I just installed Manjaro and I’ve been running into a few graphics related issues (mostly not smoothly running graphics), but the one that bothers me the most is also the one I haven’t really found anything about yet.
The issue is a follows:
When the screen turns off or the machine goes into sleep mode and I wake it back up, both screens turn on but my main screen seems not to get any signal and turns off again. It also doesn’t turn on after logging in.
When I switch the input on the monitor back and forth however it turns on and continues to show the image.
The main monitor (the one with the issue) is connected by DisplayPort and is 4k 60Hz.
Secondary is connected by HDMI to DVI and is 1050p 59,95Hz.
Specs:
CPU: Ryzen 9 5900x
GPU: MSI RTX 3080 Suprim X
MB: Asus ROG B550-E
Latest BIOS and latest drivers.
System: Host: je-systemproductname Kernel: 5.13.19-2-MANJARO x86_64 bits: 64
compiler: gcc v: 11.1.0
root=UUID=a8fa1bf0-9f05-4059-8d0d-d6ef1ebae18b rw quiet splash apparmor=1
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Machine: Type: Desktop System: ASUS product: N/A v: N/A serial: <superuser required>
Mobo: ASUSTeK model: ROG STRIX B550-E GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2423
date: 08/09/2021
Battery: ID-1: hidpp_battery_0 charge: N/A condition: N/A volts: 3.7 min: N/A
model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A
serial: 407f-dd-b1-ff-98 status: Discharging
Memory: RAM: total: 15.54 GiB used: 5.62 GiB (36.2%)
PCI Slots: Permissions: Unable to run dmidecode. Root privileges required.
CPU: Info: 12-Core model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3
family: 19 (25) model-id: 21 (33) stepping: 0 microcode: A201016 cache:
L2: 6 MiB bogomips: 177681
Speed: 2766 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz):
1: 2766 2: 2789 3: 2197 4: 2197 5: 2257 6: 2887 7: 3594 8: 2460 9: 2585
10: 2442 11: 2197 12: 2198 13: 2879 14: 2197 15: 2196 16: 2196 17: 2197
18: 2878 19: 2879 20: 2875 21: 2197 22: 2643 23: 2425 24: 2201
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2
bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc
perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru rdrand rdseed
rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall
vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Graphics: Device-1: NVIDIA vendor: Micro-Star MSI driver: nouveau v: kernel
bus-ID: 07:00.0 chip-ID: 10de:2216 class-ID: 0300
Device-2: Logitech StreamCam type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 4-4:2
chip-ID: 046d:0893 class-ID: 0300 serial: 52E38445
Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: nouveau note: n/a (using device driver) - try sudo/root display-ID: 0
OpenGL: renderer: llvmpipe (LLVM 12.0.1 256 bits) v: 4.5 Mesa 21.2.2
compat-v: 3.1 direct render: Yes
Audio: Device-1: NVIDIA GA102 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 07:00.1 chip-ID: 10de:1aef
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Native Instruments Komplete Audio 6 type: USB driver: snd-usb-audio
bus-ID: 3-4:2 chip-ID: 17cc:1001 class-ID: fe01 serial: 3173616E
Device-4: Logitech StreamCam type: USB
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 05:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp5s0 state: down mac: ea:b4:33:b2:b6:8e
Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus-ID: 06:00.0 chip-ID: 8086:15f3 class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: 24:4b:fe:57:7b:55
IP v4: 192.168.1.83/24 type: dynamic noprefixroute scope: global
broadcast: 192.168.1.255
IP v6: fe80::e5c8:c23e:900c:2360/64 type: noprefixroute scope: link
IP v4: 10.10.14.81/23 scope: global
IP v6: dead:beef:2::104f/64 scope: global
IP v6: fe80::7ff6:83a6:cc14:6e99/64 virtual: stable-privacy scope: link
WAN IP: 88.130.152.152
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-5:2
Report: rfkill ID: hci0 rfk-id: 5 state: up address: see --recommends
Logical: Message: No logical block device data found.
RAID: Message: No RAID data found.
