[ 0.249196] #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 #13 #14 #15
[ 0.294387] ACPI BIOS Error (bug): Failure creating named object [\_TZ.TZ01], AE_ALREADY_EXISTS (20220331/dswload2-326)
[ 0.294391] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20220331/psobject-220)
[ 0.296056] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP2.WWAN], AE_NOT_FOUND (20220331/dswload2-162)
[ 0.296059] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20220331/psobject-220)
[ 0.345987] Expanded resource Reserved due to conflict with PCI Bus 0000:00
[ 0.358510] pci 0000:00:08.1: can't derive routing for PCI INT A
[ 0.358511] pci 0000:00:08.1: PCI INT A: not connected
[ 0.358634] pci 0000:00:08.3: can't derive routing for PCI INT A
[ 0.358635] pci 0000:00:08.3: PCI INT A: not connected
[ 0.360693] pci 0000:00:00.2: can't derive routing for PCI INT A
[ 0.360694] pci 0000:00:00.2: PCI INT A: not connected
[ 0.471631] hpet_acpi_add: no address or irqs in _CRS
[ 0.547761] tpm tpm0: AMD fTPM version 0x3004e00020005 causes system stutter; hwrng disabled
[ 0.716674] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 0.722514] hub 6-0:1.0: config failed, hub doesn't have any ports! (err -19)
[ 3.511196] v4l2loopback: loading out-of-tree module taints kernel.
[ 4.489765] nvidia: module license 'NVIDIA' taints kernel.
[ 4.489768] Disabling lock debugging due to kernel taint
[ 4.548577] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
[ 5.184909] ATPX version 1, functions 0x00000001
[ 5.184946] ATPX Hybrid Graphics
[ 5.196056] amdgpu 0000:05:00.0: amdgpu: PSP runtime database doesn't exist
[ 5.196060] amdgpu 0000:05:00.0: amdgpu: PSP runtime database doesn't exist
[ 5.420179] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 530.41.03 Thu Mar 16 19:48:20 UTC 2023
[ 5.514168] ACPI Warning: \_SB.NPCF._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20220331/nsarguments-61)
[ 5.514212] ACPI Warning: \_SB.PCI0.GPP0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20220331/nsarguments-61)
[ 5.535641] amdgpu: SRAT table not found
[ 7.064438] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 7.492453] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
Thought this could be useful
