I wanted to use Flameshot as screenshot tool and that works as intended… Except…
When I try to take a Screenshot with flameshot a System windows pops up asking if I’d want to share the screenshot with the appication trying to use it. Is there a way to disable this?
If needed I can send you a Screenshot of the window I am talking about
Thanks for the reply and thank you for the welcome msg
This is the window I’m talking about. If I click on share flameshot’ll open and I can take the screenshot using flameshot. But I always have to share the screenshot through this window first.
I tried the links and sadly none helped. It’s not really a flameshot issue. It’s not really an Issue at all. It’s the expected behaviour. I just want to know how to disable that default behaviour so I can have the system the way I want it.
I already configured everything. The PrtScr key is already set to flameshot gui to use the flameshot app to take the screenshot. But when I use the print key it opens the window and asks me to share the screenshot with the app before flameshot opens.
This is what happens when I try to take a Screenshot.
This is what happens when I decline to share.
And if I do decide to share, like I said, Flameshot opens and is working as intended.
Sadly it didn’t work. I even tried to search for other schemas that may contain any screenshot related keybinds (I think Wayland is the one causing this window to pop up) But I couldn’t find any bindings
Okay so I finally found the right wording to google and found a reddit thread that linked me to a github issue.
TL;DR => This window was introduced to prevent arbitrary code execution and there’s already a feature request to give possibilities to prevent the window from popping up every time u want to take a Screenshot.
The issue is not yet resolved but the mere existence of the github issue renders my request for help on this forum done. Thank you all for your help
