Hi, everyone! Sorry in advance for any confusion I might be making. But this week I turned off my second monitor on Display Settings and now whenever I try to turn it on back again, using the Display Settings, the computer freezes and I can’t do anything but force restart. Is there anyway to turn it back on again via terminal or some other way? It works just fine on Windows (I am running a dual boot). The computer is 1 week old lol and I am new to Manjaro so I don’t really know what to do.
Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=70504b68-dca6-477f-8de8-2fabf28e287b rw quiet splash apparmor=1
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Dell product: Dell G15 5511 v: N/A
Mobo: Dell model: 0KGWG1 v: A03 serial: <superuser required> UEFI: Dell
v: 1.19.2 date: 10/27/2022
ID-1: BAT0 charge: 85.9 Wh (100.0%) condition: 85.9/84.3 Wh (101.9%)
volts: 13.2 min: 11.4 model: SMP DELL 70N2F95 type: Li-poly serial: <filter>
status: full
RAM: total: 15.38 GiB used: 3.58 GiB (23.3%)
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
microcode: 0x42
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1749 high: 3019 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 1143 2: 1108 3: 2658
4: 2300 5: 1232 6: 1247 7: 1026 8: 1502 9: 1997 10: 3019 11: 2530 12: 1209
13: 1613 14: 2300 15: 2300 16: 800 bogomips: 73744
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:9a60
class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
driver: nouveau v: kernel non-free: 525.xx+ status: current (as of 2022-12)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 8 link-max: lanes: 16 ports: active: none empty: DP-3,
DP-4, HDMI-A-1, eDP-2 bus-ID: 01:00.0 chip-ID: 10de:2560 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-5:4 chip-ID: 0c45:6720 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: LG Display 0x067e built: 2020 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel UHD Graphics (TGL GT1)
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Dell
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:43c8 class-ID: 0401
Device-2: NVIDIA GA106 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
Device-2: Realtek vendor: Rivet Networks driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 2d:00.0 chip-ID: 10ec:2600
class-ID: 0200
IF: enp45s0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 3-14:6 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 476.94 GiB used: 20.3 GiB (4.3%)
model: PC SN740 NVMe WD 512GB size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 73103012 temp: 36.9 C scheme: GPT
ID-1: / raw-size: 97.76 GiB size: 95.66 GiB (97.86%) used: 20.26 GiB (21.2%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 70504b68-dca6-477f-8de8-2fabf28e287b
used: 41.4 MiB (43.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: E849-C8EC
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 377.56 GiB fs: ntfs label: N/A
uuid: FAA04B03A04AC5BB
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1021 MiB fs: ntfs label: N/A
uuid: 5C0EC77B0EC74D28
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 3-1:2 info: Sunplus Innovation Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 98mA
chip-ID: 1bcf:0005 class-ID: 0301
Device-2: 3-3:3 info: Kingston HyperX Alloy Core RGB type: Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 0951:16dd class-ID: 0301
Device-3: 3-5:4 info: Microdia Integrated_Webcam_HD type: Video
Device-4: 3-7:5 info: Alienware LED controller type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.1 speed: 12 Mb/s
chip-ID: 187c:0550 class-ID: 0300 serial: <filter>
Device-5: 3-14:6 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 20 Gb/s
Use of uninitialized value $unit in concatenation (.) or string at /usr/bin/inxi line 24273.
Use of uninitialized value $value in concatenation (.) or string at /usr/bin/inxi line 24273.
Src: /sys System Temperatures: cpu: 50.0 C mobo: N/A
Power: 12v: N/A 5v: 5 3.3v: N/A vbat: N/A
Processes: 358 Uptime: 8m wakeups: 2 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1244
pm: pacman pkgs: 1231 libs: 311 tools: gnome-software,pamac pm: flatpak
pkgs: 0 pm: snap pkgs: 13 Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.24
