this issue is covered here but the topic is closed:
…solved-manjaro-forum-can-not-access-topic-found-in-google-searches/5674
may i suggest that the landing page be edited to include the fix? in big red letters at the top: add ‘archive.’ to the address to access older help articles.
there is a lot of valuable information there and it is insanely frustrating to read the first paragraph of a promising fix only to find it’s a dead end.
The actual solution for this is rather problematic as - at some point the - search engine index - will collide with existing topics - and return topics with no relevance for search query - and this a rather unfortunate side effect from the decision to archive the old forum after the crash.
I have not been involved in the rebuilding of the forum - nor does I know anything on the troubles faced when the whole #! crashed - but from an objective viewpoint - who cares if all the images was lost - if the user base and the accumulated knowledge could have been restored - it would have been a far better outcome than all SEO pointing nowhere - but as far as I know - even this restore wasn’t possible.
Well if you use a browser capable of using custom search engines with nicknames you could assign https://forum.manjaro.org/search?q=%s to a nickname for searching the (new) Manjaro forums (for example mf) and amf to https://archived.forum.manjaro.org/search/?q=%s for the archived forums, so you would only need to type in the address bar
mf <what I want to search for in the new forums>
and
amf <what I want to search for in the archived forums>
It’s very fast and effective this way, directly, without the need of google leading to broken urls…
