I installed SDDM on Manjaro XFCE following instructions on the Manjaro wiki for sddm:
What happens:
On startup I reach the SDDM login screen. I can enter my password. The login screen then freezes without proceeding to the desktop starting as it should. How would I fix this?
Some output follows where I checked the status of sddm:
The last lines output below might indicate some problem with Authorization. What might be the problem here? Did the wiki instructions leave out some necessary step? There are no onscreen error messages to suggest what is wrong.
● sddm.service - Simple Desktop Display Manager
Loaded: loaded (/usr/lib/systemd/system/sddm.service; enabled; preset: disabled)
Active: active (running) since Mon 2022-12-12 10:19:31 MST; 7min ago
Docs: man:sddm(1)
man:sddm.conf(5)
Main PID: 386 (sddm)
Tasks: 4 (limit: 9392)
Memory: 101.9M
CPU: 1.236s
CGroup: /system.slice/sddm.service
├─386 /usr/bin/sddm
└─622 /usr/lib/Xorg -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{91da6af8-2cf9-4974-829a-2ebed8793352} -noreset -displayfd 17
Dec 12 10:20:05 Zotac sddm-helper[804]: pam_unix(sddm:session): session opened for user dmn(uid=1000) by (uid=0)
Dec 12 10:20:05 Zotac sddm[386]: Auth: sddm-helper exited successfully
Dec 12 10:20:05 Zotac sddm[386]: Greeter stopped.
Dec 12 10:20:06 Zotac sddm-helper[804]: gkr-pam: unlocked login keyring
Dec 12 10:20:06 Zotac sddm-helper[804]: Starting: "/usr/share/sddm/scripts/Xsession \"startxfce4\""
Dec 12 10:20:06 Zotac sddm[386]: Session started
Dec 12 10:20:06 Zotac sddm-helper[804]: [PAM] Closing session
Dec 12 10:20:06 Zotac sddm-helper[804]: pam_unix(sddm:session): session closed for user dmn
Dec 12 10:20:06 Zotac sddm-helper[804]: [PAM] Ended.
Dec 12 10:20:06 Zotac sddm[386]: Auth: sddm-helper exited with 1
