Hello,
I’ve recently installed Manjaro xfce on a new HP Victus 15-fa0031dx laptop i bought about a week ago, encountering a problem with screen tearing when my mouse sits on about a seventh of the length of my screen from left to right. I’ve tried looking for a solution to my problem, or a similar one, in various forums, including this one.
My problem, even though I’ve installed Manjaro xfce, also occurs on KDE, and dwm, which leads me to believe that this is probably a driver issue. This forum post is one which has the most resemblance to my situation: ‘Hey, how I solve the cursor “tearing/flickering” for some seconds when I make my cursor go to the left part of the monitor’ (I’m not linking the post because I am unable to due to my account’s age).
$mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2021.11.04 false PCI
video-modesetting 2020.01.13 true PCI
$inxi -zv 4
Kernel: 5.15.78-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: Xfce v: 4.16.1 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HP product: Victus by HP Gaming Laptop 15-fa0xxx v: N/A
serial: <filter>
Mobo: HP model: 8A50 v: 37.43 serial: <filter> UEFI: AMI v: F.10
date: 08/23/2022
ID-1: BAT0 charge: 51.5 Wh (100.0%) condition: 51.5/52.6 Wh (98.1%)
volts: 13.0 min: 11.6 model: HP Primary status: full
Info: 8-core (4-mt/4-st) model: 12th Gen Intel Core i5-12450H bits: 64
type: MST AMCP arch: Alder Lake rev: 3 cache: L1: 704 KiB L2: 7 MiB
L3: 12 MiB
Speed (MHz): avg: 599 high: 980 min/max: 400/4400:3300 cores: 1: 805
2: 980 3: 485 4: 781 5: 613 6: 410 7: 541 8: 600 9: 482 10: 400 11: 572
12: 528 bogomips: 59916
Device-1: Intel Alder Lake-P GT1 [UHD Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-12.2 bus-ID: 00:02.0
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 520.56.06 arch: Turing
bus-ID: 01:00.0
Device-3: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 3-6:2
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: modesetting,nvidia
dri: iris gpu: i915 resolution: 1920x1080~144Hz
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel Graphics (ADL GT2)
direct render: Yes
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave driver: mt7921e v: kernel bus-ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 05:00.0
Local Storage: total: 505.81 GiB used: 13.84 GiB (2.7%)
ID-1: /dev/nvme0n1 vendor: Micron model: MTFDKBA512TFH-1BC1AABHA
size: 476.94 GiB temp: 34.9 C
ID-2: /dev/sda type: USB vendor: Kingston model: DataTraveler 3.0
ID-1: / size: 293.74 GiB used: 13.84 GiB (4.7%) fs: ext4 dev: /dev/nvme0n1p6
ID-2: /boot/efi size: 511 MiB used: 316 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p5
Processes: 278 Uptime: 21m Memory: 15.3 GiB used: 2.62 GiB (17.1%)
Init: systemd Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 918 Shell: Bash
v: 5.1.16 inxi: 3.3.23
Something that I found weird while looking for a solution to my problem is that my /etc/X11/mhwd.d contains a single file, nvidia.conf, which is empty; but that might be because I’m only using the integrated Intel graphics. I do have this file, but I just copied it from /usr/share/X11/xorg.conf.d/10-intel-nvidia-drm-outputclass.conf:
$cat /etc/X11/xorg.conf.d/10-intel-nvidia-drm-outputclass.conf
Section "ServerLayout"
Identifier "layout"
Option "AllowNVIDIAGPUScreens"
EndSection
Section "OutputClass"
Identifier "intel"
MatchDriver "i915"
Driver "modesetting"
EndSection
Identifier "nvidia"
MatchDriver "nvidia-drm"
Driver "nvidia"
Option "AllowEmptyInitialConfiguration"
ModulePath "/usr/lib/nvidia/xorg"
ModulePath "/usr/lib/xorg/modules"
EndSection
This has been a real headache, so I would appreciate any help you guys can provide me with.
Thanks!
