I’m getting screen tearing on a new laptop. I had Manjaro + KDE Plasma on my last laptop, but the last laptop also had a 1660Ti and a Ryzen 7 and now I’ve downgraded to a Ryzen 5 and Radeon graphics (I wasn’t dealing with nvidia driver issues again ). I’ve attempted a couple of solutions but nothing has worked as of yet. The most prominent result was to turn TearFree on, but doing it manually with xrandr ‘crashes’ (?) KDE Plasma. I get logged out and I have to log back in, but when I check xrandr --props
it doesn’t seem to turn it on.
As always, here’s inxi
output. Sorry if I’m just foolish, but I’d really appreciate any help.
Kernel: 5.15.74-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=e6f35551-64ad-4cfa-bd4b-b2623324c91c rw quiet apparmor=1
security=apparmor resume=UUID=b4aa7ba9-8910-4b33-8e17-9cc10f6dd579
udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Inspiron 15 3515 v: 1.4.0
serial: <superuser required> Chassis: type: 10 v: 1.4.0
Mobo: Dell model: 04D48M v: A00 serial: <superuser required> UEFI: Dell
v: 1.4.0 date: 01/10/2022
ID-1: BAT1 charge: 37.8 Wh (92.6%) condition: 40.8/40.8 Wh (100.0%)
volts: 12.6 min: 11.2 model: ATL 0x47,0x59,0x4D,0x44,0x00,0x00,0x0014
type: Li-ion serial: <filter> status: discharging
RAM: total: 29.27 GiB used: 2.86 GiB (9.8%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 5 3450U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
stepping: 1 microcode: 0x8108109
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1221 high: 1223 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1222 2: 1222
3: 1222 4: 1222 5: 1221 6: 1221 7: 1222 8: 1223 bogomips: 33547
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Dell driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:15d8 class-ID: 0300 temp: 47.0 C
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-2:3 chip-ID: 0c45:6730 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: amdgpu gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x08cd built: 2019
res: 1366x768 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
OpenGL: renderer: llvmpipe (LLVM 14.0.6 256 bits) v: 4.5 Mesa 22.1.7
direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Dell
bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Dell
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x,snd_pci_acp5x
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Dell driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.6
chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k5.15.74-3-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:c821 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-2.4:3 chip-ID: 0bda:c829 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Local Storage: total: 238.47 GiB used: 58.03 GiB (24.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC711 NVMe 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 41002131 temp: 27.9 C scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 224.71 GiB (97.97%) used: 58.03 GiB
(25.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: e6f35551-64ad-4cfa-bd4b-b2623324c91c
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 288 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
uuid: BB69-B6B3
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: b4aa7ba9-8910-4b33-8e17-9cc10f6dd579
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-2: 1-2:2 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-2.4:3 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 3-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 3-2:3 info: Microdia Integrated_Webcam_HD type: Video
Hub-5: 4-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 47.0 C mobo: 41.0 C sodimm: SODIMM C gpu: amdgpu
temp: 47.0 C
Fan Speeds (RPM): cpu: 0
Processes: 258 Uptime: 24m wakeups: 5 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1441 libs: 377 tools: pamac,yay pm: flatpak
pkgs: 0 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.22