Drives: Local Storage: total: 1.59 TiB used: 930.99 GiB (57.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte model: GP-AG41TB
lanes: 4 type: SSD serial: SN203108941571 rev: EGFM13.0 temp: 36.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: S1DBNSAD956330E rev: DB6Q scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD5000BPKT-00PK4T0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: WD-WX81A21A3165
rev: 1A01 scheme: MBR
Partition: ID-1: / raw-size: 53.23 GiB size: 52.1 GiB (97.87%) used: 10.63 GiB (20.4%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: a8fa1bf0-9f05-4059-8d0d-d6ef1ebae18b
ID-2: /boot/efi raw-size: 652 MiB size: 650.7 MiB (99.80%)
used: 288 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
label: NO_LABEL uuid: CAD1-2B79
ID-3: /run/media/je/FCA8E78BA8E7432E raw-size: 877.02 GiB
size: 877.02 GiB (100.00%) used: 751.7 GiB (85.7%) fs: ntfs
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A uuid: FCA8E78BA8E7432E
ID-4: /run/media/je/Volume raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 168.66 GiB (36.2%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17 label: Volume
uuid: AEF80C43F80C0C71
Swap: Alert: No swap data was found.
Unmounted: ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: 80E6-BFE1
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 515 MiB fs: ntfs label: N/A
uuid: 1CE638BAE63895CC
ID-4: /dev/sda1 maj-min: 8:1 size: 500 MiB fs: ntfs label: System-reserviert
uuid: E004BFCF04BFA6C6
ID-5: /dev/sda2 maj-min: 8:2 size: 231.86 GiB fs: ntfs label: N/A
uuid: F23EC29B3EC257ED
ID-6: /dev/sda3 maj-min: 8:3 size: 545 MiB fs: ntfs label: N/A
uuid: 3AF64610F645CD37
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0
Device-1: 1-5:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-2: 1-6:3 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: 9876543210
Hub-2: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-7.1:6 info: Razer USA Lian Li O11 Dynamic Razer Edition
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1532:0f13 class-ID: 0300
Hub-3: 1-9:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-9.2:7 info: Razer USA Huntsman Elite type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 1532:0226 class-ID: 0300
Device-2: 1-9.3:8 info: Logitech USB Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c539 class-ID: 0300
Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 3-4:2 info: Native Instruments Komplete Audio 6 type: Audio
driver: snd-usb-audio interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 4-4:2 info: Logitech StreamCam type: Video,Audio,HID
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo interfaces: 6 rev: 3.2
speed: 5 Gb/s power: 896mA chip-ID: 046d:0893 class-ID: 0300 serial: 52E38445
Sensors: System Temperatures: cpu: 42.2 C mobo: N/A
Repos: Packages: pacman: 1140 lib: 295 flatpak: 0
1: https://manjaro.moson.eu/stable/$repo/$arch
2: https://osmirror.org/manjaro/stable/$repo/$arch
3: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
Processes: CPU top: 5 of 521
1: cpu: 39.9% command: gnome-shell pid: 1825 mem: 1779.8 MiB (11.1%)
2: cpu: 15.9% command: brave pid: 3481 mem: 672.0 MiB (4.2%)
3: cpu: 2.9% command: brave pid: 3653 mem: 442.6 MiB (2.7%)
4: cpu: 1.7% command: brave pid: 141340 mem: 174.8 MiB (1.0%)
5: cpu: 1.4% command: discord pid: 3146 mem: 497.1 MiB (3.1%)
Memory top: 5 of 521
1: mem: 1779.8 MiB (11.1%) command: gnome-shell pid: 1825 cpu: 39.9%
2: mem: 672.0 MiB (4.2%) command: brave pid: 3481 cpu: 15.9%
3: mem: 497.1 MiB (3.1%) command: discord pid: 3146 cpu: 1.4%
4: mem: 442.6 MiB (2.7%) command: brave pid: 3653 cpu: 2.9%
5: mem: 429.4 MiB (2.6%) command: brave pid: 54221 cpu: 1.0%
Info: Processes: 521 Uptime: 11h 8m wakeups: 53 Init: systemd v: 249
tool: systemctl Compilers: gcc: N/A Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.06
