Hey there,
I’ve recently built a new work rig, consisting of an AMD Ryzen 7 5700X, MSI Pro B550M-P mobo and Intel ARC A380 GPU.
Am currently running the 6.1 LTS kernel, with the Cinnamon DE.
This is connected to 3x 27 inch 4K LG monitors via DP.
Recently I’ve been having issues whereby 2 of the 3 monitors flicker and then go black. Howeve the mouse cursor is still visible on those affected screens.
Often I can “fix” the issue by going into Display settings and disabling one of the 2 screen and applying the change, and then cancelling the change on the confirmation box.
However sometimes it happens every few mins, which is obviously extremely annoying.
Rebooting usually results in a much longer runtime before re-occurence of the issue.
System info:
Host: fatmcgav-desktop Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64
compiler: gcc v: 13.1.1 parameters: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64
root=UUID=aac0ce1f-4a29-4fb7-af08-a627dd917d88 rw quiet
cryptdevice=UUID=4757777a-12e4-46ff-ac1a-b87b33f043c3:luks-4757777a-12e4-46ff-ac1a-b87b33f043c3
root=/dev/mapper/luks-4757777a-12e4-46ff-ac1a-b87b33f043c3
udev.log_priority=3
Desktop: N/A dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7D95 v: 1.0
serial: <superuser required>
Mobo: Micro-Star model: PRO B550M-P GEN3 (MS-7D95) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.20
date: 08/17/2022
Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
serial: 4b-55-57-47 charge: 55% (should be ignored) rechargeable: yes
status: discharging
System RAM: available: 62.72 GiB used: 18.63 GiB (29.7%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3225 high: 4352 min/max: 2200/4662 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3748 2: 3705
3: 3600 4: 3651 5: 2825 6: 3665 7: 3599 8: 2200 9: 3553 10: 2894 11: 3622
12: 2200 13: 2200 14: 4352 15: 3598 16: 2200 bogomips: 108845
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel DG2 [Arc A380] vendor: ASRock driver: i915 v: kernel
arch: Gen-12.7 code: Alchemist process: TSMC n6 (7nm) built: 2022+ pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 ports: active: DP-2,DP-3 off: DP-1
empty: HDMI-A-1, HDMI-A-2, HDMI-A-3, HDMI-A-4 bus-ID: 2d:00.0
chip-ID: 8086:56a5 class-ID: 0300
Device-2: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.3:4
chip-ID: 046d:0892 class-ID: 0102 serial: 5A2E9CDF
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: modesetting
alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 7680x2160 s-dpi: 96 s-size: 2032x572mm (80.00x22.52")
s-diag: 2111mm (83.11")
Monitor-1: DP-1 note: disabled model: LG (GoldStar) HDR 4K serial: 450270
built: 2020 res: N/A dpi: 163 gamma: 1.2 chroma: red: x: 0.682 y: 0.314
green: x: 0.278 y: 0.675 blue: x: 0.153 y: 0.047 white: x: 0.314 y: 0.329
size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9
modes: 3840x2160, 2560x1440, 1920x1080, 1600x900, 1280x1024, 1280x800,
1280x720, 1024x768, 800x600, 720x480, 640x480
Monitor-2: DP-2 pos: primary,left model: LG (GoldStar) ULTRAFINE
serial: 202NTCZAX459 built: 2022 res: 3840x2160 dpi: 140 gamma: 1.2 chroma:
red: x: 0.682 y: 0.318 green: x: 0.259 y: 0.678 blue: x: 0.149 y: 0.059
white: x: 0.314 y: 0.329 size: 697x392mm (27.44x15.43")
diag: 806mm (31.7") ratio: 16:9 modes: 3840x2160, 2560x1440, 1920x1080,
Monitor-3: DP-3 pos: right model: LG (GoldStar) HDR 4K serial: 116440
built: 2019 res: 3840x2160 dpi: 163 gamma: 1.2 chroma: red: x: 0.682
y: 0.314 green: x: 0.278 y: 0.675 blue: x: 0.153 y: 0.047 white: x: 0.314
y: 0.329 size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9
API: OpenGL Message: Unable to show GL data. Required tool glxinfo
missing.
