sd-umount: Failed to unmount /oldroot
Just by chance I saw that my PC throws errors incl. kernel panic whenever I shutdown the PC. There is no trace in the logs. But I have pictures:
So far I did not experience any negative impact, but it scares me.
I do not know if this is a kernel bug or a systemd bug. I found some info on the web. Some of which proposed to add the "shutdown" HOOK to/etc/mkinitcpio.conf etc. . I did that. But it did not help.
Any idea what is going on here?
Maybe some job on shutdown. Check your services for a shutdown target.
Also try other kernels and/or fallback image.
I said: there is no trace in the logs. It happens at the very end of the shutdown process and powering off a second later. The last entries in the journal are:
Sep 10 17:57:05 rakete systemd[1]: Reached target Power-Off.
Sep 10 17:57:05 rakete systemd[1]: Shutting down.
Sep 10 17:57:05 rakete kernel: printk: systemd-shutdow: 57 output lines suppressed due to ratelimiting
Sep 10 17:57:05 rakete systemd-shutdown[1]: Syncing filesystems and block devices.
Sep 10 17:57:05 rakete systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Sep 10 17:57:05 rakete haveged[459]: haveged: Stopping due to signal 15
Sep 10 17:57:05 rakete haveged[459]: haveged starting up
Sep 10 17:57:05 rakete systemd-journald[460]: Journal stopped
Any external drives?
Just giving ideas...
No external drives. And I believe this issue is new. I will try kernel 4.19 and see....
It is definitely a systemd issue!
With kernel 4.19 I get the same three lines of error like in the first image but no kernel panic.
But when I downgrade systemd the issue is gone.
It was this update in testing that caused the issue:
[2019-09-06 22:31] [ALPM] upgraded systemd-libs (242.85-2 -> 243.0-2)
[2019-09-06 22:31] [ALPM] upgraded systemd (242.85-2 -> 243.0-2)
[2019-09-06 22:33] [ALPM] upgraded systemd-resolvconf (242.85-2 -> 243.0-2)
[2019-09-06 22:33] [ALPM] upgraded systemd-sysvcompat (242.85-2 -> 243.0-2)
Downgrading solved it:
[2019-09-10 18:53] [ALPM] downgraded systemd (243.0-2 -> 242.85-2)
[2019-09-10 18:54] [ALPM] downgraded systemd-libs (243.0-2 -> 242.85-2)
[2019-09-10 18:55] [ALPM] downgraded systemd-resolvconf (243.0-2 -> 242.85-2)
[2019-09-10 18:55] [ALPM] downgraded systemd-sysvcompat (243.0-2 -> 242.85-2)
@philm
I do not recommend to push systemd 243.0-2 to stable.
UPDATE:
Noticed this too, but i think the issue is solved with the 243.9-1 currently in unstable.
I see I'm not the only one. But I only get the 2 sd-umount errors, I don't get a kernel panic or whatever that mess is in the 2nd picture, probably cause I'm on stable...
Yep I noticed it on my fresh install of Architect Testing this weekend. Forgot to report it.
It's a regression in v243. It still happens in 243.51:
https://bbs.archlinux.org/viewtopic.php?pid=1866672#p1866672
But the systemd issue I opened was closed by Poettering:
Umm. Kernel oopses are never something userspace should be able to trigger. Unfortunately your second pic cuts off where the interesting bits follow.
Either way this doesnt look like a systemd prob. If the kernel oopses its a kernel problem. Please contact your distro about this first.
(Also drop vbox kernel modules which arent upstream before testing. Kernel folks dont like testing that.)
Anyway. Closing this here.
