 59.88 59.98
576x432 75.00
512x288 60.00 59.92
416x312 74.66
480x270 59.63 59.82
432x243 59.92 59.57
360x202 59.51 59.13
320x180 59.84 59.32