Device-1: Intel DG2 Audio vendor: ASRock driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 2e:00.0 chip-ID: 8086:4f92
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 30:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
Device-4: FiiO K3 driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-1.4.1:6 chip-ID: 2972:0047 class-ID: fe01
Device-5: Shure MV5 driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.4.3:8
chip-ID: 14ed:1000 class-ID: 0300
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.70 status: off tools: pw-cli
Server-2: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
type: plugin tools: pacat,pactl,pavucontrol
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 2a:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: 04:7c:16:54:71:a9
IP v4: 192.168.10.113/24 type: dynamic noprefixroute scope: global
broadcast: 192.168.10.255
IP v6: fe80::d5eb:50c5:e3a5:abcf/64 type: noprefixroute scope: link
IF-ID-1: sdwan0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IP v4: 100.96.0.2/32 type: noprefixroute scope: global
IP v6: fe80::2301:4853:a57e:1e90/64 type: noprefixroute scope: link
WAN IP: 94.173.235.94
Device-1: luks-4757777a-12e4-46ff-ac1a-b87b33f043c3 maj-min: 254:0
type: LUKS dm: dm-0 size: 465.46 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 465.46 GiB
Local Storage: total: 465.76 GiB used: 42.76 GiB (9.2%)
model: WD BLACK SN770 500GB size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial: 224008802097
fw-rev: 731030WD temp: 39.9 C scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 465.24 GiB (99.95%)
used: 42.76 GiB (9.2%) fs: xfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-4757777a-12e4-46ff-ac1a-b87b33f043c3 label: N/A
uuid: aac0ce1f-4a29-4fb7-af08-a627dd917d88
used: 472 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: D1E0-8005
Device-1: 1-4:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Hub-4: 3-1:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Device-1: 3-1.1:3 info: Elgato Systems GmbH Stream Deck MK.2 type: HID
chip-ID: 0fd9:0080 class-ID: 0300 serial: DL29L2A35864
Device-2: 3-1.3:4 info: Logitech C920 HD Pro Webcam type: video,audio
Hub-5: 3-1.4:5 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
Device-1: 3-1.4.1:6 info: FiiO K3 type: audio driver: snd-usb-audio
interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
Device-2: 3-1.4.2:7 info: Yubicom Yubikey NEO(-N) OTP+U2F+CCID
type: keyboard,HID,smart card driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
chip-ID: 1050:0116 class-ID: 0b00
Device-3: 3-1.4.3:8 info: Shure MV5 type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
Device-4: 3-1.4.4:9 info: foostan Corne type: keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 4653:0001 class-ID: 0300
Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-7: 4-1:2 info: Realtek Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
Hub-8: 4-1.4:3 info: Realtek Hub ports: 4 rev: 3.2
System Temperatures: cpu: 38.0 C mobo: 39.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 831 fan-3: 0 fan-4: 617 fan-5: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.30 vbat: 3.25
Packages: 1011 pm: pacman pkgs: 1000 libs: 281 tools: pamac,yay pm: flatpak
pkgs: 11
1: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
Processes:
CPU top: 5 of 563
1: cpu: 5.0% command: chrome pid: 79987 mem: 207.8 MiB (0.3%)
2: cpu: 3.2% command: chrome pid: 4003540 mem: 546.9 MiB (0.8%)
3: cpu: 3.0% command: chrome pid: 4093 mem: 577.9 MiB (0.8%)
4: cpu: 2.3% command: chrome pid: 59653 mem: 237.7 MiB (0.3%)
5: cpu: 2.2% command: k9s pid: 3978758 mem: 109.2 MiB (0.1%)
Memory top: 5 of 563
1: mem: 652.3 MiB (1.0%) command: chrome pid: 12306 cpu: 0.8%
2: mem: 577.9 MiB (0.8%) command: chrome pid: 4093 cpu: 3.0%
3: mem: 546.9 MiB (0.8%) command: chrome pid: 4003540 cpu: 3.2%
4: mem: 499.4 MiB (0.7%) command: chrome pid: 271854 cpu: 0.1%
5: mem: 418.3 MiB (0.6%) command: chrome pid: 4004287 cpu: 1.0%
Processes: 563 Uptime: 1d 2h 36m wakeups: 16 Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Shell: fish v: 3.6.1 running-in: tmux: inxi: 3.3.27
I had a poke around the Xorg
