Hi, screen flickers black during start up and once booted is only visible when there is mouse input. Everything else works fine and no issue on external monitor when i add one. I have tried multiple kernels and reinstalling intel drivers but with no luck.
Kernel: 5.13.8-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=ca2162f3-b45a-4dfd-8f66-5da4c7eec2cd rw quiet apparmor=1
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 81YH v: IdeaPad 5 14IIL05
serial: <filter> Chassis: type: 10 v: IdeaPad 5 14IIL05 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0R32866 WIN serial: <filter>
UEFI: LENOVO v: DSCN34WW(V1.20) date: 05/25/2021
ID-1: BAT1 charge: 45.0 Wh (99.1%) condition: 45.4/44.5 Wh (102.0%)
volts: 12.4 min: 11.1 model: LGC L19L3PF7 type: Li-ion serial: <filter>
status: Charging cycles: 84
RAM: total: 7.45 GiB used: 1.84 GiB (24.6%)
Info: Quad Core model: Intel Core i5-1035G1 bits: 64 type: MT MCP
arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: A6 cache:
L2: 6 MiB bogomips: 19048
Speed: 1200 MHz min/max: 400/3600 MHz Core speeds (MHz): 1: 1200 2: 1249
3: 1246 4: 1201 5: 1210 6: 1201 7: 1201 8: 1249
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp
rep_good sdbg sep sgx sgx_lc sha_ni smap smep split_lock_detect ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel Iris Plus Graphics G1 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo bus-ID: 3-6:2
chip-ID: 174f:244c class-ID: 0e02 serial: <filter>
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.1.6
direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-icl
alternate: snd_hda_intel,snd_sof_pci_intel_icl bus-ID: 00:1f.3
chip-ID: 8086:34c8 class-ID: 0401
Sound Server-1: ALSA v: k5.13.8-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
port: 3000 bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
bus-ID: 3-10:3 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 238.47 GiB used: 9.55 GiB (4.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZALQ256HAJD-000L2
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: AL2QFXV7 temp: 35.9 C scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%) used: 9.55 GiB (4.1%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: ca2162f3-b45a-4dfd-8f66-5da4c7eec2cd
label: NO_LABEL uuid: EA56-E11D
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 3-6:2 info: Syntek Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 174f:244c
Device-2: 3-10:3 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
Message: No sensor data found. Is lm-sensors configured?
Processes: 222 Uptime: 17m wakeups: 529 Init: systemd v: 248 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1192 lib: 327 flatpak: 0 Shell: Bash
v: 5.1.8 running-in: konsole inxi: 3.3.06
Anyone know what could be causing this issue?
