Hello,
Screenshots used to be saved in /Pictures, but not anymore; they are now saved only in the clipboard. How can I save them in Pictures again?
Thank you!
Hello,
Thank you!
By default Screenshooter uses the clipboard. Perhaps in Manjaro they did set it to /Pictures.
IN the provided (above) link you can find how to set a savepath after you make a screenshot and here you can find how to set a default path again.
Thank you for the answer. I want to continue using Alt + PrScr.
Then setup your screen shot application to honor that - that is really not a distro problem but a user problem.