logs, and found this around the time of one of the screen events:
[ 45943.035] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Device or resource busy
[ 45943.076] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Device or resource busy
[ 45943.120] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Device or resource busy
[ 45943.154] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Device or resource busy
[ 45943.197] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Device or resource busy
[ 45943.558] (II) modeset(0): Allocate new frame buffer 7680x2160 stride
[ 45944.013] (II) modeset(0): EDID vendor "GSM", prod id 23490
[ 45944.013] (II) modeset(0): Using hsync ranges from config file
[ 45944.013] (II) modeset(0): Using vrefresh ranges from config file
[ 45944.013] (II) modeset(0): Printing DDC gathered Modelines:
[ 45944.013] (II) modeset(0): Modeline "3840x2160"x0.0 533.25 3840 3888 3920 4000 2160 2163 2168 2222 +hsync -vsync (133.3 kHz eP)
[ 45944.013] (II) modeset(0): Modeline "3840x2160"x0.0 297.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.5 kHz e)
[ 45944.013] (II) modeset(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[ 45944.013] (II) modeset(0): Modeline "1920x1080"x0.0 138.50 1920 1962 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz e)
[ 45944.013] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 45944.013] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 45944.013] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 45944.013] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 45944.013] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 45944.013] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 45944.806] (EE) event3 - Logitech MX Ergo: client bug: event processing lagging behind by 28ms, your system is too slow
[ 45944.806] (EE) event3 - Logitech MX Ergo: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 45963.966] (II) modeset(0): Allocate new frame buffer 11520x2160 stride
[ 45964.946] (II) modeset(0): EDID vendor "GSM", prod id 23490
[ 45964.947] (II) modeset(0): Using hsync ranges from config file
[ 45964.947] (II) modeset(0): Using vrefresh ranges from config file
[ 45964.947] (II) modeset(0): Printing DDC gathered Modelines:
[ 45964.947] (II) modeset(0): Modeline "3840x2160"x0.0 533.25 3840 3888 3920 4000 2160 2163 2168 2222 +hsync -vsync (133.3 kHz eP)
[ 45964.947] (II) modeset(0): Modeline "3840x2160"x0.0 297.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.5 kHz e)
[ 45964.947] (II) modeset(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[ 45964.947] (II) modeset(0): Modeline "1920x1080"x0.0 138.50 1920 1962 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz e)
[ 45964.947] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 45964.947] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 45964.947] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 45964.947] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 45964.947] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 45964.947] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 45965.333] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Cannot allocate memory
[ 45965.722] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Cannot allocate memory
[ 45965.953] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Cannot allocate memory
[ 45966.183] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Cannot allocate memory
[ 45966.370] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Cannot allocate memory
[ 45966.580] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Cannot allocate memory
[ 45966.781] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Cannot allocate memory
[ 45967.186] (WW) modeset(0): flip queue retry
[ 45967.193] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Cannot allocate memory
[ 45967.212] (WW) modeset(0): Present-flip: queue flip duri
The Present-flip: ...
errors stop spewing when I disable one of the black screens, and then re-occur pretty quickly once all 3 screens are enabled.
I’ve tried using different refresh rates of 30hz
or 60hz
, but no difference.
Any pointers?
Thanks
Gavin
