I realise I cannot simply share my screen (or window) on Zoom or other visioconference soft&web apps.
I have tried different solutions mentioned in the forum but yet nothing helps : see post screensharing-on-zoom-calls-under-wayland/86041
or firefox-screensharing-with-pipewire-and-wayland-in-gnome-not-working-as-expected/107320
Therefore, I am trying to use OBS Studio which provides a virtual camera that Zoom (or else) can take as video input. But… The problem remains since it requires v4l2loopback
that doesn’t work, with similar symptoms to this post : install-v4l2loopback/79240
. And in anycase, OBS was not able to get a screencast from a window for the previous reason.
Has anyone found a workaround ? Thanks!
