Since several version I can not update the seafile-client. I receive the following error:
Preparing...
Cloning seafile-client build files...
Checking seafile-client dependencies...
Resolving dependencies...
Checking inter-conflicts...
Building seafile-client...
==> Making package: seafile-client 7.0.9-1 (So 16 Aug 2020 21:54:35 CEST)
==> Retrieving sources...
-> Found seafile-client-7.0.9.tar.gz
-> Found fix_QT5_v5.15_QPainterPath.diff
seafile-client-7.0.9.tar.gz ... Passed
fix_QT5_v5.15_QPainterPath.diff ... Passed
==> Extracting sources...
-> Extracting seafile-client-7.0.9.tar.gz with bsdtar
==> Starting prepare()...
/usr/bin/patch: **** Can't open patch file /var/tmp/pamac-build-ralph/seafile-client/src/fix_QT5_v5.15_QPainterPath.diff : No such file or directory
==> ERROR: A failure occurred in prepare().
Aborting...
Anything I can do to fix that?
Thanks
muc
