After Linux 5.10 is finally recommended as a kernel, I decided to take it another shot.
It seems like I still have this lockscreen issue which prevented me from upgrading to the new kernel version earlier.
Thus I ask for support on this issue.
Once my screen is locked, it’s dead.
It’s two black screens (I have dual screens) for me and no way to get out of it.
I get no keyboard input, not even ctrl + alt + f2, forcing me to restart the computer each time the screen locks.
I was able to get out of that.
I would like to note that I just found out that I am using light-locker as my screen lock.
I’m not sure if that’s standard.
and wait 2-3 seconds for the lock to set in.
Perhaps the same is true with the other commands.
I’ll check…
Okay, it’s the same with xflock4 and I’m quite sure with suspend as well.
I’m also using lightdm.
I’ll install xfce4-screensaver again then.
I get the feeling that I installed light-locker for a reason, like xfce4-screensaver was unable to go completely black or something, or maybe I had the same issues with it as I have with light-locker right now.
Whenever my screen goes to sleep/locks, I’m no longer able to get back.
1.1 Keyboard input or mouse move makes the screen go from sleep to black.
1.2 Alt+Ctrl+F2 or mouseclick does nothing.
When I do get the lock screen, through moving mouse or keyboard input before the screen goes to sleep, my password is rejected and I am giving a timeout after three tries.
Turning off screensaver in xfce4-screensaver does not turn it off. I still get a blank screen after ~15 minutes of inactivity
